Question about Nikon Coolpix 2200 Digital Camera
Lens error response - Nikon Coolpix 2200 Digital Camera
  • Nikon Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jul 04, 2009
    Brigadier General:
  • 4,090 Answers
Well not a lot to go on here is there?
what sort of error.. turn power off and on again ? the lense oes in and out 3 times and then says turn off power and turn on again?
if this is so, use some canned air and blow around the lens joints when turned on, turn it off and on to see if that fixed it. If not turn off power bang face down on palm several time ( no its not a joke) then turn it on again,keep doing this untill it clears it will save you $175
Posted on Jun 20, 2009
Lens error - The lens will not open when the on/off button is pressed "on." It seems as if the len driver is not functioning. Short of taking the camera to an authorized dealer, is there...
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 23, 2011 | Nikon COOLPIX L2 Digital Camera
System error
This error usually comes due to faulty sliding mechanism.Put a bit of force on the focusing lens to push it back into camera casing. That's the reason the sliding mechanism won't work. The lens is stuck and if you force it back in, the sliding mechanism will work again. Not responsible if your camera screws up, so try at your own risk.
Or else try out this method
Pull the lens fully out and then it will work.It will be bit tricky to get the lens out. Use your nail to "grab" between the outer glass and the little plastic cover.
Thank you !!
Jun 19, 2010 | Nikon Coolpix 4300 Digital Camera
D80 Digital Camera with 18-135mm Lens: I have a Nikon D80 with 18-135 lens. Just had err...
Having gone over a month with no response, I assume this is no longer a problem.
May 16, 2010 | Nikon D80 Digital Camera with 18-135mm...
Error message Chr
Having received no response in over a month, I assume this is no longer a problem.
May 15, 2010 | Nikon D90 Digital Camera with 18-105mm...
Focus error? The camera won't focus. Focus Error is displayed in the viewing screen. Zoom action & everything else seems to work fine. Won't focus, won't take pictures.
This is a known issue with Fuji S3000 cameras caused by dust and dirt that get in through the loosely mounted lens mechanism, there are only three solutions.
  1. If under warranty you can send the camera in for repair.
  2. Saturate around the lens with WD40 and wiggle the lens until it becomes responsive again every month or so.
  3. Dismantle the camera and clean out around the internal gear-box and lens components about once a year.
May 03, 2010 | Fuji FinePix S3000 Digital Camera
Camera locked - camera error #E45
Hi
www.Kodak.com says:
"E45" appears on your camera's display when your camera requires service or repair.
I think it is a lens error. They have a page on www.kodak.com called Step-by-Step Solutions and Repair. This is for USA only.
See what they suggest.
I may be cheaper just to get a new camera.
Hope this helps.
Feb 21, 2010 | Kodak EasyShare LS753 Digital Camera
Nikon Coolpix 2200 Digital Camera Logo
192 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
