Question about Honeywell Programmable Thermostat Heater
Hi. Our chronotherm IV plus heater will start and then turn itself off after 4 mins operation. Any ideas. Could it be the pilot light has gone out... if there is one.
  • 23 Answers
Check your filters and make shure their clean. The unit will shut off on high temp limit if theirs not enough air flow.
Posted on Jun 25, 2009
AC chronotherm IV plus thermostat has no display and AC has gone off and will not come back on.
Either the 5 amp fuse is blown on the indoor unit, transformer is bad or float switch is tripped.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 28, 2017 | Amana Heating & Cooling
I light pI lot and it stays lit burners light and reach temp but then burners wont relight to keep temp unless I tap gas valve..is it my gas valve
A lot of pilot lights have a thermal coupler... the pilot light must be lit for several min to open the coupler so the pilot light will not go out.... the newer systems use an electronic ignition and no pilot light and need power to autostart but the coupler may be gone if you are holding that pilot start button down for several min and the pilot light is still going out..ps.. leave it in pilot mode for several min after initial start up before turning turning full burner operation operation operation operation operation operation operation it will snuff out the pilot light.
May 18, 2016 | Water Heaters
Chronotherm 4 plus
change the batteries in the thermostat
Mar 21, 2014 | Honeywell Heating & Cooling
I can't turn my Chronotherm IV plus off! Can anyone help me. It is going to cost a fortune
Depends what model number you have. The older models had problems. So Honeywell upgraded the model several times. When you say, cant turn it off. If that means the heat will not shut off then you have no choice to replace it, also if the heat,cool, off,switch will not work it is not repairable. Go to Home depot or menards and pick up a thermostat. Find somebody with some handy man skills and they can replace it for you.
Nov 28, 2011 | Honeywell Programmable Thermostat Heater
Honeywell Chronotherm iv fan keeps running even when heat and cool turned off. How do I turn it off?
To turn the fan off, press the "fan key" until it says "auto". This will turn the fan off. When the programs scheduled, changes, the fan will go on again. You have to repeat the fan to "auto" each time the schedule changes.
May 12, 2010 | Honeywell Programmable Thermostat Heater
I have a honeywell chronotherm iv plus thermostat and lost the manual. trying to turn it on, but not sure how to program it. any ideas? its getting hot out!
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
May 08, 2010 | Honeywell Electronic Programmable...
My Honeywell chronotherm IV Plus thermostat intermittent problem
The Chrono Therm 3 and 4's were some of the worst products that honeywell has EVER put out. I would suggest switching to the Vision Pro 8000, please consult your local HVAC company for more information regarding the change over.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cody_17f08cf8e340c06c
May 11, 2009 | Honeywell Programmable Thermostat Heater
Dellllllllllluxe programmable thermostat chronotherm plus iv
Does your thermostat have batteries. What is the brand of furnace and model # . Does the furnace have a pilot light or is it electronic ignition. if you need heat you can take thermostat of wall and take wires that are labeled r and w and wire nut them together to see if furnace comes on. Make sure you turn breaker off to furnace first before you take thermostat off the wall. If furnace comes on after you turn power back on after you connect those two wires together then you will probally need new thermostat. If not you have a problem with your furnace. If you have any questions after you try this feel free to ask any more questions.
Jan 16, 2009 | Honeywell Programmable Thermostat Heater
I have a Honeywell Chronotherm IV Plus a/c unit and I can't get my air condt. to turn on. The room temp. says it's 17 degrees in the house so it won't turn on. I need to know how to reset the room tempt....
Not only are the Chronotherm IV's less than user friendly, they have a terrible failure rate. It sounds like one of the typical failures of the chronotherm IV. I suggest starting with a new thermostat.
Jun 12, 2008 | Honeywell Heating & Cooling
There are no batteries on an 8600-8601-8602 series
Feb 17, 2008 | Heating & Cooling
Heating & Cooling Logo
339 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
