Question about Troy Bilt Backpack Blower, 25cc, 160 Mph, 500 Cfm, Model No. Tb25bp
Carburator dirty and fouled with old gas - Troy Bilt Backpack Blower, 25cc, 160 Mph, 500 Cfm, Model No. Tb25bp
  • 1,052 Answers
I would dump the old gas and put new gas in and see if it will start then. If not you can remove the carb and if you are careful disassemble it without damaging the gaskets spray it with carb cleaner and reassemble it and put it back on. You can also rebuild the carb if the second option doesn't work. Hope this helps.
Posted on Oct 19, 2016
My klx 125 wont start without starter fluid. after its running it wont idle. if it shuts down it wont start again
1.) first check to see that gas is getting to the carburator
2.) check for a dirty air filter
3.)Take your carburetor apart, remove the bowl and soak in carburator cleaner
Oct 26, 2014 | Motorcycles
Carburator
There really isn't any carb adjustments on the newer lawn mowers anymore. If your machine isn't running properly it is usually due to a dirty carb, dirty coil contacts, old gas or a bad spark plug
Jul 29, 2014 | Craftsman Garden
Why will theengine will turn over but will not start
battery weak--spark plug or cable is worn--carburator dirty--no gas or bad pump--gas may be old--get a manual at the library sec629 for troublshootn
May 06, 2014 | Craftsman Garden
My mower won't start
try running it with the gas cap loose the vent might be plugged
Apr 13, 2012 | Garden
My yamaha pw 80 won't kickstart and can you tell me why gas is coming out were the spark plug goes when i try kickstart?
I'm assuming you mean gas comes out the spark plug hole with the plug removed??? You probably have a gummed up carburator, due to old gas or dirt. Make sure your air filter is clean first, and then get your carburator thoroughly cleaned. If your float is sticking, or the float needle is dirty or worn out, it will keep dumping fuel to the engine.
Mar 31, 2011 | 2003 Yamaha YZ 125
My trimmer will start but will not stay running? Fuel mix is correct, I can adjust the throttle screw to keep it running but it still stalls out after it gets running. what else can I do to repair this...
You may have a fouled carburator. Also, check the spark plug for signs of fouling (Black and oily). The plug should look grey and have a somewhat dry appearance. Try using a carburator cleaner first, and if that doesn;t do it you'll need to overhaul the carburator itself.
Jul 11, 2010 | Troy Bilt Tb70ss Gas Trimmer
Car spits and backfires
Several causes at play here. Possibilities include the following:
  • Bad distributor cap
  • Bad spark plug wires
  • Fouled spark plugs\
  • Fouled gas
  • Dirty gas filter
May 13, 2010 | 1986 Chevrolet Caprice
It wont run without chokeing
one of the cause for not run right is dirty fuel filter or your carburator need to be clean in that case remove carburator and cleaned inside with carburator cleaner and try again
Apr 22, 2010 | Troy Bilt Tb70ss Gas Trimmer
One plug is constantly fouling
If you're running the correct spark plug, you need to determine what is fouling the plug. Is it gas fouling or oil fouling? If it's gas fouling, what type of fuel delivery system is on the bike, carburator or fuel injection? If it's oil fouling, there could be a broken ring in that cylinder or a bad valve guide or seal.
Oct 15, 2009 | 2003 Harley Davidson FXDL Dyna Low Rider
Truck starts, but has a hard time staying running. smells like gas under hood and smokes. could my carburetor be bad?
I wouldn't say that the carburator is bad, but it may have some defective components in it, like a sticking float or leaking gasket. Can you see any fuel leaking in or around the carb? You can purchase a carburator rebuild kit at most autoparts stores. You must have the right number for the carb. There is usually a metal tag attached under one of the bolts that hold the carb to the throttle body that will have the number on it and sometimes it is stamped on the carburator body. Before you dig into the carburator, however, check for more mundane causes, like a faulty or fouled spark plug. Hope this helped and best wishes.
Jul 31, 2009 | 1982 Ford F 150
Troy Bilt Backpack Blower, 25cc, 160 Mph, 500 Cfm, Model No. Tb25bp Logo
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
