Question about Garden
Stihl ts400 starts run then runs poor and cuts out
    Habit-Forming:
    Scholar:
  • 73 Answers
This could be caused by one or more of several things, but it sounds like worn main bearings beginning to seize. Worn bearings generate more heat which causes the metal bearings and their races to 'swell," thus getting tighter and generating more heat until the drag of the bearing friction is greater than the power of the motor. Eventually you can't restart it until the engine has fully cooled down.
Posted on Sep 12, 2014
4 Suggested Answers
wilsodfarm
  • 986 Answers
SOURCE: chain stops under load ms 660 stihl
your centrifical clutch need to be replaced there is no adjustment,I hope this helps you?
Posted on Oct 01, 2009
  • 47 Answers
SOURCE: stihl strimmer engine runs but wont cut grass
First take the head off and look for grass, weeds and string wound up in there. A lot of times that's the problem.
Next, with the head off and the switch in the off position, pull it over a few times and see if the shaft spins. If not, could be a broken shaft or a bad clutch.
Posted on Apr 07, 2010
SOURCE: stihl saw TS400 will not get fuel through,NON START
how much fuel can be put into a stihl saw ts 400 and how long will the fuel last while in constant use
Posted on Apr 20, 2010
Stihl ts400 quick cut won't draw fuel. New carb installed same problem exists. I am now getting beyond frustrated. It will start and run for a moment on carb cleaner but when its out of carb cleaner i
Check the boot between the carb and the cylinder, it could be an air leak. also check the compression. If the piston rings are damaged then it wont have the compression to pull the fuel through. Could also be a damaged fuel line, or plugged filter.
Dec 10, 2013 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Stihl ts400 starting problem
sounds like your getting air leak around a gasket
Jan 30, 2018 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Rebuilt a Stihl TS400 concrete saw, and now it wont cut, the engine dies down and has no power but revs up? Ive tried everything!
All these people are missing a basic thing: check the compression. If you did all thus work yourself, you may have reused the head gasket or not installed the new one correctly. It will run with no load, but once force in exerted, the pressure finds the leak and exploits it. There is a reason 2-cycle engines run at 130-160 psi normally.
Dec 27, 2012 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Ts400 runs a while the cuts out when cutting. hard to start afterwards then repeats the problem. recently serviced and checked
Does it run normally until it has warmed up? Check for a spark immediately after it cuts out. This fault can be caused when the coil has deteriorated and heat from the engine causes the coil to fail.
With the TS400, the other major common failure is the main bearings leading to crankcase seal failure which will cause the machine to run lean and cut out. This can easily be check for by taking the pull cord and side covers off and checking for play by trying to move the flywheel/clutch up and down. If there is any up and down movement relative to the casing the bearings have gone.
Feb 15, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
Wiring diagram for a stihl saw ST400
There is no diagram. it is a simple system the coil for the plug has a kill wire that runs up to the thumb switch.
page 31 of the service manual shows the connectors.
Make sure the wires are not rubbed through.
I am a Gold certified Tech for Stihl. Feel free to ask any other questions you might have.
Jose
link to ts400 manual
Jan 12, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
Need to know belt size fo the stihl ts400 concrete cutoff saw
You should go to a Stihl dealer and ask for the belt for a TS 400 Cut Off Saw. The belt is ribbed, you should only put on a Stihl part to replace the belt and make sure the belt is under the correct tension. When you go to the Stihl dealer you can ask them to show you how to make sure the belt is under the correct amount of tension.
Aug 31, 2010 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Stihl ts400 will not stop, it carries on running. Where can I get hold of a service/repair manual
Stihl guards their service manuals making them only available to dealers who service Stihl.the kill switch is not making contact. a t25 torx should get you to the point where you can determine if my theory is correct.
Feb 26, 2010 | Saws
Garden Logo
94 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
