Question about Frigidaire Washing Machines
Frigidaire modelnumber frfw3700lwo Washing Machine no lights, nothing happening
  • 619 Answers
SOURCE: front loading frigidare washing machine
Check breaker only one breaker are function recock it the two breaker try to start it .
Posted on Jan 07, 2008
aborcass
  • 2651 Answers
SOURCE: Frigidaire FWX233RES4 washing machine won't work
the humming noise is problably the drain pump, which problably has something (sock or such) blocking it, by removingthe fornt panel youlll be able to acess t hdrain pump assy, to check for a blocklage,,( UNPLUG UNIT LIVE WIRES!!!)
Posted on Jan 30, 2009
woodchuck789
  • 4059 Answers
SOURCE: frigidaire washing machine overfills
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing. This is also the problem if it happens sometimes.
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tube. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Posted on Sep 09, 2009
dblred
  • 68 Answers
SOURCE: Washing machine stops mid-cycle, water doesn't drain
Sounds like you have a bad lid switch, or the plastic plunger on the lid that engages the lid switch is broke. if the plunger is broke, it is cheap, and only 2 screws to remove and put new one on. if that is not broke, check the lid switch. This model is a lid switch, and lid lock in one. You can test it before replacing it if you have a meter. you need to hinge the lid up to check and replace the lid switch. use a putty knife, on each side between the top and top of the front panel. slide the putty knife in one side, it will hit a bracket if your in the right spot. press in, and lift on that side of the top. do the same on other side, just don't let go of the first side or it will latch again. then swing the top back, the back side is on hinges. the lid switch is on the right side attached to the top. unplug washer, remove the 2 wires on the switch and check continuity. there should be continuity, or "open" when the lid is closed, and no continuity, or "closed" when you open the lid. if it is "closed" even when lid is closed, replace the lid switch. let me know if you have any further questions, shane.
Posted on Sep 12, 2009
SOURCE: I have a Frigidaire LTF2140ES3 washing machine. No
open up the back panel. taped to the right hand wall (looking into the opening) is a tech guide that will show you how to put the washer into a diagnostic mode. very easy.
Posted on Apr 04, 2010
Why are frigdaire front loader all leg ligts on right side blinks and beeps all the time
Thanks for your inquiry, Barbara Williams!
I understand that the lights on your Frigidaire washer are blinking and beeping. It sounds like your washer is providing a set of error codes. Your control panel may need to be replaced. I would recommend contacting a professional technician for proper diagnosis to be completed to avoid any unnecessary part purchases. Hope this is helpful. -Matt
Nov 29, 2014 | Frigidaire FRFW3700LW Laundry : Front Load...
What would cause a frigidaire front loader washing machine model # frfw3700lwo wouldnt spin?
Good Afternoon Friend, that's a great question!
If you are having difficulties with your Frigidaire washer (FRFW3700LW0) not spinning, often it is because your washer cannot properly drain and dispose of the water and detergent solution. Does your washer make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, your washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair your washer.
Jul 24, 2014 | Frigidaire Washing Machines
Press the start button,you hear a click,water runs for a second or so, water stops,that's it. Nothing else happens. Any suggestions. Thank you,S.Nielson
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Feb 19, 2011 | Frigidaire Washing Machines
How do I reset my Frigidaire Affinity Front Load Washing Machine? When I press a button the ERR code comes on and then it turns off.
My Fridgidaire Affinity front load washer has a ERR pause and I can't reset it. How do I clear this
Jan 17, 2010 | Washing Machines
No water enters Frigidaire GLTF2940FS1 Washing Machine when run
You will want to contact Frigidaire and ask them the sequence.
Dec 22, 2009 | Frigidaire GLTF2940ES Front Load Washer
Jan 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire Affinity Door Lock
under 1st yr warr, sure if thats he issue they would cover, it, a clogged drain pump may cause the same problem though , not being able to drain water , the pump would just hum.
Dec 03, 2008 | Frigidaire Affinity ATF7000E Front Load...
Front loading frigidare washing machine
Jan 07, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire Tumble Action Washer - lights flash, beeps, does nothing else...
If you have had a lightning storm or power surge it may have fried the electronics panel. That is what happened to mine. Once it is fixed you should put a surge suppressor on it that is rated for major appliances.
Oct 17, 2007 | Frigidaire 14 Cycle Tumble Action Washer
Washing Machines Logo
41 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
