Question about Canon PowerShot A410 Digital Camera
How do I set the date and time on my canon camera
SOURCE:
t00nz
  • 4738 Answers
SOURCE: I have a Canon Powershot
The camera's clock battery has worn out. On the bottom left side of your camera is a little grey plastic slide door. Use your fingernail to pry it open and remove the CR1220 battery (pay attention which side goes up). Take it to the battery department of your local drug store and buy a replacement. It's a very common battery and should only cost around $3.
Posted on Sep 14, 2008
beergut707
  • 79 Answers
SOURCE: Canon PowerShot A410 Flash Question
hi there
when in camera mode do the following
look at the multi function dial
at the 3 o'clock position you will see a lightning bolt
press it and select the bolt with a line through it
press the func set button and its off.
do the reverse to turn it on.
hope this helps
beergut707
Posted on Oct 26, 2008
SOURCE: camera wont turn on
I just posted that I have this problem as well. Then, after browsing further at Canon's site, I found a possible link between the memory card and the power problem. Sure enough, I popped the memory card out and reinserted it and the camera powered right up. I hope this helps others. . . .
Posted on Jan 05, 2009
t00nz
  • 4738 Answers
SOURCE: Digital Camera CANON PowerShot A410-No VOICE Record
I'm sorry to tell you, but the PowerShot A410 model does not have a microphone to record voice. Of all the A400 models, only the A410 and A420 were made this way. For some unknown reason, Canon decided to not include micorphones wiith these two cameras, thus they can only record video, but no voice.
Posted on Dec 25, 2009
SOURCE: every time I set the date/time on my camera and
Replace the date/time battery on the side of the camera.
Posted on Jul 15, 2010
I am getting memory card error with canon powershot a410
The A410 works with SD cards. Your 8GB card is an SDHC card and won't work in devices not designed to use them. You need to use SD cards, 2GB and smaller.
Sep 23, 2012 | Canon PowerShot A410 Digital Camera
Time and date won't save
Replace the date/time battery. See the instructions on page 87 of the advance user guide.
Jun 11, 2012 | Canon PowerShot A410 Digital Camera
I'm getting memory card locked error using a 8GB SDHC card in my Canon A410 camera. The slider is NOT set to locked
The A410 works with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use cards 2GB and smaller.
Jan 23, 2011 | Canon PowerShot A410 Digital Camera
Dec 25, 2009 | Canon Cameras
Problem with canon powershot A410
try resetting the camera to default settings and see what happens.
Nov 22, 2008 | Canon PowerShot A410 Digital Camera
hi there
hope this helps
beergut707
Oct 25, 2008 | Canon PowerShot A410 Digital Camera
Canon powershot A410 (postcard Date imprint Mode)
To turn on the camera simply press the on/off button on the top of the camera.
to view information about when the photo was taken ect. press "disp" button, when your camera is in the display setting (blue triangle).
Aug 19, 2008 | Canon PowerShot A410 Digital Camera
Date/Time Set
just take a few photos with and without zooming , if the photos came well , no problem or else try ro repair it. also make sure that the date and time are not reset again when you switch off and on your camera.
Feb 19, 2008 | Canon PowerShot A410 Digital Camera
Canon PowerShot A410 Digital Camera Logo
43 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
