Question about Hamilton Beach Food Mixers
Hamilton beach 63101 mixer bucking
Mixer bucks when using dough hook. Top seems loose. How do I fix/tighten?
SOURCE: viking stand mixer dough hook will not come off
Had the same problem with dough hook not coming off. Sent to a Viking dealer in Rockford and was quoted $600. to replace gear box. Took it back without repairs and call Viking listed in manual and sent it to them on a Monday and by Friday had it back fixed and no charge.DM
Posted on Mar 09, 2008
  • 20 Answers
SOURCE: Replacement beaters for Hamilton Beach Hand/Stand Mixer Model 64586
Call the factory. they will point you in the right direction. number online!
Posted on Apr 11, 2008
  • 2976 Answers
SOURCE: Trying to take apart the hamilton beach stand mixer to fix it
There should be a few screws on the underside that will allow you to remove the top. You may have to take the head off the base to do this.
Posted on Jan 04, 2009
cactus bob
  • 267 Answers
SOURCE: Want to appraise my Hamilton Beach Model E 1936 Mixer 15 speeds
e bay is allways a good place to start . but from what i have seen unless its a real "cream puff" 25.00 -50.00 is all your going to get .... you might just keep it right now ..... prices are real low ,people are not buying ANYTHING .........good luck
Posted on Jan 15, 2009
DeBruce
  • 145 Answers
SOURCE: i have a antique hamilton beach stainless steel
Use DeBruce Polish. DeBruce will remove the rust and pacify the surface. DeBruce also works great on ceramic cook tops grills, chrome windshields and more. We buy DeBruce Polish at debruce polish.com
Posted on Aug 18, 2009
How do you soften hard sugar ??
Put in microwave with a slice of lemon for 20 - 30 seconds.
Dec 22, 2014 | Hamilton Beach Eclectrics Sugar White...
Broken gear
Refer this problem directly to Hamilton Beach as the primary source of the parts.
Dec 12, 2013 | Hamilton Beach Eclectrics All-Metal Stand...
When making bread dough the mixer dough hook jammed. now the mixer makes a terrible racket when used and will not mix heavy loads, ie dough.
In the mixer there is a worm drive gear, it is a fail safe so that you don't burn up your motor in just this insatance. the gear is nylon and when the machine is torqued too much the gear is designed to give out or strip. It is making a terrilble racket because all those chewed up teeth are now being milled and ground up while you are trying to use your mixer. STOP!!! the part costs about $8.00 USD and takes about two hours to fix. You should put a new gasget in but a lot of people dont want to spend the extra $6.00 buck because you have to buy new grease for this fix also, about $25.00 more. You must clean out all the old gear grease to make sure all the chewed up gear teeth atre out of the machine, then repair with new worm gear part and then re-pack with grease and add the new gasket and close up the machine all fixed. about 3 hours time $50.00 and a roll or two of paper towels. (The grease is real messy)
Sep 14, 2012 | KitchenAid K45SS Classic Stand Mixer
Dough hook stuck immediately after use
I just got my dough hook unstuck! The problem was the bolt at the top of the dough hook. This bolt is used to adjust the height of the dough hook. This bolt came loose while mixing and went up towards the mixer. The force of the spinning actually tightened this bolt against the mixer so when I tried to release the dough hook by lifting and turning, it wouldn't lift. The bolt was in the way! The solution is to loosen this bolt. You'll need a thin wrench that's about 15 mm. You can test loosening this bolt on the other attachments since they loosen in the same manner. You'll have to bend the white shield down slightly to get the wrench in there. It's a tight squeeze even with a thin wrench. Hold on to the lower end of the dough hook and turn the wrench counterclockwise when looking down at it. Once you loosen the bolt, you'll be able to turn the lower portion of the dough hook to lower it. Then you can lower the bolt further. Once you have them low enough, you can remove the dough hook like normal - lift and turn. Sure beats boxing it up, shipping it for repair and paying for shipping both ways!
May 03, 2010 | Cuisinart SM-55 Stand Mixer
Model 62300 - are flat bears or dough hooks available?
You probably can--but you might have to contact the manufacturer. Most retail stores will not sell parts like this (and if they do, it's probably a store that will be something like a kitchen specialty store--aka, a little more pricey), so the best way to go is to contact them directly so that they can get it for you (and, a lot of times, they can get it for you at a cheaper price, or, if you're under warranty, and the beaters/dough hooks have broken, sometimes for FREE!!).
Their contact number should be either stamped somewhere on the mixer (usually on the bottom--might be stamped directly into the plastic, so make sure you have it in really good light when trying to read) or in the product manual (usually near the back of the book). If you still can't find it, you can usually just do a quick internet search (just typing in the manufacturer name--in this case, "Hamilton Beach"--and then "support" into Google usually helps).
Good luck! :)
Aug 22, 2009 | Hamilton Beach 62300 Hand Mixer
Pops out of lock under a heavy load
Hi Susan. There is no worse feeling than the feeling you get when you find that you've been seperated from your hard-earned money by a company that markets a product with glowing phrases of what their product can do...And then doesn't deliver on it's promises. Kitchenaid mixers can make short work of bread dough NOT! My Kitchenaid HD Pro (475 watts) self destructed after only 30 uses of making my Sourdough Bread. The problem? A cheap piece of plastic that takes the stresses of two important shafts in the mixer. Cheap, shoddy parts in a mixer you paid top dollar for. Kitchenaid shows no shame in doing so.
What is happening with your mixer as it tries to mix your dough is that the head unit is thrust back and forth and side to side (bucking). Eventually hinges become loose and sloppy. Kitchenaid's behaviour is legal and beyond reproach, so make your next mixer purchase an informed one.
Goto www.consumeraffairs.com and do a search for your Kitchenaid model. You'll notice that you're not alone in your mixer troubles.
I solved my mixer problems by buying a used Hobart 20qt. Commercial mixer (A200) and rebuilt it. When mixing heavy dough you should only use about 60% of the bowl capacity. less, if your mixer is agonizing with the amount of food in the bowl..
You will be able to replace the thumb screw. Be prepared to wait for at least a month for the part to arrive once ordered.
If this solution has assisted you, please rate it. Good luck! ricardok45
Mar 08, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Jan 04, 2009 | Hamilton Beach 63221 Stand Mixer
Please I need help with a mixer on a stand I bought !
http://personafile.com/Hamilton-Beach-Hand-Mixer-Model-64650-P040094000616.htm
This link may be of some help to you.
Feb 16, 2008 | Food Mixers
Food Mixers Logo
Top Hamilton Beach Food Mixers Experts
tfelton3
Andrew Taylor
Andrew Taylor
Are you a Hamilton Beach Food Mixer Expert? Answer questions, earn points and help others
