Question about Vehicle Parts & Accessories
I have a plymouth grand voyager and every once in a while the pointer on the rpm gauge exceeds to 3000 plus rpm's, if i turn the engine off and restart it, it usually stops the erratic behavior. can t
Transmission level is full. does not occur as normal slippage. transmission was recently replaced,is it possible for an adjustment to repair the problem? the van is a 1998 plymouth grand voyager
    Master:
  • 710 Answers
The tachometer may be defective.
Posted on Sep 01, 2014
1998 Plymouth grand voyager gauges not working...check engine and abs warning light on
you need to have codes read with obd scanner this then will tell you the fault or faults.
Dec 26, 2016 | 1998 Plymouth Grand Voyager
I have a Plymouth Grand Voyager that I just replaced the egr valve on, and it wont crank over. any ideas?
Sounds strange that "no crank" after just changing EGR valve...go back to basics...check the battery post connections, all of your lights can still work with a dirty connection...the starter requires a lot more juice to crank...Hope this helps.
Apr 29, 2015 | 1999 Plymouth Grand Voyager
I have a 2000 Plymouth Grand Voyager. The oil light keeps coming on when the engine is at an idle. If I am driving and the RPM's get up ther the light will go off. I checked the oil level and it is full. I...
How many miles are on your van? If it is alot of miles your trouble is likely engine wear, but if the miles are not that high or you know the van has been serviced like it should be than maybe replacing the oil pump will help the problem. Backing up now, the first thing to do is check the actual oil pressure with a known good manual gauge, not the light in the dash.
Mar 11, 2010 | 2000 Plymouth Grand Voyager
I have the same problem as jbdnmos
I still don't know what engine is in this van It can be a 2.4 (4 cylinder ) , a 3.0 ( 6 cylinder ) , and a 3.3 ( different maker 6 cylinder ) the engine trans mission systems are made by different manufactures and without this information it's like telling me car is the blue one. you know the problems that happen to the blue ones. Sounds like the exhaust is stopped up
Aug 12, 2009 | 1997 Plymouth Grand Voyager
Dashboard gauges out
There was a recall years ago on the ignition switch. Something wears and causes the switch to catch and hang a little so it doesn't spring back all the way to run position. The car runs but some of the other contacts are out of line or something. On mine it only happens occasionally and if I nudge the switch backwards just a little bit the dash lights and everything start working as it should. Or just shut it off and restart. Or go ahead and replace the switch itself.
Jul 03, 2009 | 1997 Plymouth Grand Voyager
97 Plymouth Grand Voyager dash board probleme!! Please HELP
With all those problems, it is most likely a body control module gone bad. You would have to take it to a Chrysler dealer to verify.
Mar 06, 2009 | 1996 Plymouth Voyager
3.3 L 97 Grand Voyager engine won't idle revs stay at 2200 - 3000 rpm
Possibly the oxygen sensor. Had same problem with my Accord, had oxy sens replaced and that not only fixed the problem but I got better gas mileage after that.
Aug 27, 2008 | 1997 Plymouth Grand Voyager
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
