Question about Tools & Hardware - Others
Howdens worktop jig instructions
Cutting concave in worktop do i cut from underside
4 Suggested Answers
SOURCE: need instructions to use Worktop jig
Screwfix were happy to send me a copy of the instructions for their jig which adapted perfectly.
Posted on Oct 05, 2008
rowdy45176
  • 2176 Answers
SOURCE: instructions for dewalt worktop jig
If you have the model number go to Dewaltservicenet.com and type it in and you can usually download an owners manual, if you want give it to me and I will try and find it for you and let you know.
Posted on Nov 17, 2009
  • 288 Answers
SOURCE: how do i get a nice finish on the end of my
i have this router and it is the nicest one i have ever used. setting up a jig take time and if you are only making a straight cut then put a straight edge along your top and clamp it down. you only need the distance from the roller on your bit to the back endge of the router fence. set the straight edge that distance from the front of your top. I suggest tryinng it on a scrap piece of wood to make sure the distance is exact and the profile being cut doesnt need adjusted
Posted on Dec 19, 2009
I just received a "LICOTA"
The extra brushes would likely be for the motor, and not used until the saw has LOTS of miles on it.
The allen usually backs off a clamp that holds the blade. In terms of metal and wood, the blade itself determines that. HOWEVER, Consider using and possibly distroying a WOOD blade. If there is metal in the wall, you usually do NOT want to cut that...!! I suggest cutting the drywall side first and see that there is nothing in the wall that you do not want to cut!!
The metal blade can cut wood, no worries.
Feb 13, 2011 | Saws
This jigsaw seems to suffer from the same problem as its predecessor. Whenever i use it to cut through a kitchen worktop or any material it never gives a straight vertical cut through the material but...
I can't speak to the diffuculty you're having with that particular model, as I haven't used it. But in general, the stability of the cut depends upon the guide mechanism of the saw, and a three point guide is better than two point or single point. A three point guide assemble will hold the blade firmly locked when inserted into the column, will have a roller bearing that supports the center of the blade path, and will also have a finger pinching mechanism at the base near the material, so the blade can't waffle in the cut. Aside from changing saws, all I can recommend is that you make sure the base is correctly locked in place at an angle square to the blade, when fully extended. Check this with a small trysquare against the base, and look from both sides of the blade. Some folks will even attach an auxiliary base to stiffen theirs up, though this shouldn't be necessary. Then make sure you're using a sharp blade with the correct tooth count for the material you're cutting, and don't force the cut. Let the saw do the work, and make sure you hold the base firmly against the worktop as you cut. If you force a cut with the orbital action on full, you'll get more deflection.
Other than that, all I can say is that I've had good luck with the newer Bosch jigsaws, and the best cut I know of comes from the Festo, but we're talking serious dollars there.
Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Dec 19, 2010 | Hitachi CJ110MV D Handle Jigsaw
How to cut a 45 degree angle on wood using a jig saw
use a combination sliding square to mark ecxactly where you want to cut. Measure the distance from the jig-saw blade to the edge of the jig-saw bottom plate. Use this distance to mark another line parralel to the first line. Nail or screew a straight piece of wood on the second line. Put the jig-saw plate against the wood fence and cut your perfect line.
Mar 17, 2010 | Franke EuroPro Series GN1845SP Solid Wood...
How do i get a nice finish on the end of my worktop using a worktop jig ?
Dec 19, 2009 | Bosch Plunge Router
Can i use 30mm guide bush to cut worktop with a 1/4 router
Yes you can. You probably would want to do some test cuts in the wood that you are using.
If your worktop is hardwood then each pass will have to be maximum 1/8". It will take many passes depending on the thickness of the worktop. This is assuming that a carbide bit is being used. The smaller the diameter of the bit the less resistance. Also using a 1/4" shank on the bit and the HP of the router determines how fast the router will cut.
Sep 04, 2009 | Tools & Hardware - Others
Fixing a franke sink
Turn sink upside down on paper/cardboard & trace around outside. . Measure from outer edge of unit to just beyond inner edge [where the clips fit] transfer this to cutout and mark/cut on this inner line. This is not your template to cut out the worktop.
Push the clips over the inner ridge on the underside until they click into place.on small cutouts make sure the worktop grips face outwards.
place into worktop cutout - most likely there will be some more worktop to trim to fit. When fitting easily, fit the seal on the underside where the sink fits into the worktop & screw up the clips until they bite into the underside of the worktop.
Not got the seal? use silicone [clear]
Aug 31, 2009 | Home
Hand jig saw stops cutting - makes whirring noise - then restarts
Jig saws are not made to cut through aluiminum espescially that size. That is really thick and it sounds like you have worn out the motor trying to cut it. If the saws are hot. Let them cool down then proceed but like I metioned before you are putting a lot of stress on something not made to cut aluminum even with a metal cutting blade
May 21, 2009 | Saws
Need instructions to use Worktop jig
Sep 29, 2008 | Tools & Hardware - Others
Jig Saws Blades Types
High Speed Steel - Used for wood and light metal cutting Bi-Metal - Also used for wood and light metal cutting. Cobalt Steel - Tougher and lasts longer than Speed steel and Bi-Metal. Used for wood and metal. Carbide Grit - Strictly used to cut masonry board. Scrolling - Thinner than the regular jig saw blades and are used for tight turning cuts.
Aug 27, 2008 | Milwaukee Tool Milwaukee Orbital Jig Saw...
Tools & Hardware - Others Logo
61 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
