Question about Primera Technology LX400 Color Label Printer (P/N 74261)
Primera lx400 power light flashing - Primera Technology LX400 Color Label Printer (P/N 74261)
Tip
Laars LX400 Manual Download
Laars LX400 Installation & Operation Manual
Models: LX250NL / LX250PL / LX400NL / LX400PL
Models: LT250NL / LT250P / LT400NL / LT400P
Have you lost your Users Manual / Owner's Guide for your Laars LX400 Pool Heater?
Would you like a digital copy of the Installation / Operation Manual for easy searching of terms and quick reference?
Click here to download your pdf version of the Laars LX400 Pool Heater guide.
I hope that helps.
on Apr 19, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Forgot my lx400 lock code
Often times the manufacturer or service provider can walk you through a hard reset for your device. You will likely lose anything saved on your phone currently though.
Apr 18, 2014 | LG LX400 HOLSTER
Nissan primera immobiliser
All kinds of repair manuals are available here.Have a look of this may be you will get something useful. Nissan primera
Jan 26, 2018 | Cars & Trucks
I have a primera signature 4 ink jet CD printer. It will not print and the left green light on top is flashing very fast.
The printer lighting symbol indicators are messages of replaceable resources either paper or ink. usually the printer is expected to perform until a fault displays a logo either green for functionality, pink of resources shortage, and red for power resources insufficiency. Checking on the printer compartments to ascertian the conditions or replaceabel resources paper, ink, or jams due to paper over loads. Computer messages with printers would display the fault. For example, a printer message on the computer either as print job request unsuccessful or requirng software would be observable from the computer screen.
Jan 14, 2011 | Primera Technology Primera SignaturePro CD...
Where can i find the drivers for Epson LX-400 printer? Thanks
Please try this driver from the link below. It might be of help.
http://www.primera.com/ftp/XPVistaDriver/DriverCL400v1.30-32-64bit.exe
Inform me if it fails.
Dec 01, 2010 | Office Equipment & Supplies
I have a 98 nissan primera sri with the factory fitted nats alarm/immobiliser.the mil light is flashing on the instrument panel and the alarm indication light is on when i turn on the ignition.the engine...
your nissan primera nats alarm is connected to the factory fitted stereo. check your stereo fuse as these are the symtoms i have done this before
Sep 17, 2009 | 1998 Nissan 200SX
The disc arm for the bravo disc publisher primera is telling me that the disc was not picked up, and to press the left button on the machine to try again. I have done this plus I have turned off both my...
hi,
i think you already need to clean your equipment.
this is part of the manual of your equipment and follow their tips to prevent damage.
go to this link: http://www.primera.com/manuals.html
to download the files.
Section 5: Maintenance and Troubleshooting
A. INTERPRETING THE PUBLISHER’S INDICATOR LIGHTS
The Power/Ink button can tell you what is happening inside
the Publisher. Please refer to the following:
Power/Ink Button Publisher
Fast Flashing The Publisher is initializing.You will see this
pattern when the Publisher is first turned on.
Wait until the lights stop blinking before
opening software or starting jobs.
Slow Flashing The cover is open and the ink cartridge carrier
is in change position. Insert a new cartridge
and close the cover. (The slow flashing light
can also indicate an out of media condition,
a robotic error or a picking problem. However,
these conditions are always paired with a error
message on screen.)
B. CLEANING THE PUBLISHER
NOTE: Do NOT attempt to oil or grease the Publisher's Robotic Arm shaft
or other components. You will likely cause more harm than good!
Any moving parts are designed to operate for the life of the machine
with no additional lubrication required.
Use a clean, lint-free rag with a small amount of ammonia
window cleaner to clean the Publisher's outside case and
trays. This type of cleaner is very effective on inks that may
accumulate on the printer tray. Stronger cleaning solutions are
NOT recommended because they may damage the paint and
plastic materials from which the parts are manufactured.
Always disconnect your Publisher's power cords before
cleaning. Resume operation only after the surfaces are
completely dry.
C. PERFORMING A ROBOTIC SELF-TEST
To ensure that everything is working properly, a Self-Test
feature is built in to your Publisher. In this mode, the Robotic
Disc Transporter will go through the motions of picking and
placing a disc to ensure proper working order. This test may be
performed without connecting the Publisher to the PC.
Perform the test by doing the following steps:
• Load some discs into the Input Bin.
• Open the cover.
• Press and hold the power button for five seconds. The test
will start.
• To stop the test, close the cover and press the power
button.
D. CLEANING THE INK CARTRIDGE
It may be necessary to clean the ink cartridge nozzles if you
notice reduced print quality, or if you suspect an cartridge nozzle
has become slightly dried out or clogged. If you are having
print quality problems, follow the steps below:
1. Remove the print cartridge.
2. Moisten a lint-free cloth with water.
3. Hold the cloth against the
nozzles for three seconds.
This will “wick” some
additional ink onto the damp
cloth.
4. Wipe in one direction only.
5. Repeat the process
E. TECHNICAL SUPPORT
If you have difficulties in operating your Publisher, the
procedures in this manual and the software User's Guide
should, in most cases, solve the problem. If you still have
difficulty, contact the technical support number listed on the
insert included in the supply pack that came with your
Publisher.
Source Location
Primera Knowledge Base www.primera.com/knowledgebase.html
PTPublisher Software Help files Open the software. Click on the ? icon in the
upper right corner of any screen.
SureThing Software Help files Open the software. Click on the Help
Menu - Contents
Email Support www.primera.com/contact_tech_support.cfm
Chat Support www.primera.com/knowledgebase.html
Phone Support 763-475-6669 (Mon - Fri 8 a.m. - 7 p.m. CST)
Nov 22, 2008 | Bravo Computers & Internet
I can,t print
this usually indicates there is a problem with the cartridge, check the bottom of each cartridge and see if the colour barcodes are intact and ensure you are not trying to start the machine with the lid up as too much light coming in will also cause the problem when reading the coloured barcodes on the bottom of each cartridge
Apr 16, 2008 | Primera Technology BRAVO AUTOPRINTER (Open...
Primera Technology LX400 Color Label Printer (P/N 74261) Logo
389 people viewed this question
Top Primera Technology Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Primera Technology Office Equipment and Supply Expert? Answer questions, earn points and help others
