Question about Marshall Amplification Marshall MG50DFX 50W Guitar Combo Amplifier
Ground noise buzzing noise
I get a static buzzing noise out both speakers. it stops if I hold the plug cable or master out cables? turntable wires are grounded. help!
If this is stopping when you grab a connector then you have a bad solder on the connector. a short or break in the wire or a ground is bad.
Apr 07, 2016 | Allen & Heath Xone-22 2 Channel Dj Mixer
My DigiTech RP355 turns on but only buzzes
Sounds like a classic ground-loop issue. Sound-on-Sound had a great article some time back that may help you.
Apr 10, 2014 | Music
Buzz coming from elec. guitar pickups only when using Aviom and headphones
It is a definite pickup grounding issue causing hum/"buzz" which diminishes when touching strings. Check the impedance of cable jack inputs and cable which should be 1/4"mono input/output jacks) . A personal preference but effective is to NOT run guitar direct into mixer but through an external amp w/ a headphone out jack . Noise gating/preamp filter also will help eliminate the "buzz"/noise from pickups. It is unfortunately the nature of the "electro-magnetic" beast when it comes to electric guitar pickups .Hope this helps.
Feb 23, 2014 | Aviom A16ii Personal Monitor Mixer 16...
I turn on the power and get just a buzzing noise. The keyboard does not work at all. The power light is on but no sound from the keyboard other than a buzzing sound.
normally a buzzing sound means a grounding problem, or a component has failed, unless you have the proper equipment to check these items,, your going to have to take it to a shop that does, sorry I know thats not what you wanted to hear,, but heres a hint, Ive found that a shop that deals in instruments and sound devices charges a lot, I have found a TV repair shop in my town, that can check my band equipment,, and its much cheaper, and I usually get the stuff back much quicker too
Sep 01, 2011 | Akai Music
Hi i have connected all the cables up correctly & have it all working except i have some sort of interferance coming through.i have a contant crackling & on & off buzzing sound,sound like...
First thing: Make sure ALL and I do mean ALL of your interconnected equipment is POWERED from the SAME receptacle. Powering different parts from different receptacles in a building will surely get ground bounce buzz and ALSO subject the equipment to hazards of circuit damage.
The audio connecting cables should be BALANCED lines where possible... either XLR or TRS cables. Problems like you are having are common when CONSUMER grade equipment is mixed with PROFESSIONAL equipment. Anyway, get all the stuff powered from the same receptacle and get back to me if you still have the problem. Note you may have to run three wire extension cords if devices are separated a bit... the pro's have to do that to avoid noise. All devices should have three wire (grounding) cords and/or grounding wires connecting chassis...
Jul 16, 2011 | Mixvibes U-Mix 44 4-in 4-out USB Audio...
Noise , sounds like ungrounded, all the cables are fine , the connection is grounded
so its a buzzing noise. are your turntables grounded? some dont have to be. the buzzing could be several things feedback from something around you or the mixer is buzzing cause of to much power. just mess around w stuff your not gonna break it. and what i mean about that is more wires check wires. dont preform open heart surgery on your equptment. sometimes the buzzing means the faders are going i own 3 vestax mixers and on my pmc 17a right before the faders went i had massive buzzing sound.
May 31, 2011 | Vestax Pmc 280 DJ Mixer
I get a buzzing noise when my thunderverb 200 is idling
turn on the ground lift and/or make sure the unit is properly grounded
May 27, 2011 | Orange Amps Orange Amplifiers Thunderverb...
Generates buzzing noise even when only cable is connected to it. No cable - no noise.
If you are saying that you are plugging a guitar cord into an input on an amp without the guitar on the other end and you are getting a hum or buzz with the volume turned up ; that is normal. If you are getting the same results with a guitar plugged in it means the ground wire to your output jack on your guitar is broken. Check your cord with a volt ohm meter for continuity on the tip on one end to the tip on the other end. Do this for the sleeve on one end to the other. If you were getting the buzz without a cable it would mean that your input jack in your amp has a broken ground connection. Hope this helps.
Jul 04, 2009 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Amplifier is buzzing when i plug in my les paul but ok with other
Several things to try:
- Probably already have, but another guitar cord.
- Ground switch on the amp?
- I had an older guitar that buzzed due to the pickups. While touching the strings, all was well - I was acting as the ground then. The ground wire broke, so it buzzed no matter what. The ground wire ran to the metal bridge.
- Play louder than the buzz! :)
Mar 23, 2009 | Epiphone Les Paul 100 Electric Guitar
Marshall Amplification Marshall MG50DFX 50W Guitar Combo Amplifier Logo
10 people viewed this question
Top Marshall Amplification Music Experts
Michial Gueffroy
Vito Vacirca Jr.
matt martin
matt martin
Are you a Marshall Amplification Music Expert? Answer questions, earn points and help others
