Question about HP DeskJet 845c Printer
When I first print a page of text, it comes out all faded--like when the cartridge is empty, even though I just had the cartridge refilled. When I print the same page again, the text becomes a little darker. Each time I re-print the page, it gets a little better. The machine is 9 years old. And it sometimes squeaks when the carriage goes back and forth when it is printing.
    Brigadier General:
  • 4,090 Answers
Ok two things here, the slides need wiping with a cloth, even use a small amount of sewing machine oil on cloth ( SMALL AMOUNT I SAID) then run the machine in cleaning mode and also check the print mode this is in the printer queue module under tools or maintenace.
Posted on Jun 20, 2009
Deskjet 1050A is not printing black. Help?
The black ink cartridge is cloged or empty. Try to refill it in case of empty, or clean in case of cloged ( left the printhead for 1 hour in clean solution or in hot water if you don't have )
All the best !
Jan 18, 2018 | HP Office Equipment & Supplies
Canon pixma mx882 won't print red
Regarding your Canon MX882 printer's poor print quality (lack of color printing performance from Canon 225 or 226 ink cartridges), it sounds like your PRINTHEAD is either clogged (from dried ink) or has reached it's END-OF-LIFE, to help determine which please perform the following steps (if you have already performed a step, please continue to the next step in the order shown):
Canon Cartridge Troubleshooting: http://inkjet411.com/?page_id=1537
1.Go into the printer's maintenance/tools menu and print a print quality test (i.e. heading cleaning, nozzle test or similar) to help identify which color (of number of colors) is impacted.
NOTE: To help determine which color has run out, use the following suggestions in sequence until you are able to identify the empty color: 1) Generate a Print Quality Test Page from your printer control panel; a faded color band indicates empty. 2) To distinguish between a black and photo black cartridge, print a text document and/or a photo. Faded black in a text document indicates the black cartridge is empty; faded black in a photo indicates the photo black cartridge is empty. 3) To distinguish between cyan, yellow, and magenta click here: http://inkjet411.com/?page_id=146 A faded or missing color band indicates empty.
2.At the printer's control panel under the 'Maintenance' or 'Tools' menu, activate a 'CLEANING' or 'HEAD CLEANING' to prime the ink system. Then Run the Inkjet411 'Ink Recovery Test Print' from our Test Prints page to verify all colors are firing properly (all printers also provide some form of a Self Test page): http://inkjet411.com/?page_id=146
    3.Check your user's manual to see if there are any procedures on cleaning the service station/capping station assembly (this is where the carriage/cartridges 'park' when not in use). A dirty service station can cause all kinds of improper color output problems (assuming the printhead is working correctly of course). NOTE: May not be applicable for your model depending on the printer design.
    4.The Ink Absorber, if applicable depending on print model, may also be full which could also cause printing related issues (typically an error code will be displayed when the ink absorber is full)...here is a customer/yahoo response on this particular issue: http://answers.yahoo.com/question/index?qid=20130523085451AAE1TqW
    5.Refer to our print quality support page to ensure other variables are not causing the issue such as printer driver settings or operating system device conflict, etc: http://inkjet411.com/?page_id=1432
      6.If this does not remedy the problem, then one or more of the ink ports may be dry within the PRINTHEAD assembly (the ink cartridges physically connect to this electronic assembly). We suggest you either remove the printhead and perform a hot water flush for 2 minutes (in a sink) or using an eye-dropper, or similar, drip 5-10 milliliters (i.e. 1-2 teaspoons) of distilled water into the respective color ink port to help saturate the foam. http://inkjet411.com/?page_id=2804
      7.Reinstall ink cartridges and retest.
      Inkjet411 Suggested PRINTHEAD Cleaning Procedures:
      Canon Printhead Warm-Water Flush Procedure: http://inkjet411.com/?page_id=2804
      Epson Printhead Cleaning (Flush) Procedure: http://inkjet411.com/?page_id=2836
      3rd party PRINTHEAD CLEANING solutions (for additional reference only):
      http://www.youtube.com/watch?v=FL8QaFVwsEs(Canon)
      http://www.youtube.com/watch?v=ZheZf-vdho8 (Canon Printhead removal / water flush)
        http://www.youtube.com/watch?v=3kKULRjqaLg (Epson #1)
        http://www.youtube.com/watch?v=i78Tu3RVO3s (Epson #2)
        8.If the problem persists, then you may have a damaged PRINTHEAD (worst case scenario), unrelated to the refilled cartridges. The printhead is a separate electronic assembly (which the cartridges are installed into) and is responsible for firing the ink drops onto the paper. Over time and based on usage this assembly will eventually fail (typically lasts ~4,000 to 5000 printed pages on avg). Refer to video on how the PRINTHEAD functions: http://inkjet411.com/?page_id=2054
        PRINHEAD TECHNICAL NOTES:
        IIT (individual ink tank-based) printer models have an electronic PRINTHEAD within the base of the carriage assembly (responsible for pulling ink from the 4, 5 or 6 ink cartridges and then firing the ink droplets onto the paper) - these will eventually fail depending on print usage type and printer duty cycle (i.e. rated for approximately 10,000 printed pages over life, but the consumer average is typically closer ~4,000-5,000 thruput pages). The printhead is replaceable and can be ordered directly from the manufacturer or www.Amazon.com . For information on how the PRINTHEAD functions, please watch the following video: http://inkjet411.com/?page_id=2054
        Typically the printhead should not reach it's end-of-life until after a minimum of 8 or more complete sets of cartridge changes. While some printheads may last 10,000+ pages others may only last 2000 pages, actual results will vary. The printhead will eventually fail in time due to an internal micro-electronics failure, due to the following leading factors: general customer print usage and printer care, printer duty cycle (i.e. # pages printed per month), printing frequency (i.e. time between each print job), print mode (i.e. draft vs. normal) and content printed (i.e. photos vs plain pages) and color mode (black and white only vs. color/greyscale printing).
        Paper types used (i.e. plain paper, photo papers & matte/heavy bond papers) and paper edge curl (i.e. duration in printer and/or exposure to low relative humidity) can also quickly lead to premature printhead failures due to physical 'head strikes' of the paper edges making repeated contact with the printhead nozzle plate surfaces.
        CAUTION: the use of compatible/clone cartridges (i.e. sold thru the internet from China) are known to be problematic and may cause printer errors and permanent PRINTHEAD damage. We do NOT suggest refilling these types of ink cartridges.....refilling of original/genuine ink cartridges is only suggested!
        Canon 225/226 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=t1QDEDRZapY
        Please advise if the above suggestions do not help remedy the current issue. For any additional questions please contact us directly: Inkjet411help@gmail.com
        -Thank you
Apr 02, 2014 | Canon MX882 All-In-One InkJet Printer
Canon printer mx882 not printing in black
Regarding your recent inquiry about the poor black print quality (Canon PG-225 PGBK ink cartridge) & lack of overall printing performance with your Canon MX882 printer, it sounds like your PRINTHEAD is either clogged (from dried ink) or has reached END-OF-LIFE, to help determine which please perform the following steps (if you have already performed a step, please continue to the next step in the order shown):
        For USA store ink refill locations and details on ink refill pricing:
        Costco USA Ink Refill Service (all 453+ stores): http://www.costcoinkjetrefill.com
        Fry's Electronics Ink Refill Service (all 34 stores): http://www.frys.com/ads/page51
        Micro Center Ink Refill Service: http://www.microcenter.com/site/content/refill-service.aspx
        Customers who have questions regarding the use of refilled ink cartridges can visit http://www.inkjet411.com or contact us directly at INKJET411HELP@GMAIL.COM
        -Thank you
Mar 20, 2014 | Canon PIXMA iP3000 InkJet Photo Printer
My printer is printing faded text
your ink at cartridge will empty, refill ink at your cartidge, or change with new cartidge
Jan 19, 2011 | HP Photosmart C5180 All-In-One InkJet...
I've got my toner refilled and it still unable to print
try shaking it
if you have a better print
then your toner is empty
if not maybe drum must change or
some parts of toner are missing
Jun 24, 2009 | HP LaserJet 1020 Printer
Dell 926 injection refill kit didnt work
The ink your purchased is likely a cheap watered down version of what your printer is meant to take. You may notice that the ink smears when you rub the page directly after printing. Why you chose to use the blue and red ink to make black blows my mind. These refill kits are insanely cheap and buying the black could not have been much more. Not using black ink in the black cartridge would explain why your print is faded. Also, there is no way to reset the ink levels on this type of cartridge. As long as the printer still prints, just ignore the ink level indicator and print until the ink runs dry. I recommend Cartridge World for ink refills because they use high quality ink to manufacturer specified volumes while still saving you money.
Feb 05, 2009 | Dell 926 All-In-One InkJet Printer
Text fades out in middle of page
throw the ******* thing out the window
Jul 29, 2008 | Dell A920 InkJet Printer
Printing degrades
I have 3 MP780s' and I have a similar problem. I'm guessing that you are printing majority heavily colored pictures. We found out the problem when we used refilled cartridges. We'd print 1-4 pages before we have a problem w/ 1 color not coming out. We would switch to OEM cartridges and the problem disappears. I'm guessing that you don't have this problem when you are printing text based items or doing slow printing. If so then that means by setting the print speed slower, there is a chance you will minimize the problem.(This is just an alternative.) If you have this problem w/ OEM or refilled cartridge, I suggest you to go to a pharmacy and get a small 10 syringe that has a screw-in lock for the needle. You won't need needles just the syringe. The diameter of the syringe should match the BCI-3e cartridges opening (except for the black). Put the syringe there and **** out some ink. Maybe 0.5-2 ml. Most likely you will get bubbles and I think this might be what is called a vapor lock. I've never seen this happen to OEM cartridges but I've seen them happen on refilled cartridges. But hey, maybe there's a first time. I'm assuming that your OEM cartridges are more than half full. Let me know if this helps.
Just to clarify, when you od the nozzle cleaning, do you do a print test after. From the print out you can see which color is clogged up. Work on that cartridge.
Jul 22, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Magicolor 2400W print fades on right side of page
Have you tried cleaning the leans at the bottom of the printer? Open the cover, pull out the drum. Under it is a long, narrow piece of glass. If it gets dusty or toner accumulates on it, it will cause streaks in the printing. If this is dirty, take a clean, soft cloth and very gently wipe it off.
May 12, 2008 | Konica Minolta magicolor 2400 Laser...
Fading cartridge problems
That printer is pretty old. Are you selecting "Best" quality when you print or is it possible that some documents are being printed in Quick Print mode (which puts less ink on the page)? If you're doing the same thing on each print job but the print quality changes, there's definitely a problem. If you're printing from web pages, the print quality may be a factor of the design of the pages. If you print two pages of a multi-page document and quality declines, you should be able to get help through Lexmark's technical support.
Apr 09, 2008 | Lexmark P6350 All-In-One InkJet Printer
HP DeskJet 845c Printer Logo
44 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
