Question about Toto Home
I have a power gravity 9y Toto anti siphon 528 valve the water runs stop 2 seconds continue about 5 times & stop. How do I open the cover? Do it have segments inside? Can I replace a cap? How do I open the cover on top?
  • 6 Answers
SOURCE: Toto toilet Power Gravity intermittently running
I suggest that you replace the cap with the new seal, it sounds as tho the valve is not shutting off and the bowl fill tube continues to run. Have you adjusted the water level to 3/4 of an inch below the overflow tube. If not, try that.
Posted on Mar 16, 2009
  • 659 Answers
Did you replace the flapper with a genuine Toto replacement flapper? If you didn't, they are slightly different. Toto toilets are fantastic but you do need to use OEM parts for repair.
Posted on Mar 19, 2009
  • 33 Answers
SOURCE: Gmax flushing system won't stop
WATER LEVEL IS NOT PROPERLY ADJUSTED. REDUCE WATER LEVEL TO FILL LINE
Posted on Jan 07, 2010
  • 299 Answers
SOURCE: I have a toto ultramax. the water keeps running
It is a little stiff but you won't break it. Just turn the cap counter clockwise (left) about an inch and it'll come right off. Put the replacement cap on by doing the reverse and it should be good to go. I have 7 of these toilets and they all needed cap replacements within 2 years. When you change it be sure to flush any sedimant out of the valve body as that's what usually causes the problem. Once you have the cap off hold a small pail or large cup upside down over the valve body and turn the water on for a few seconds. The cup will keep the water in the tank and the body will be cleared of sediment. After changing a couple and on the recommendation of the local Toto distributor I decided that it would better to just replace the whole valve with a FluidMaster unit (about $8 at Home Depot). The Fluidmaster units have been working fine for 6 years. It takes less than 20 minutes to replace the whole valve but is, of course, a bit more work than changing the cap.
Posted on Apr 18, 2010
SOURCE: My toto power gravity siphon
You have a problem with your flapper not seating all the way so the water is not filling in the tank to lift the ball **** to shut off the water first make sure the flapper is ok
Posted on Oct 26, 2010
My toto power gravity siphon won't stop running. Suggestions as to how to fix would be greatly appreciated. Cheer, Mark
Oct 24, 2010 | Toto Promenade, 1.6 GPF, Elongated...
I have a toto ultramax. the water keeps running in the tank, even when its over the level of spill valve. i've looked at various websites which say how to repair, but i've got the most basic question...
Apr 18, 2010 | Toto Promenade, 1.6 GPF, Elongated...
Water flow problem
2 things it could be. Bad flapper seating or back siphon.
1) visually check the flapper. Is it worn, cracked, or not fully seating because the chain might be too long and preventing a good seating?
2) IF the flapper is good without anything blocking it open there, then you have back siphon. Make sure the small hose that goes from the fill valve into the over flow tube has an high arch. If the arch is too low, after the water is cut off the gravity will back siphon water out of the tank.
Mar 19, 2010 | Home
Jan 07, 2010 | Toto Drake Tank W/GMAX RH COTTON WHITE...
Continous water running
just lower your float a little further. otherwise i'd adsume air is leaking out of your float. but if your float is up in the shut off position and water is still coming out. then you need a new assembly.
Sep 04, 2009 | Toto Washlet S400 for Power Gravity...
You need to either bend the arm that connects tot he float down (if it is the type with the ball float) or adjust the height of the fill valve assembly. THis accomplished by slightly twisting the valve assembly carefully and sliding down a half of an inch or so and then twisting back to lock it in place.
This should fix you up right.
Apr 29, 2009 | Toto Round Carusoe Two Piece Toilet, 1.6...
Mar 16, 2009 | Toto Promenade, 1.6 GPF, Elongated...
Mar 13, 2009 | Toto Washlet S400 for Power Gravity...
Home Logo
46 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
