Question about Royal VF1012mx Shredder
Omnitec shredder will not turn off automatic - Royal VF1012mx Shredder
How do I fix the rollers that won't turn when paper is inserted in shredder?
That shredder is as weak as they come - it is probably a broken plastic part inside the mechanism. Recommend you throw it away and get the Amazon Basics shredder, your experience will be much better. Sorry.
Jan 16, 2015 | Royal Office Equipment & Supplies
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
Can you take apart a fellowes PS-12C
FELLOWES SHREDDER
May 23, 2014 | Fellowes Office Equipment & Supplies
Runs reverse auto
From your manual!
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the waste basket; insert waste basket and repeat jam clearing procedure.
Feb 01, 2014 | Fellowes DM12C Shredder
Royal shredder
It may be that the sensors are dirty - use a cotton bud dipped in rubbing alcohol to clean the sensor light(s) and heads
Jan 27, 2014 | Royal 160MX Shredder
Staples SPL-X21G shredder won't turn off
Blow canned air down into the feed slot.
Sep 22, 2009 | Office Equipment & Supplies
Shredder model SPL TMC 16 A will not turn off automatically
my brother took the shredder apart and found out that when you oil, the oil goes between the lens so it thinks something is there when not, he had to take it apart and clean the lens which would void warranty. its also possible that the oil on the lens collects dust and also blocks the infared eye
Jun 30, 2009 | Fellowes DM15C Shredder
My shredder will not turn on. Is there a reset switch?
There are a couple of reason why A shredder will not turn on.
There is a safety switch that makes sure the shredder is attached to the base. Make sure this makes contact and nothing is keeping the switch from closing.
There is an overheat cutout switch attached to the motor. This should automatically reset after the motor cools off after overheating.
If not then the last thing to check is the fuse.
Jun 21, 2009 | Fellowes DM15C Shredder
My Royal VF700 shredder will not turn off
Try giving the EYES in the middle where you insert the paper a clean...if that dosnt work you may have lost the pcb inside ...give Royal a call at 1-800-524-0799 for parts assistance.
Feb 24, 2009 | Royal VF700 Cross-Cut Shredder
Royal VF1012mx Shredder Logo
56 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
