Home | Canon | PIXMA MP150 All-In-One InkJet Printer | Cant print the ink abs...
Canon PIXMA MP150 All-In-One InkJet Printer
Problem for Canon PIXMA MP150 All-In-One InkJet Printer
Cant print the ink absorber if full
By jackiej_guev on Jun 20, 2009
my cannon mp145 had a problem. after i refill the ink tube and i start to deep cleaning that i usually do i cant print anymore. theres a comment that the ink absorber is full. now what shall i do? i already turn off then tern it on but still i cant print
Comments:
Jun 20, 2009
- once again i got another problem. after the e8 and been ok, now its e2 and e7. whats the meaning of that code and how to fix it? thanks and hope you could reply atonce.
Jun 21, 2009
- its doesnt work! still the e2 and e7 keep blingking and theres no light at the black and color ink. i alresdy arrange the cartridge but still thesame
Jun 21, 2009
- i already do your advise but the code e2 and e7 always blink. is it possible if i open and clean the whole printer to remove all the split ink inside the body of my printer? can i ask if you can send me a diagram of my printer before i start open it?
Jun 22, 2009
- hi there. i already do your advise, but still i doesnt work. its still blink the e2 and e7. the alarm blinks too but the black ink and color ink stop blinking. whats the next step? can i request a diagram of this model? i want to open it and clean the spill of ink inside but im affraid to open without a diagram. is there a waste ink tray that i can remove to clean? thanks and waiting for your reply
Best Solution
posted on Jun 20, 2009
Helpful)
nettiser
Rank: Wiz  Canon Expert
Rating: 84%, 1350 votes
change the absorber pad
Comments:
Jun 21, 2009
- Jacjiel
Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 – Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error – USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
I have not encountered an E7 but check the seating of all your cartridges
Jun 21, 2009
- hope that is helpful to you
Jun 21, 2009
- Sorry, I do not have a diagram of your printer But try logging on to the tech support of the manufacturer.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Canon PIXMA MP150 All-In-One
Questions and Unsolved Problems for Canon PIXMA MP150 All-In-One
Do you recommend Canon PIXMA MP150 All-In-One InkJet Printer?
Answer
Answer
I have had an orange warning light so after checking paper levels etc I gave in and bought some new... (More)
Answer
My Canon Pixma MP190 scanning facility does not seem to work on Windows Vista - it seems to scan... (More)
Answer
i have a new computer with windows 7 and i can't install the driver of my printer canon pixma... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon PIXMA MP150 All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 1506
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
