Question about Minolta magicolor 2350 Laser Printer
HP 8600 Duplexer-how to install - Minolta magicolor 2350 Laser Printer
  • Minolta Master
  • 6,161 Answers
I am sure the HP web site can provide down loaded instructions to do that
Posted on Feb 20, 2015
I have a hp laserjet 4240n and we installed the duplexer. But it gives error 49.2 F05 and also a jam error 13.12. Does anyone know the solution?
49.2c05 is a communication error. the 13.12 is a jam error. try upgrading the firmware with the duplexer not installed. firmware can be found at www.hp.com
Nov 21, 2016 | HP Office Equipment & Supplies
How do I delete eprint?
Usually for HP printers not being recognized because they loose their IP address on the network or the computer can't see it.
What you can do is completley uninstall the HP software for the Officejet 8600, then go to HP.com lookup the officejet 8600 under Support > Download Drivers. download the latest full installation then run the install. When it ask you how to install it do the custom install and then only select the things you want to install.
When it ask you to do the eprint set up you can skip that part. also once install try running the HP updates for find any Network fixes or and Firmware updates.
HP Officejet Pro 8600 All in One Printer N911a Software and Drivers
Aug 06, 2015 | HP CM749A - Officejet Pro 8600...
How can I disable 678 HP cartridge protection?
Aug 06, 2015 | HP Office Equipment & Supplies
Set up scanning on hp officejet pro 8600
Did you install the drivers and the software that came with the unit. If you need to get them they are here:
http://support.hp.com/us-en/product/HP-Officejet-Pro-8600-e-All-in-One-Printer-series---N9/4322914/model/4323658/drivers/
Feb 17, 2015 | HP Office Equipment & Supplies
JAM IN DUPLEXER CONSTANT ON DUPLEX JOBS FINE OTHERWISE.I HAVE REPLACED DUPLEXER,ENGINE POWER BOARD,DCE CONTROLER,REVERSING ASSEMBLY,FUSER UNIT. ANY IDEAS.
You've done everything I would have done and more.
How about you installing a DOA duplexer. At this point I would change it again. Is there another printer that you can swap duplexers with?
There is a paper path sensor test (letter H) and manual sensor test . I don't know if the Component test checks the duplexer, but you should be able to find out.
Is the printer still under warranty? Can you call HP or are you an HP tech and you can call 2nd level support.
Just a thought....when you run a Config sheet, does it show the duplexer?
May 18, 2011 | HP LaserJet M4345 MultiFunction Printer
Error code 57.70 on HP 9500 color printer
What is the code? This unit does not have a fan in the duplexer nor for the duplexer. The 9500 has a fan housing but there was never a fan put in by the design team. Give the code and I look it up to see the problem.
Apr 28, 2010 | HP LaserJet 9500n Printer
Duplexer
If you really have an HP 4350dtn (d = duplexer), then the duplexer is not connected correctly. Look at the back of the printer for the duplexer. It prtrudes from the back drop down tray and is used to print on both sides. I would pull it out and push it back in to make sure all connections are tight.
Tray number 1 is the manual feed tray in the front of the unit.
Mar 03, 2008 | HP LaserJet 4350dtn Printer
5652 and Vista - duplex print not working
In Vista the default s the duplexer is "not installed". Go to Start, Settings, Control Panel, Printers, double-click on the Deskjet, Printers, Properties, Device Settings and set the duplexer to "Installed".
If the duplexer prints the back side upside down in Vista once it is enabled you can get a patch as described here.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Feb 19, 2008 | HP DeskJet 5652 InkJet Printer
Duplexer
duplexing has to do with sending and receiving data at the same time. there is also half duplex mode: is where the device can send and receive but not at the same time. try going to start, control panel, printer faxes, find your printer , right click and enter printing prefrences.there may be a tab that says finishing. click this tab and make sure you checkmark print on both sides.
please let me know the outcome if that doesnt fix it i will check into that printer a little more. just another note vista is alittle quircky still so make sure the drivers are updated and vista is updated.
Feb 17, 2008 | HP PSC 2410 All-In-One InkJet Printer
Duplexer problem
First, the machine always prints the first page first. Make sure you have the right driver (4 plus and not 4)and check the settings in the device settings of your printer driver on the pc. Also make sure the duplex unit is for the 4 plus and not the 4.
May 17, 2007 | HP LaserJet 4 plus Printer
Minolta magicolor 2350 Laser Printer Logo
18 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
