Question about Husqvarna Garden
Chainsaw will not start
Has spark, but wont fire, even with starting either
WeListen2You
  • 538 Answers
SOURCE: 40 CC WILD THING POULAN
maybe the thermal sensor in the engine is overheated..it is inthere to keep the engine from frying.
Posted on Oct 23, 2008
  • 2692 Answers
SOURCE: 0340 AV stihl chainsaw won't fire
Spray a little starter fluid down the carburator . It is starts then is is a fuel problem. Most likely a gummed up carburator. Remove and clean .
Posted on Jan 24, 2009
Tinkertown
  • 16 Answers
SOURCE: wont start with new plug. I can smell gas, but none on plug
Check the start stop switch, sometimes they can get dirty causing the saw not to get spark. Also maybe check Your air cleaner. if it's clogged it may be flooding itself out?
Posted on Feb 16, 2009
  • 226 Answers
SOURCE: Craftsman Chainsaw will not start
It's your ignition, which you can take that stuff apart on the left hand side of the saw under the recoil. I have 2 of these, & you can get the parts. Maybe its just the magneto gap adjustment, which is like a business card or newspaper width gap. I would check that first. Hope this helps you, Rick
Posted on Apr 29, 2009
  • 15 Answers
SOURCE: poulan wood shark 1950 wont start spark plug has
Try to squirt a little gas in the carb and see if it pops or tries to run for a short time. The diaphram in the carb is probably old and hard. That would be the first place I would look.
Posted on Nov 08, 2009
Won't start can't even get it to fire got spark getting gas ,don't know.
Check the compression! It has to be around 120 and no less then 100 to fire off. If it is ok, Have your carb checked out. It should fire off with some spray.
Feb 10, 2013 | Poulan Garden
Mini mac 35 no spark how to test
hello. well thank you for taking care of the problem,,
Feb 18, 2012 | Garden
Husqvarna 14" chainsaw wont start. put new plug
Try a new spark plug.If still does not fire you have a bad ignition coil.
Nov 26, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
455 wont run
Make sure the muffler has not become plugged. Check the flywheel key as it may have sheared off for some reason causing the timing to be off, yet still generate sparks. Are the sparks blue and snappy? If not, check the ignition module gap to the flywheel magnets--use a thin business card for a gauge. A wide gap can cause weak spark. Hope this gets you running again!
Apr 30, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
New Ryobi petrol c/saw wont start.
If it is brand new, sounds like you should return it for the retailer to have repaired.
Dec 05, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Poulan wood shark 1950 wont start spark plug has
Nov 07, 2009 | Garden
My husqvarna 50rancher chainsaw wont start
Check your fuel make sure it is new fuel. Check to make sure that you have spark. Even replace the plug, for the price of 3dollars it is not a bad deal. If those do not work then you are going to have to check your flywheel and your armatur those are the items that would prevent you from firing since Huska makes a excellent carb you do not need to mess with it at all. Thank you for choosing FIXYA.COM please rate
Feb 14, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Wont start with new plug. I can smell gas, but none on plug
Jan 26, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
14 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
