Question about HP Officejet 7210 All-In-One InkJet Printer
How do I find cartridge levels for my HP printer??
Hp officejet 4620 does not print with starter cartridge
If printer is in warranty, demand for replacement.
1. Check ink levels in printer..if levels are showing, take out all ink cartridges refill them.
If levels are zero, go for new cartridges.
2. If ink level are showing in printer & physically cartridges having ink, then problem with print head, try to clean the clogged nozzles.
Nov 16, 2014 | HP Officejet 4620 e-All-in-One Printer,...
I want to check ink levels. It is blurring the color when printing
Checking the ink levels A message will appear on the front panel display when the ink level for the print cartridge is low. The ink levels can also be checked through the HP Director on the computer.Checking the ink levels on a Windows computer
  1. From the HP Director , click Settings , Print Settings , and then click Printer Toolbox .
  2. Click the Estimated Ink Levels tab. The estimated ink levels appear for the print cartridges.
Checking the ink levels on a Macintosh computer
  1. From the HP Director , click Settings , then click Maintain Printer .
  2. If the Select Printer dialog box opens, select the HP PSC, and then click Utilities .
  3. From the list, select Ink Level . The estimated ink levels appear for the print cartridges.
Jun 21, 2011 | HP LaserJet CP1518 Printer
I have a hp psc 1310 series printer and i can not find the site to check the ink levels. The book says to use the hp director on page 28.
Checking the ink levels A message will appear on the front panel display when the ink level for the print cartridge is low. The ink levels can also be checked through the HP Director on the computer. Checking the ink levels on a Windows computer
Oct 05, 2010 | Office Equipment & Supplies
How to reset the ink level of my hp officejet 6500
Checking ink levelsUse one of the following methods to check the ink levels. Method one: Check the ink levels from the HP All-in-One The ink level is displayed on the main screen of the control panel display. Locate the two icons that represent the print cartridges. The icon on the left is for the color cartridge and the icon on the right is for the black cartridge.
  • The exclamation mark (! ) symbol indicates a low ink level.
  • The question mark (? ) symbol indicates the product cannot determine the status of the print cartridge. This might be because the cartridge is refilled.
Figure 1: Ink levels on the control panel displayc01362755.gif 1 - Exclamation mark indicates low ink in the color cartridge 2 - Ink level in the black cartridge is OK Method two: Check the ink levels from the computer using the HP ToolboxFollow these steps to check the estimated ink levels using HP Toolbox.
  1. Make sure the product is on and connected to the computer.
  2. Open HP Solution Center .
    • Windows XP: On the Windows taskbar, click Start , click All Programs , point to HP , and then click HP Solution Center .
    • Windows Vista: On the Windows taskbar, click the Windows icon (c01364735.gif ), click All Programs , click HP , and then click HP Solution Center .
    • Windows 2000: On the Windows taskbar, click Start , click Programs , point to HP , and then click HP Solution Center .
  3. Click Settings .
  4. Point to Print Settings , and then click Printer Toolbox . Printer Toolbox opens.
  5. Check the ink levels displayed on the Estimated Ink Levels tab.
Figure 2: Estimated ink levelsc00670267.gif
Jun 02, 2010 | HP Officejet 6500 Wireless All-in-One...
How do you check the ink levels of the cartridges on a hp deskjet 940c
If the ink level is low in a print cartridge, the Print Cartridge Status light stops flashing when the printer’s top cover is opened. When you open the panel the ink cartridges slide to the center , as far as checking the ink level find and right click on the printer icon, click properties, and find ink cartridges and ink levels.
Thanks
Shereena.
Apr 22, 2010 | HP DeskJet 940c InkJet Printer
How to reset ink levels from HP J4580 printer refilled 901 wont show ink level comes up as empty
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Jan 10, 2010 | HP OfficeJet J4580 All-In-One Laser...
How do I check ink levels on my HP deskjet D4160 printer?
Here is what I found on the Web. You can click on the link below, to see Full Instructions. If you find this helpful, pls rate me.
http://h10032.www1.hp.com/ctg/Manual/c00687555.pdf
View estimated ink levels
Follow these instructions to view the estimated ink levels of the print cartridges that are installed in the printer:
1. Open the printer Toolbox.
2. Click the Estimated Ink Level tab.
Note If the print cartridges were used before being installed in the printer, the
estimated ink levels will not appear on the Estimated Ink Level tab.
The Estimated Ink Level tab also contains print cartridge ordering information. To view
this information, click the Print Cartridge Information button.
Thanks and good luck.......
Pls rate me
Jan 01, 2010 | HP Deskjet D4160 InkJet Photo Printer
F4280 printer and hp 60 cartridge
keep the cartidge in Hot Water for 30 minutes. maybe it works.
May 30, 2009 | HP DeskJet F4280 All In One Printer InkJet
Ink level didn't change
s.gif Deskjet 5100 series
  1. Click Start or c01319360.gif , click All Programs , click Hewlett-Packard , and then click Printer Assistant .
  2. Click Utilities .
  3. Click View ink levels .
    • If a cartridge is low on ink, discontinue these steps, replace the cartridge, and then try printing again.
    • If the cartridges contain a sufficient amount of ink, continue to the next step.
  4. Click Printer Maintenance .
  5. Click Clean Cartridges .
  6. Follow the on-screen instructions.
ISSUE: After installing a new HP Inkjet print cartridge, the ink level indicator remains at the previous level. SOLUTION: Continue to print and ignore the ink level indicator. The print cartridge is full of ink, it just is not being measured accurately.
May 29, 2009 | HP Photosmart D5160 InkJet Printer
Ink
Normally when you install the print software you install HP Director or solution centre software that has a estimated ink staus monitor..from user manual
Check the estimated ink levels You can easily check the ink supply level to determine how soon you might need to replace a print cartridge. The ink supply level shows an estimate of the amount of ink remaining in the print cartridges. Tip You can also print a self-test report to see if your print cartridges might need to be replaced. For more information, see Print a self-test report. To check the ink levels from the HP Director (Windows) 1. In the HP Director (or HP Solution Center), click Settings, point to Print Settings, and then click Printer Toolbox. Note You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab, and then click Service this device. 2. Click the Estimated Ink Level tab. The estimated ink levels for the print cartridges appear. To check the ink levels from the HP Image Zone software (Mac) 1. In the HP Director (OS 9) or HP Image Zone (OS X), choose Settings, and then choose Maintain Printer. 2. If the Select Printer dialog box appears, select your HP All-in-One, and then click Utilities. 3. From the pop-up menu, choose Ink Level. The estimated ink levels for the print cartridges appear.
Print a self-test report If you are experiencing problems with printing, print a self-test report before you replace the print cartridges. This report provides useful information on several aspects of your device, including your print cartridges.
Load letter, A4, or legal unused plain white paper into the paper tray.
Press and hold the Cancel / Resume button and then press the Start Copy Color button
The HP All-in-One prints a self-test report, which might indicate the source of the printing problem.
Jan 12, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP Officejet 7210 All-In-One InkJet Printer Logo
15 people viewed this question
Seeker5211
Seeker5211
