Question about Sterilite ® 10828004 5.2 Gallon Touch-Top Wastebasket, White 4 Pack
Lids springs replacing springs
Why wont lid on my phillips senseo hd7863 close when the pod is in the holder ?
Maybe you inserted the pod with the wrong side up or you used a 2-cup pod in a single cup holder. If the clamping spring isn't working (the lid feels loose when you try to close it), that spring (that is nothing more than a straight piece of metal wire) needs to be replaced.
Jun 07, 2014 | Philips Senseo HD-7810 Coffee Maker
How to remove old trunk lid shocks on the LS 430
At each end of the gas spring lift cylinder there is a spring steel "U" shaped clip, pry it off and the shock comes right off the ball socket.
Sep 20, 2012 | 2001 Lexus LS 430
How do I get the lid off a sears laundry center. Does it slide out after the lid has been popped? This unit has the dryer on top. I have to repair the lid switch
Your shouldn't have to remove the lid all the way. You should be able to replace the switch by just propping it up after it's out of the spring clips.
Mar 26, 2011 | Kenmore Washing Machines
How do you install the spring on the lid assembly replacement parts for a dishwasher so the lid will spring open after the pre-wash cycle?
Insert one end of spring in one hole, after putting it around the cover hinge, then put the other end in the other hole, and press it in until it snap locks into place. Besure you refer to owners manual. If you have it.
Jan 06, 2010 | Whirlpool Dishwashers
Deep fryer
If the lid will not stay open, there should be a small spring in the hinge. I am not sure of your model, But some have a safety interlock that will not allow operation with the lid open. These usually have a feature of raising and lowering the basket with the lid closed like some chemistry experiment!
What's wrong with a manual wire basket?
If the spring is not fitted correctly, or missing, it's fiddly but not impossible to replace.
Oct 28, 2008 | Kitchen Appliances - Others
Hamilton Beach 80355 Custom Grinder: Lid Cracked
The replacement lid can be found at:
http://www.forumappliances.com/i-656-Hamilton_Beach__cover_lid_.html
Feb 02, 2008 | Hamilton Beach 80355 Custom Grind Coffee...
Sterilite ® 10828004 5.2 Gallon Touch-Top Wastebasket, White 4 Pack Logo
213 people viewed this question
Top Sterilite ® Home Experts
Donni Steen
Tom Chichester
Are you a Sterilite ® Home Expert? Answer questions, earn points and help others
