Question about Scotsman Prodigy Air Cooled Cuber C0330SA 1A
Parts/? needed water solenoid parts please
Can someone please tell me what the white barrel shaped plastic thing with the clear casing is (between the blues)? It's leaking, it spills over the top of the metal.
white clip is cold water solenoid,blue clip is warm water solenoids,red clip is hot water solenoid,they are all the same part number
May 19, 2015 | Washing Machines
Ice dispenser solenoid just started clicking
You need to replace both the solenoid for the ice maker and the water dispenser. Easy job, less than 1 hour. Parts should be under $50. Facing the back of the refrigerator the solenoids are located on the lower right behind the hardboard cover where the water comes.
The he replacement parts are a little different than what you have, and much easier to work with. Just cut the water lines close to the old solenoids (you don't have much extra to play with). You'll just push the water lines into the new solenoid valves.
Make sure the water is off and the refrigerator is unplugged.
Feb 04, 2014 | Electrolux Refrigerators
Water dispenser not working
Jan 24, 2014 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Water and ice dispenser will not shut off
The the replacement parts are a little different than what you have, and much easier to work with. Just cut the water lines close to the old solenoids (you don't have much extra to play with). You'll just push the water lines into the new solenoid valves.
Dec 23, 2013 | Electrolux EW23CS70IS Side by Side...
Water line not working
The door switch controls a solenoid valve. I don't know exactly where it is. The solenoid valve is bad, or the switch is bad. If it works intermittently, it is more likely the switch - usually. However, if you are hearing a buzz, I would think that would be the solenoid valve buzzing, indicating a problem with the mechanical valve part of the solenoid valve. Likely, it needs to be removed, taken apart and cleaned.
If this has been helpful, please take a sec to rate me. Thanks!
Don
Mar 04, 2012 | Garden
The washer work fine but not getting any water i have water pressure
The quick solution may be to check the small filter screen at the hose connection to the faucet. It may be clogged so the water cannot flow through to the washing machine.
A more complicated problem would be if the solenoid within the machine is not opening to allow water to flow into the machine. You could check to see if voltage is getting to the solenoid during the fill part of the cycle. If it is then the solenoid is bad. If no voltage then the control board or the part controlling the solenoid is bad. In either case you would need to get inside the machine to replace the bad part.
Jul 29, 2011 | Whirlpool Washing Machines
Kenmore refrigerator side by side model 25358682890 cold water dispenser does not work. ice maker works.
Your fridge has a dual solenoid water valve - one side controls the water flow to the dispenser, the other to the ice maker. It's possible that one side burned out while the other is still good.
Here's a photo of what it looks like:
Here's a link to the replacement part:
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Refrigerator-Parts/218658000/0046/253/Model-25358682890/0582/0165000?keySuffixId=NA&productTypeId=x&searchModelNumber=25358682890&subCompDesc=Icemaker&brandDesc=KENMORE&modelDesc=Side-by-Side&blt=11
Before replacing the part, make sure the solenoid is in fact, bad. Get a voltmeter, and touch the probes to the electrical contacts on the solenoid, like so:
If the meter barely moves, the solenoid is bad.
If both solenoids test out OK, the other possibility is that the water supply line is kinked or clogged. Also, if your water dispenser has a filter (also on the back of the fridge), it might be clogged. My money's on the solenoid, though.
Good luck, and if this helps, please my answer!
Also, thanks to Zenzoidman for the pics.
Jan 31, 2011 | Kenmore Side by Side Refrigerator
How do you locate cold water relay
There is no cold water relay. There is a water inlet valve with a cold water solenoid on it, though. If you have no cold water, any of the following could be a cause:
1. Clogged sediment screen on the cold water inlet. You will need to shut off the water and remove the fill hose from the back of the washer and check the inlet screen on the cold water inlet on the back of the washer. Clean if necesssary. NOTE: This can be a common problem if you have hard water or use well water. Cleaning with a 50/50 solution of distilled vinegar and water using cotton swabs can dissolve most accumulations of rust and sediment.
2. Poor electrical connection on the cold water solenoid on the inlet valve. Locate the electrical connection for the cold water solenoid (usually color coded BLUE for cold water, RED for hot water) and unplug. Check the electrical contacts for any signs of corrosion. Clean the contacts if necessary.
3. Bad cold water solenoid. With the electrical connection removed and the washer unplugged, take a resistance reading on the solenoid contacts. They should read something around 600-800 ohms if good. If bad, you will need to replace the water inlet valve.
4. Kinked or clogged fill hose.
NOTE: Make sure you UNPLUG the washer before servicing.
If you determine the water inlet valve to be defective, the following link explains how to access and/or replace:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
The part number for the inlet valve is 285805 and can be purchased at any of the following websites:
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
Prices will vary between these sites, so shop all of them for the best price.
If you need a diagram to assist you, the first three websites mentioned usually have excellent exploded view illustrations that accompany their parts lists. You can use these as a helpful reference. The water inlet valve is listed as item 18 under the "Control and Rear Panel Parts" heading.
If you have any questions, please let me know. I hope this helps you.
NOTE: Roper is manufactured by Whirlpool, and use Whirlpool parts, so these instructions will apply.
Oct 08, 2009 | Roper RAB5232E
Warm water out when cold only button pressed. need part # for water solenoid
u can call any maytag store they can look up part but u can use the universal valve part no is 205613
Apr 16, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Hot water solenoid not energising i.e. no hot fill.
check the water setting.
it could be set to cold and not warm or hot that is why it is not energizing the hot water solenoid.
tnx 4 using fixya.
drcool
check also temperature setting of water. if it is set to cold, then hot water will not be energized. or it could be the defective part.
tnx again,
drcool
Sep 26, 2008 | Indesit W 123 Front Load Washer
Scotsman Prodigy Air Cooled Cuber C0330SA 1A Logo
27 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
