Question about Epson Stylus C63 InkJet Printer
Blank paper after printing replaced with new Epson cartridges
Did head clean? and followed replacement instructions still wont print a thing!
  • 71 Answers
You might need to replace the printer head.
Posted on Jun 20, 2009
My Epson wf2560 will not print anything it is brand new and it sounds like it is printing but the paper comes out blank
usually it is caused if your ink cartridge is dried up.
( Ink Cartridge if not used will dry even if it is full)
or print head need clean, some printers application could have the function to clean up.
if you buy it new replace it. or contact them
Mar 02, 2018 | Epson Office Equipment & Supplies
Printer won't print. It pulls the paper in and appears to print but then the paper comes out blank. I changed the ink cartridge and same thing--no ink appears and the paper comes out blank.
Hi amy, what is the model of your printer? If your printer is Canon or HP, I can conclude that the problem was your printer's chip detector or something related to that part of the printer that reads your cartridges.
But if your printer was Epson, the ink cartridge is not the problem, the problem is with your printer head. Printer head of Epson differs from canon and HP which are attached to their own cartridges. If your printer head got clogged, then it would never print, it needs to be clean.
Epson has a built in printer head inside your printer, that means if you will change the cartridge with a new one, it doesn't help at all unless you will get your printer in a cleaning mode. If the cleaning doesn't help you can bring your printer to the nearest printer technician.
Dec 17, 2009 | Canon PIXMA mini260 InkJet Photo Printer
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
Epson r390 printer prints blank(no text on paper)
Check condition of head first. Move head to parking position (head cleaning position). From outlet pipe of head cleaning mechanics, do suction. It's there is ink, the head is not clog (and the flow of ink is ok). Make nozzle check. If nothing lines appear, the problem is in board (cause you just reset). Using resetter, do initial setting. Good luck.
May 31, 2009 | Epson Stylus Photo R390 InkJet Printer
I replaced both ink cartridges for the printer, won' print.
Please follow the procedure your printer has which forces it printer to clean the print heads.
I have experience of other epson stylus models.  I have previously spoken to epson about this exact problem.  Repeating the head cleaning process a minimum 5 times cleared the problem.
Running head clean multiple times in succession builds up pressure in the print heads - causing (usually new) cartridges to work correctly.
kind regards
Jan 27, 2009 | Epson Stylus 880 InkJet Color Printer
Printer will not print ,paper comes out blank
Put new in cartridges in printer.
Page prints out blank.
Have cleaned the print heads 3 times.
Need help!
Nov 16, 2008 | Epson Stylus C66 Inkjet Printer
Communicates with XP-PC, makes all the moves and sounds- nothing prints
Hi, Hope this helps
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/hzMF5dB-ZMc&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/hzMF5dB-ZMc&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
Oct 11, 2008 | Epson Stylus CX5800F All-In-One InkJet...
Cx6600 printer problem
if you left your printer for two weeks or more without using, the print heads may be stuffiness. In this case (aparently yours cases) you must take your printer to a authorized service, they will can clean (with a proper fluid) or replace the ink heads, if cleaning is not possible.
Mar 16, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Will not print
Unfortunately, if you have replaced the cartridges and tried many cleaning cycles, then there is no solution other than replacing the unit. A good replacement would be the C88+
Mar 18, 2007 | Epson C64 InkJet Printer
Epson Stylus C63 InkJet Printer Logo
159 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
