Question about Tunturi C80 Elliptical Cross Trainer
Display lights up but won't register resistance or time etc.
No resistance, time etc. display only showing 000's
I cannot set the time and date on my cash register when I turn key PGM it shows "ae 01" and no 000 what do I do?
Error 01 means that a previous activity has not been completed. Here is a link to the manual: http://totalpos.co.nz/wp-content/uploads/2012/10/Casio-TE2400-Operator.pdf
May 10, 2015 | Casio TE-2400 Electronic Cash Register
My HD SAMSUNG HM500JI not work any more bad sector that cany be fix...!!!
Well.. I'm SAD to inform you..your drive has encountered a serious error.
There's a couple of options..none of which you will like.
Drives (SMART) report errors, but sadly don't fix anything. Once a bad-sector has been encountered, its usually an indication of major failure (google/39% of all drives w/bad sectors major failure..etc)
Your options.. Is your data super important--if so, STOP using the drive, send it to a DRC (Data recovery Center), expect to spend $600-1k for the data.
If you've backedup, good news-- drives are cheap.. buy another, plus your drive into tthe 2nd slot, copy off what you can..
the drive itself is having a major failure (meaning it cannot relocate the bad sectors any longer, hence the smart failure)-- meaning-- drives "TRY" to relocate (when they detect failures, they'll move the data else where, mark the bad area, and use a new spot)... Your drive has probably done that.. ALOT. And now... it's gone critical.
BEST solution for you, to save $$ and time.. but a drive ($80-150 bucks)... install your os... put the other drive on the other cable, copy off what you can..and call it a day.
A DRC won't do much more to be honest... if its SUPER critical, contact www.deepspar.com and see if they will recommend you to a DRC locally to you, or do it them selves...again $$$
Oct 16, 2012 | Samsung HM500JI 500 GB SATA Hard Drive
Engine light just came on
Cycle the key from off to run three times & leave it in the run position. the Check engine will start to flash. the sequence will tell you the code. for instance 000 0000 00000 000 0000 00000 000 0000 00000 0000 00 00000 0000 00 00000 0000 00 00000 000 0000 00000 ... would show you code #345 three times then code #425 three times then starts over again with the first code if there are only two codes
Jan 15, 2011 | Chrysler Town & Country Cars & Trucks
How do I change the time on my Panasonic KXDT343?
1. From extension 101, press the PROGRAM key.
2. Then, using the number pad, dial *#1234 (Display shows SYS-PRG #).
3. Using the number pad 000.(Display: 000 DATE / TIME)
4. Press the SP-PHONE key (Display example:'93 Jan. 1 FRI).
5. Press the SP-PHONE key again (Display example: 12:00 PM 24).
6. Enter the new hour using the number pad.
7. If you need to adjust the minutes press the FWD/DND key.
8. Enter the new minutes using the number pad.
9. If you need to adjust the AM/PM press the FWD/DND key.
10. Press the AUTO ANSWER/MUTE key to select AM or PM.
11. When finished entering the new time press the AUTO DIAL/STORE key.
12. Press the HOLD key.
13. Press the PROGRAM key to exit programming.
Jan 11, 2011 | Panasonic KXDT343 Phone
Lowrance HDS 10 Sonic Hub (000-10141-001) isn't working. Followed instructions. Suppose to be easy installation. It just won't register
cant seem to get the power light working on the sonic hub. red to power, yellow to power, black earth etc...diagrams looks simple? however no joy
Sep 24, 2010 | Lowrance GPS
Error ##334 show up on display. what is it meant exectly ?
1. Press the "menu": Key
2. Press "Copy" Key
3. Press "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading or select (-) as a short-
cut to the last setting.
4a. Press “Set” and the display shows:
Test Mode [1] – [8]
CF-FH3 :WLD-11-02
4b. Press “8” and the display changes to:
Test Mode [1] – [8]
Please wait
***note*** you have to wait until the display changes
Then the display changes to:
8: PRINTER TEST
[2]---[8]
5. Then Press the "3" button and the display shows:
8 – 3 : EEPROM Clear
*** the display scrolls to [0] : INK COUNT
[1] : 2PURGE FLAG
6. Press "0" button – for INK COUNT
7. Press the "Stop" button
8. Press Off then On to set new changes.
9. Printer feeds a blank page after it is turned on again.
This should Reset the printer and remove the WRONG CARTRIDGE error and save you a few dollars.
Replace all the Ink Absorbers.
QA4-1012-000
QA4-1013-000
QA4-1014-000
QA4-1015-000
QA4-1055-000
Reset the counter to zero.
Replace the printhead. QY6-0042-000 (now QY6-0064-000)
Should cost you about $54 if in the US.
This will only work a few times. Eventually, it will fail to reset
and you will have to replace the Printhead. I hope this helps.
Nov 13, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Wont Post get 9 beeps!
This problem is due to the mix of registered and unregistered DIMMs. 64Mb and 128 Mb DIMM's are unregistered memory technology 256MB is registered memory technology. A mix of registered and unregistered memory prevents the server from completing startup, and results in an error beep sequence and a blank screen
Oct 08, 2007 | IBM Netfinity 3500 M20 8657 Server
Tunturi C80 Elliptical Cross Trainer Logo
Top Tunturi Exercise & Fitness Experts
gbob59
Jeremiah Meyer
Jeremiah Meyer
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
