Question about GE Profile JB968 Electric Kitchen Range
Baking element how to remove under floor baking element
2 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: How do you change the top oven bake element.
Should be no problem.
Posted on Jul 17, 2010
Getting tu the heating element on a maytage oven model #mer5755qab how do I get to that element . is it on the top or under the botto,
Hello Jerry,
That bake element is accessed from under the floor of the the oven...in th erear of the floor is a couple screws if ya remove those ya can pull up the the oven floor up and out from the rear to the front the bake element will under of that floor.
BEFORE ATTEMPTING THAT BE SURE TO DISCONNECT POWER TO THE OVEN
Sep 30, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Was baking in oven on a baking stone and inside the oven there was a flash and loud pop (what you would expect if you had metal in a microwave). Is this worth the service charge to see if it can be fixed?...
Was the baking stone resting on the element? It sounds like the element has shorted out and it should have tripped the circuit breaker and/or blown a fuse in the unit. Replacing an element is not difficult and is carried out from the inside and the back if the oven. With the power off, locate which element has blown, it will probably be the bottom one and there should be a hole at the site. Remove the back if the unit, remove the wires from the element, remove any screws that may be holding itin place, ease the element out of any clips that retain it and pull it out through the front, Refitting the new element is the reverse of the removal.
Jan 18, 2011 | Amana AER5712AA Electric Kitchen Range
Had foolishly tried to remove baking element w/ oven turned off but still plugged in / breakers still on (all to make cleaning easier-ha!) unscrewed element beleiving it was modular like stovetop elements....
Some times s**t happens. The most likely situation is the wire connections that connect the heater have burnt off, or simply just become disconnected.
the normal repair or replacement to the lower heater element would be to disconnect the wires from the heating element by sliding the wire off of the spade connector. Some times they are connected by a screw and nut terminal. Next to remove the screws from inside the oven, and then pull the element out from the back wall. I can see how you could easily interpret that they would slide out like many stove top elements.
In your situation confirm that power is off.
Remove back panel and check terminal' connections to the heating element. repair.
Model ra520w3 HOTPOINT ELECTRIC RANGE Parts
maxresdefault-es3dyrcoa4nhevk3e5ork442-3-5.jpg Hope this helps?
Jun 21, 2017 | Hotpoint RA520 Electric Kitchen Range
THere is no bottom element in this oven. Is there supposed to be one??
you are right jsrock, there is an element under the floor pan, but if this person bought it from someone (not a dealer) that may explain the lack of knowledge. The benefit here is in the cleaning, and not having to lift the heating element to place foil or teflon sheets underneath as in "the old days." I like it this way better!
Mar 18, 2010 | Amana ACF4215 Electric Kitchen Range
My oven is burning my baked goods, but shows the right temp with a thermometer. Do I have to turn the dial to broil and then back to the desired temp? Even if the rack is in the middle, everything burns....
If it is convection bake you have to turn the temp down (25 degrees or so) that is listed in the recipe.
The broil setting is not used to bake because it operates differently from the bake setting. So, don't go to the broil setting at all.
The element for bake is under the floor of the oven. You have not indicated whether it is gas or electric, but both of these can have issues with the burner or element.
If you are baking on the correct setting and the oven is heating from the bottom, not the top, this can be caused by hot spots that are created by elements/burners.
to check, look under the floor of the oven. Turn the bake heat up to high and see if the flame is uneven. For an electric oven, the color of the element should be evenly red, no brown spots.
If you are using an oven thermometer, move the thermometer to the spot in the oven that seems to be burning things the most.
Nov 27, 2009 | Kenmore Ovens
Cooking element
You do not list a full model number. Typically a JBP78_____ uses a WB44X10013 bake element. Disconnect power to range. Take out two 1/4 inch hex head screws holding element in at back of oven. Pull element out a few inches into oven. Disconnect wires. Reverse to install. Not too hard if it is an exposed element. A bit more involved on ranges with "hidden" bake elements (which are under the floor of the oven).
Oct 11, 2008 | GE Spectra JBP78 Electric Kitchen Range
Thermador oven
If oven does not heat check heating element and oven control. Follow also suggestion below:
" It won't bake Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
It bakes poorly Here are two instances of when food "bakes poorly:"
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
  • You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
  • If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
From repairclinic
Aug 17, 2008 | Thermador PGR366 Gas Kitchen Range
Model MER57550AW won't heat beyon 200 degrees to prest 400
can you see lower (bake) element or is it hidden(under the oven floor). a visual inspection of elemnet is usually all that is required to determine if its good or not, It will have a "burn out" in it perhaps a plume of white soot around damaged area.in which case you will need to replace the element. simple enough 2screws and 2 wires part number 74010750.. if it is a "hidden" bake elemnt the floor oh oven lifts rightup to reveal it."POWER MUST BE TURNED OFF!!!!!!!! IT IS A CONSTSANTLY LIVE ELEMENT!!!!!!!!!!!!
Mar 16, 2008 | Kitchen Ranges
MER57550AWAW electric - won't heat to selected preset temp
Mar 16, 2008 | Maytag MER5750 Electric Kitchen Range
GE Profile JB968 Electric Kitchen Range Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
