Question about Stihl Garden
Engine runs, but trimmer head won't turn - Stihl Garden
  • Stihl Master
  • 1,807 Answers
Check that the gear head is engaging onto the drive shaft and tube. also could be a broken drive shaft, depending on the model
Posted on Feb 27, 2016
  • 45 Answers
SOURCE: trimmer dust cover hot to touch ... trimmer head
sounds like the drive cable is jammed.you need to remove the shaft from the engine and head and see if the cable spins freely.
Posted on Apr 29, 2009
harlan301
  • 205 Answers
SOURCE: new strimmer, trimmer head stopped turning even
check your cable in side the tube , if this is new, call your warranty repair center. you can find that. buy calling the 1-800 number in your book, than go to dealer locater. hope this helped
Posted on Oct 19, 2009
SOURCE: trimmer head on weedeater featherlite sst will not
replacing twine on head so it can be tapped and cut when still going.
Posted on May 02, 2010
  • 6468 Answers
SOURCE: Engine runs, but the head won't turn
if it has a curved shaft check the cable they break went over loaded on both models check the clutch
Posted on Mar 24, 2012
bustech17
  • 38 Answers
SOURCE: TB70ss Trimmer runs but does not turn the string
Remove the angle drive gearbox near the string head and spin it to see if everything is moving properly. You may have stripped the gears out of it.
Posted on Sep 23, 2012
Husqvarna trimmer starts but head doesn't spin, made a high squelling sound but continued to cut, the next time I went to start it the cord pulled quickly then caught started turned briefly then quit while...
Make sure there is not debris stopping the head. Try removing the trimmer head and make sure the shaft turns freely. If it does the problem could be either the engine or clutch.
Jun 25, 2014 | Husqvarna 28cc Gas Line Trimmer
Stihl fs 55r head won't turn
Check drive shaft. Some models have a flexible cable drive shaft that is prone to breaking. also make sure the drive shaft is engaged in the clutch drum and in the gear head end.
Mar 25, 2013 | Stihl Garden
Sep 16, 2012 | Troy Bilt Tb70ss Gas Trimmer
Mar 23, 2012 | Craftsman 25cc Gas Line Trimmer
When my flymo lite 250 engine is running the end does not turn to cut the grass
Could be anything from a stripped drive shaft to a loose or stripped trimmer head. You'll probably need to take it to a repair shop to have them diagnose the problem and locate the replacement parts if it's anything other than a stripped trimmer head bolt.
Nov 01, 2011 | Homelite Mighty Lite Lawn Trimmer
How to adjust the carburtor high and low on my weedeater head cutter?
Hi jamesbj44...
Before you remove or try to adjust your low and high speed jets you should always count the number of turns to lightly bottom the adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know when you go to replace them.
Normally you adjust your idle jet to 1/2-3/4 turn open from the bottom seated position to start with...you re-adjust when the engine is warm turning the screw in or out till the engine runs smoothly.
The high speed jet is normally adjusted to 1 1/2- 1 3/4 open from the bottom seated positon, then re-adjusted to run smoothly when running at high speed by turning the screw in or out.
Free Answer...Please take time to rate me
Jun 06, 2011 | Garden
Ryobi CS30 Trimmer starts and runs in full choke and half choke but stumbles and stalls on run. Not up to full rpms when in full choke and half choke....
You probably need a slight carburetor adjustment. Try to turn the L mixture screw (the one near the bottom of the carburetor on the air filter side, closest to the engine) 1/8 to 1/4 of a turn counterclockwise. These mixture adjustment screws ( L and H) have odd heads on them and conventional tools won't turn them. I use an automotive type plastic wire connector (around 22 gauge) with a ring terminal end which I can hold. Tap the plastic end of the wire terminal connector onto the head of the screw with a small hammer and this will enable you to adjust the L screw. This adjustment will increase you high speed side and possibly allow it to run off choke in a regular manner.
May 21, 2011 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Makita gas trimmer RBC221. engine runs fine but trimmer head does not turn.
would suggest that the cable that runs the head is broken or there is too much material wrapped around the head... remove the engine off the trimmer and check the cable that runs to the head....
Apr 07, 2011 | Makita EM4251 16" 4 - stroke String...
Garden Logo
42 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
