Question about Stanley Bostitch 18 Gauge Brad Nailer 1 - 1/4IN - BT125K - 2
How do I remove Senco part HC0 170 - Stanley Bostitch 18 Gauge Brad Nailer 1 - 1/4IN - BT125K - 2
I have a sfn1 senco nailer the drive pin does not retract after firing
take off cap of tool remove wagon wheel. remove cylinder and driver on outside of cylinder there are two orings a large one and a small one / it might a band instead of an oring if tool is older. there should be bunch of tiny holes your oring/band is worn or missing its called a return band
Apr 17, 2012 | Senco Air Tools & Compressors
I need to replace the rubber tips on my senco sfn1 nailer and my senco sks stapler. Do you know where I can buy them?
Look for a Senco dealer or tool supply place in the yellow pages or go to senco . com and enter your zip code for your nearest dealer. I found replacements at Hughs tool supply.
Jun 12, 2011 | Senco SKS 18 Gauge Stapler
How do I adjust the depth of the nails? I have the Senco FramePro 601.
Most senco nailers have an adjustment on the lower safety. Usually one or two screws allow foot to extend. Others framers have a thumb wheel on the side or under the trigger. If the adjustment is all the way out and the nail is still setting too deep, then fault may be with the lower bumper. If the bumper is breaking up, the driver will set the nail too deep. Remove head and pull the piston, if the bumper is missing pieces or cracked, replace. Good luck
Apr 22, 2011 | Senco Air Tools & Compressors
Looking for a diagram or schematic for a senco fp18
I have a SENCO FinishPro18 that I inherited from my son when he died a year ago. It has worked fine till now. It does not shoot a nail when depressed against a board and I pull the trigger. I don't hear air leaking, but it seems there is little pressure. Having taken apart the head, then the base, it all seems in good shape. I have not taken apart the trigger assembly, as the removal is a total commitment. Thoughts? I could use some help.
Oct 24, 2010 | Senco FP18 FinishPro 18 - Gauge Brad...
Senco Finishpro18 just stopped shooting nails. Took it apart put it together. Shoots a couple of nails then stops. Press the nailer against the target pull the trigger and air comes out of the handle.
I just had the same problem with mine. Exact same symptoms. My guess is that your gun hasn't been used in a while.
I called Senco and they recommended removing the top cap, removing all o-rings (one at a time) gently stretch them, put a small amount of lithium grease in the o-ring track, and replace the o-rings. This fixed my problem and I hope it fixes yours!
Senco has awesome tech support for their tools. I will not buy another brand because of their support. 800-543-4506
May 15, 2010 | Senco FP18 FinishPro 18 - Gauge Brad...
How do I get a part of a Senco model K staple gun
go to Senco.com and you can download a schematic and also order parts direct from them
Mar 19, 2010 | Senco Tools & Hardware - Others
SENCO PART VA0036
what is the question, if you are looking for it I would try Senco.com and you can buy direct from them if not let me know and I will try and help
Mar 05, 2010 | Senco DuraSpin DS200 - AC Screwdriver, 1"...
Trigger asembly broke ned new one senco model#03501710
Check for authorized Senco retailers or repairers near you and they will be able to order one in for you. www.senco.com
Mar 01, 2009 | Senco 2D0001N FinishPro2N1, 18 Gauge Brad...
Stanley Bostitch 18 Gauge Brad Nailer 1 - 1/4IN - BT125K - 2 Logo
18 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
JOHN LAPIER
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
