Question about Garden
No fire to sparkplug
Tractor starts and flying wheel turns but we're not getting fire to spark plug. Ignition coil was replaced and we're still having the same issue. We just ordered an ignition module to see if it corrects the problem. Any suggestions?? Model is GX95
  • panilling9
    panilling9 May 11, 2010
    neutral start switch
    trans has to be in neutral ?
    and it is a normally open switch.
  • 32 Answers
You may not be getting electricity from the battery. you can check this but it is kind of dangerous. you stick a metal object in the spark plug cap and hold onto the other end. crank it over just a little bit and if you get a small shock then it works. you may just need a new spark plug.
Posted on Jun 21, 2009
Why does my chain saw lose power and shut off as soon as it gets hot.can't restart until it cools off.
Check coil pic up or the electrical pick up in the pull string housing. Remove that and u will see the fly wheel next to that is the electrical pick up .look at fly wheel make sure magnets are clean surface ,they are in the fly wheel itself.after that remove coil and clean surface that faces fly wheel. Using a match book cover place it between fly wheel and coil ,make sure it moves but not falls out snug ,tighten coil screws and remove match book cover. If it dose it again re place coil look for small engine shop in your area and the can help get u a new one .weak spark means coil,sparkplug
Sep 15, 2014 | Poulan PP4218AV 18" Chain Saw
No fire to sparkplugs
Bit late here, but I love Datsuns! First check if you are getting power to coil on the + side of coil. Pretty much a straight path from ignition switch to coil. Then pull off coil to distributor cable at the distributor and check for spark on that wire when cranking engine over. If good, rotor, distributor cap, plug wires, or sparkplugs need checked. If no spark from coil, it should be tested with an ohmmeter for proper resistance values, or swap in another coil.
Does it have mechanical points and condenser or electronic ignition?
Nov 22, 2012 | Datsun 510 Cars & Trucks
Bolens garden tractor will not start
At this age, the engine will have points under the flywheel. If the coil is OUTSIDE the flywheel, forget fixing it and just replace the coil with a later solid state unit, then cut the points wire.
If the coil is UNDER the flywheel with the points, you'll have to stick with them, but replace them AND the condenser. These parts (and replacement coils) are still available, but decide quickly - Tecumseh have gone, and when all these old parts are used up, that's it.
May 08, 2010 | Garden
Cutting grass.heard loud Pop tractor shut Cub Cadet 1210 Hydro
just trace the spark plug wire to the coil but you can check the spark by putting a new plug in the wire and make sure it is grounded and turn the engine over if you have spark then you have to pull the fly wheel off and check the fly wheel key
Jun 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Tractor mower will crank but not start, new gas, plug and battery
check the coil it may have rust on it and the fly wheel
Jun 22, 2009 | Garden
Echo SRM 1501 trimmer has minimal fire. Feels very slight, will not fire thru plug
If this is a solid state ignition ( black box mounted right next to the fly wheel)check for rust on fly wheel and coil/ignition.Sand with light grit sand paper if nessesary. Make sure to reistall with the same gap between the two parts.note the gap at this point could also be wrong.Also check to see if the clip inside the boot where the spark plug conects is not bent and that it is conecting properly. If this is a points ignition system then its basicaly the same steps.Clean contact pionts check plug boot for good contact. Or could be bad coil.Be sure you are using a plug with the propor heat range.
Jun 07, 2009 | Echo Garden
Not firing
After you check the key and key way,Check the coil wire to see if it has any breaks in it,If no breaks are present,Replace the coil.
Jun 02, 2009 | Briggs & Stratton Briggs Stratton Intek V...
No spark
hi is this a point less ignition or electronic? check that your ground wire from ign. coil is not grounded causing no start.( last ign coil shot) good luck.
Apr 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
97 Ford Probe GT not starting
WARNING: Risk of Electric Shock
Check your spark plugs and wires yourself. Remove one sparkplug at a time from the engine block, plug the wire back on, place the sparkplug on the engine or vehicle body so that the outer thread of the sparkplug would touch the body, or engine (GND) you can secure it with a cellotape or so. Turn the ignition key to the START position and when starter is spinning wach for high voltage sparks appearing between the body,engine or gasket and the tiny black end of the sparkplug called electrode. If there's a sparks, than it's fine, othervise try to get one working sparkplug and to retest this. If now it works then your sparkplugs needs to be replaced. Othervise check the resistance of the high voltage coil primary windings. this should be something between 0.2 and 10 ohms, when coil is disconnected from vehicles wiring. I just do nts remember the exact figure. If multimeter doesn't show anything, replace the coil, otherwise check if the supply current is flowing to the coil plug when IGN is ON. If it's fine then check the COM line at the same plug, using analog muldimeter is the easiest and not harmfull way to do this. If COM isn't comming You might need to go deeper into ECU, or even to replace it. If COM is fine then it would identfy that coil itself is faulty.
Update me about your progress
Good luck
Mar 20, 2009 | 1994 Ford Probe
Garden Logo
188 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
