Question about Homelite Garden
Motor is running up and down want idle at a constant speed
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 50 Answers
Carburetor needs cleaning and adjustment.
Posted on Jul 22, 2014
Motor speeds up and then slows down constantly on my Honda Civic
That's usually a problem with the idle air control or electronic throttle body. But it really depends on year and engine, which you left out.
High idle rough idle Ricks Free Auto Repair Advice
Jul 24, 2017 | Cars & Trucks
Why are my cooling fans for radiator running constantly?
The cooling fans are supposed to run any time the a/c is on in order to keep air flowing across the condenser. Your a/c will not work properly at idle if they quit.
Jul 27, 2015 | 2010 Ford Escape
How many turns of low idle screw for 1986 johnson 30 hp, ELCDM
Start with one. Bring the speed down slowly. If the motor "sneezes" and dies ,open more, maybe one-half turn and restart. If engine now runs as you idle down, slowly turn in the idle screw until the motor starts to speed up without moving the throttle. A little more and it should sneeze again. From the point where it started to speed up, back the adjustment about one eighth to one quarter turn open. See how it runs. If you have to open the idle screw way out or it keeps sneezing you probably need to clean the carb.
Aug 23, 2014 | Boating
Motor surge at constant driving speed
Acceleration is defined as a change in speed, either a negative acceleration (slowing down) or a positive acceleration (speeding up). If you have constant speed, you are not accelerating.---------------------------------------------------------------------------------------
Multi-Di@g Access
Jan 14, 2013 | 2005 Jeep Grand Cherokee
The fuel pump was changed,now it idles high.
The idle speed is controlled by an Engine Control Module (ECM).
It needs to be put on a computor to be checked.
The idle air valve provides the control for constant idle speed. In order to set the correct air valve opening to achieve constant idle speed, the fuel injection control unit uses information from the air mass meter, A/C switch, throttle valve switch and the ignition control unit (RPM signal) to regulate the output current to idle air valve. This means, there is alot of things that can make the idle speed go up or down...Hope this was some help to you??
Jul 21, 2011 | 1990 Volvo 740
1977 TS185 won't run smoothly; carb adjustment problems
thats the idle screw!
you need to adjust the mixture screw!
Aug 15, 2009 | Suzuki TS 185 Motorcycles
98 galant 2.4 engine speed uncontrollable after 1600 rpm
check automatic idle speed motor if equipped.
Jul 07, 2009 | 1998 Mitsubishi Galant
Bike wont idle and power constantly dieing and recovering
check to see if you have gas in the oil from a carb leaking down which will cause the idle speed to drop when motor warms up.pick up idle run for awhile then plugs foul.like you said a carby problem.
Feb 16, 2009 | 2006 Honda CBF 250
Runs erratically
The idle air valve (located below the throttle body) provides the control for constant idle speed. In order to set the correct air valve opening to achieve constant idle speed, the fuel injection control unit uses information from the air mass meter, throttle valve switch and the ignition control unit (RPM signal) to regulate the output current to the idle air valve. This means that the idle valve is not affected by air leaks or a jammed throttle valve.
Nov 03, 2008 | 1986 Volvo 740
Garden Logo
19 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
