Question about Homelite Mighty Lite Lawn Trimmer
Primer does not work - Homelite Mighty Lite Lawn Trimmer
    Director Badge:
    Uploaded 100 video answers.
  • 225 Answers
Bulb or fuel line could have a crack or a clog in fuel line/filter or carburetor. Here's a video on how to change the bulb and fuel lines and another video on how to clean/rebuild the carburetor.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
Posted on May 09, 2015
Lawn mower po500n225h primer not getting gas
Is the primer bulb cracked or broken. Primer will not work if air can be sucked into it. I had to replace several.
Jul 28, 2015 | Poulan Garden
Primer not working wright.want push in right
You may need a new primer. To take the old one out take a small screw driver and work the old one out as well there is a metal ring like out fit that has to be removed as well. This holds the primer in place. Purchase the right primer for the machine and make sure the hole is cleaned out then insert the new primer as well as the metal ring and most go in with a three quarter inch socket and tap it in this a hammer but don't hit hard and it should go in all the way. Then the primer should work.
Nov 14, 2014 | Garden
Fuel primer
The primer bulb fills the bowl of the carburetor on initial start-up. Most primer bulbs are depressed 4-6 times. Set the choke at half and either pull the starter cord four times. If it doesn't start, re-prime and take the choke off.
Mar 16, 2014 | Garden
Can't get gas to start primer pump not working
Sounds like you have an air leak in the fueling system and air, not fuel is being sucked in to the primer, check the fuel line and primer pump gaskets or bubble (if it is the primer bubble type)
Aug 01, 2013 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Stihl chainsaw
If you replaced the primer and not getting fuel sounds like either wrong primer or not sitting proper in carb and sucking air instead of fuel Did you. Make sure the fuel lines good inside the tank so it can suck fuel as you didn\'t say if worked before you switch the primer
Jun 30, 2013 | Garden
Tecumseh carburetor primer not working
thehole for primer fuel is clogged have to rebuild carb
May 06, 2013 | Garden
When i pump the primer to start it pumps air into the tank and not to carb
Sounds like the pickup line for the primer is not far enough into the tank. Most primer lines are only far enough in the tank to work if the fuel tank is completely full. The primer works like a suction, air is pushed into the tank and the expanding bulb draws fuel into itself. A longer primer line can be installed, and most saw or trimmer dealers will carry rolls of it. Let me know if you need anything else or if this helps, Daniel.
Aug 09, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
Need to know how to re-connect primer bulb on McCulloch Model # B00032-32, Ser # 11-100258 (McCulloch Gas Powered Chain Saw)
Take the line off of the primer that goes to the tank and leave loose for a moment. The other line to the primer comes from the carburetor and it should be be tried on either port on the primer until it will pull fuel into itself when pumped. If neither port works, the primer pump may be faulty, the carburetor is plugged internally, or the fuel line from the tank to the carburetor is decayed or the fuel filter is plugged. When the primer pulls fuel into itself, reconnect the return line that goes back to the tank. Hope this helps!
Dec 03, 2010 | Garden
Homelite Mighty Lite Lawn Trimmer  Logo
183 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
