Question about Panasonic Toughbook CF-29 Notebook
TOUGHPAD FZ-G1 EXTERNAL MONITOR - Panasonic Toughbook CF-29 Notebook
I cant turn my panasonic FZ-G1 on
If you could turn it on before and now, following same procedure, you can't turn it on, probably it is no working and you should take it to repair
May 21, 2015 | Panasonic Cameras
Hp probook 470 g1 starts fine but nothing on my screen, works on my tv but not laptop. only a week old have I done something
Right click on desktop -> select screen resolution. Select identify. If external monitor is number 2, select monitor number 1 (laptops monitor) and from dropdown menu select "extend these displays" or "duplicate these displays". Select apply, picture should be shown on both screens.
Apr 12, 2014 | HP Pavilion dv7-1130us laptop
Hog to get the FZ-G1 out of sleep mode
On any Panasonic Toughbook or Toughpad,
if the unit is stuck in sleep mode, I would try to
hold down the Power Button for 10-15 seconds.
This should cause the unit to beep. In any case,
when you turn it back on, it should start as normal.
If your unit has a removable battery pack, I would also
try to remove the battery pack as well.
Good Luck to you.
Richard from Montreal.
Authorized Panasonic Canada Toughbook and Toughpad
Dealer since 1989.
Feb 06, 2014 | Panasonic Toughbook Computers & Internet
Panasonic fz-g1 dock pinout
Dock pinout is the input power on the tablets, it always in and out process. Recommended to replace whole flexible dock inside the tablet for better quality.
Oct 15, 2013 | Panasonic Toughbook Tablets & eReaders
Hello, I have a vaio FZ 140 N/B, which was bought in USA 4 years ago. One day last week I put it on hibernate, then the next day I could not turn it on, either with A/C plug in or with battery. This is...
Hi dung27fme,
If you see power lights but nothing appears on the screen, it could be a "POST" (Power-on Self Test) problem or simply LCD problem.
Here are some steps that you can try. One of these may work on your case.
1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left from the system. (You may need to repeat this step to get it work.)
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor. You may need to press the Fn + F4 or F5, depends on the key designed on the keyboard to toggle between displays.
3. If you get display from the external monitor, I'm sure your having problem with the LCD components. In this case, check and replace faulty LCD backlight, LCD cable or LCD inverter. The LCD inverter is often a culprit.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the laptop not to POST.
5. If reinserting the RAM doesn't help, most likely your motherboard needs to be replaced.
Hope this helps.
Jun 27, 2011 | Sony VGNFZ220E/B VAIO FZ Series Notebook
No display
as your power supply is ok check hor. section if it becomes ok you will get voltage on g1 &g2.
Aug 16, 2006 | Philips SoHo 105E 15" CRT Monitor
Panasonic Toughbook CF-29 Notebook Logo
85 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
