Question about Lexmark E350d Laser Printer
84 remplacer le photoconducteur lexmark E350d
2 Suggested Answers
don_farr
  • 1011 Answers
SOURCE: replace photoconducter 84 on lexmark e350d
Go to www.lexmark.com Select the correct country. then Selectg "Technial Support" Enter the model of your printer "E350D" Click on search. Under the "Knowledge base" header place this number into the search bar: "ENUS27198" click on search. ************************* Lexmark E350d Country / Region: United States Language: English Need to download a driver? How to Reset the Photoconductor Page Count on a Lexmark E350d or 352dn Printer ID: ENUS27198 Procedure Follow the steps in the table below to reset the photoconductor (PC) page count. NOTE: The directions in this article are in English. To download a PDF file containing these instructions in several other languages, click here (file size: 782 KB). Step Action 1 Enter the printer's Configuration menu: Power off the printer. On the printer's operator panel, press and hold the select button () and the back button (). Power the printer back on while keeping both these buttons held down. When you see the messages Performing Self Test or Busy on the printer screen, you can release both buttons. If the printer has successfully entered configuration mode, you will see a new menu with the heading CONFIG MENU at the top of the screen. 2 Press the right arrow button () until you see Reset PC Cnt. Press once. You will see Reset. Press again. The printer will display a Resetting PC Count Value message and go back to the previous screen. 3 Press once. 4 Press or on the operator panel until you see Exit Config Menu. Press once. Selecting this will cause the printer to reboot. If the counter has been reset correctly, the printer should return to a Ready prompt. 5 If this does not clear the PC Life Warning or Replace Photoconductor message, power off the printer and attempt this entire procedure again. If the error remains after two attempts, confirm that: The correct photoconductor unit is installed. The part number on the photoconductor unit should be E250X22G. If it is not, install the correct photoconductor unit into the printer. The photoconductor unit has not been refurbished by a third party or is not damaged in any way. If the photoconductor unit was refurbished by a third party or appears to be damaged, try replacing it again before seeking service on the printer. If the error persists, the printer may require service to correct the issue. Contact Lexmark Technical Support for more information. Don
Posted on Jun 04, 2009
Quelques touche du clavier ne fonctionnent plus
Le clavier lui-meme a failli. Tu dois le remplacer.
Le clavier http://www.getpartsonline.com/378188-001.html
Procedure pour remplacement http://bizsupport1.austin.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c02045773
May 04, 2011 | HP Compaq nc6220 Notebook
Epson AcuLaser changé photoconducteur et faire passer le message d'erreur «installer photoconductr"...et le photoconducteur pour ma nouvelle Epson Aculaser C1100 et je reçois le...
salut ;
ce message apparait lorsque le detecteur de photoconducteur est bloque avec du toner, desinstaller le photoconducteur ; nettoyer le detecteur situe a l'interieur.
Oct 19, 2010 | Epson Aculaser C1100 Printer
Lexmark E350d erreur 935 Service Printhead error.
Yuot should let the printer toruned off at least 1- 2 hors, and then it will work again. It is a heating problem when you print a lot of pages.
Oct 13, 2010 | Lexmark E350d Laser Printer
What is 84 replace mean.
This is a summary of the chat I had with a Lexmark tech
The code 84 replace indicates the consumable parts of your printer are in need of replacing.
The rollers or drum.
Usually the toner has its own code.
I started the chat from this link..
http://support.lexmark.com/index?page=answers&startover=y&locale=en&userlocale=EN_US&productCode=LEXMARK_E350D&segment=SUPPORT&question=what+does+84+replace+mean#
good luck and don't forget to vote!!!
Sep 28, 2010 | Lexmark E350d Laser Printer
Code 936 - Service transport motor Lexmarx E350D
Here's an article on 936 and 937 Service Main Drive Motor Errors in the Lexmark website. Just click on this link: http://bit.ly/dtbJKt. If all else fails, the printer may require service. I suggest you contact Lexmark technical support or your local service provider for further assistance. thanks.
Jul 23, 2010 | Lexmark E350d Laser Printer
A Lexmark printer E350d has a message "photocon". What does it need?
Photoconductor unit (drum unit).
These are available new and remanufactured on internet auction sites.
Note that the photoconductor unit is EXACTLY THE SAME (other than the label and part number) as the one for DELL 1720.
Dec 28, 2009 | Lexmark E350d Laser Printer
Replace photoconducter 84 on lexmark e350d
Jun 03, 2009 | Lexmark E350d Laser Printer
Error 31 lexmark e350d
Possible causes here are;
Most likely, the contacts in the printer not touching the chip properly (hence why it works in another printer). A simple gentle 'tweak' would work in this case.
The other possibility is the firmware version of the (offendig) printer being incompatible with the version of the after-market chip you are using. No solution here, other than trying a DIFFERENT MAKE of chip.
Mar 18, 2009 | Lexmark E350d Laser Printer
Lexmark E350d printer - replacement cartridge will not work
Seen/heard this before on Lexmark E350.
First place to look is the cartridge.
One side has a plastic gear which is a push-fit onto the end of the Developer Roller.
The D shape (hole with a 'flat') can lose the flat, or the gear can fracture (usually from one or the corners of the 'flat').
If this is it, the cartridge is faulty.
Mar 08, 2009 | Lexmark E350d Laser Printer
Eror 31 in lexmark e350d
Error code 31 is displayed when the top front cover is closed and a defective print cartridge is detected. It may take the printer 10-20 seconds to determine if the print cartridge is defective.
Replace and reinstall the defective toner cartridge.
Oct 28, 2008 | Lexmark E350d Laser Printer
Lexmark E350d Laser Printer Logo
44 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
