Question about Maytag MERH865RAB Electric Range
Burners not working right
Front right burner only goes high. Left front doesn't come on
  • 22 Answers
SOURCE: Problem w/burners & lights after self clean
You may want to re-seat the right two cooking elements, in case there is poor electrical contact. When you have them removed, clean the contacts with denatured 91% alcohol and a Q-tip. The removal procedure follows.
First, unplug the range.
LIFT–UP PORCELAIN COOKTOP
To lift:  When cool, grasp the cooktop front
edge.  Gently lift up until the two support rods
snap into place.
To lower:  Hold the cooktop front edge and
carefully push back on each support rod to
release.  Then lower the top into place.
COIL ELEMENTS
➢When an element is on, it will cycle on
and off to maintain the heat setting.
➢Coil elements are self-cleaning. Do not
immerse in water.
To remove:  When cool, raise element.  Carefully pull out and away from receptacle.
Check them for damage. They do wear out.
To replace:  Insert element terminals into receptacle.  Guide the element into place. Press down on the outer edge of element until it sits level on drip bowl.
COIL ELEMENT SURFACE
➢ On Canadian models, the two front elements will not operate during self-clean.To prevent the risk of electric shock or fire, never line drip bowls with aluminum foil.
If that does work, you may have a faulty control panel. In that case, call Maytag at the number below.
Maytag Customer Service
533 Benson Road
Benton Harbor,MI 49022
(800)688-9900 U.S.
(800)688-2002 Canada
Posted on Dec 04, 2007
SOURCE: burner igniter won't click or work
This is an easy problem to fix. If your repair man is correct and it is the spark module and not a wire harness problem you can pick up a spark module as sears for about $37 and it only takes a couple of minutes to install. Just pull off the back panel and replace the module. This is a repair that anyone can do. I would recommend unplugging the unit before replacing.
Posted on Jun 20, 2009
  • 3600 Answers
SOURCE: Maytag Range MER5730AAQ front right burner died
you need to replace the inner connetor to make it work.
Posted on Jun 24, 2009
  • 187 Answers
SOURCE: front right burner stopped working
Often, this will be due to the element. The easiest way to troubleshoot is take a matching element(if possible) from the other side of the stove top and see if that works in the receptacle.
There should be some letters after the model numbers you listed. The last three letters also lets me know what type of top you have on your stove to guide you through how to access the parts. Make sure you write the full number with all the letters before ordering parts.
If you have the glass top or ceramic model, the connections are different than other types. The manufacturer warns customers and nonservice personnel to never try to lift these cooktops. If you would like to pursue changing or testing this element despite that caution, there is a picture of an element and switch below.
On some flat top models, you need to open or take off the over door before you can lift the top. Most stove tops will then lift off, but you may need to take off a screw or two.
Also, on Canadian models, the front two burners will not operate during oven cleaning mode. If you are a Canadian user, try to reset your burner by turning on and off at the breaker. Canadian users should also make sure that the timer is not set and open the oven door fully to make sure toasting is not engaged.
Porcelain cooktops simply lift from the front and are held open with metal supports. Replacing coil type elements on models with drip bowls (not flat top) is very easy; you simply pull out the element and replace with a new one that can be purchased in large chains and appliance stores.
You should check the receptacle and wiring underneath the stove top for signs of visible dirt, grease or other abnormalities such as burns or frays. Turn off the power, and make sure the wiring plugs are tight.
Make sure the plug in end of the coil element is not burnt or damaged. Check the coil for rough or discolored spots. Follow the wires under the stove top that plug into the coil receptacle to make sure that there are not burnt, frayed or broken areas on the wire coatings.
Testing the element for continuity and possibilities like the receptacle and infinite switch requires special tools. Testing the infinite switch would be extremely dangerous as it is done live with 240 current (unless you live outside the US). If you have testers, you can check the integrity of all of the above.
Another less likely cause for elements not working is the knob that controls the burner being damaged on the inside. You can pull a different knob to see if that works, but this kind of issue is usually obvious because it does not fit snugly and has play when you turn it.
Finally, if you are going to replace the element, or replace the receptacle or switch, make sure that you take the old ones with you with the full model number. Before pulling wires, take a digital picture or mark wires with tape/paint so that you remember how to reconnect.
Check your parts before leaving the store, so that uninformed clerks do not steer you wrong. If you need further info on how to remove and replace the items shown, leave comments. But, take a look under the hood first, because you might be surprised at how simple it all is. I hope this helps
Posted on Dec 20, 2009
dcramer531
  • 1654 Answers
SOURCE: Have maytag smooth top range.
In this case the burner switch needs replaced, if it works but only on high leads to the switch.
These switches operate like regular dimmer switches. By regulating the amount of electricity flowing through the switch to the burner they allow you to adjust the temperature setting, if you can't adjust it then the switch is bad. I suggest you get a new one from the parts supply and look at it and decide whether or not you need help with the replacement, they aren't hard but you need to decide and let me know, but it really is simple if you can unplug wires and plug new ones in and turn a nut to get the switch off your probably capable of this repair your self.
Posted on Mar 15, 2011
One burner won't spark when another is aflame. Multi-ignition BlueStar 4-burner range.
I would check that the plates are on correctly. Make sure they are aligned and sitting properly. Sometimes they move while cleaning and give you a bad ground connection for the spark.
Feb 15, 2016 | Kitchen Ranges
I have a kenmore stove model number 790,72403012 and 3 of the 4 burners are working. They all are getting a spark, but the front left won't fire up.
First, try to light the burner in question with a match. Just hold a match to the burner, then turn the gas on to low. If the burner doesn`t light, the problem is the gas supply to the burner. Next, lift the top cover and put the prop rod in the hole in the cover to support it. Hold a match to the left-front burner. Now, turn the control knob to "light". You should see the igniter spark and hear a snap. If this doesn`t happen, repeat this step with the left rear burner. If you hear the spark and snap.
If the igniter doesn`t work on the front left burner, but does on the rear left burner, the igniter does work. The problem is likely the control knob for the left front burner. The. Control knob includes the electrical switch the activates the igniter when you turn on that burner.
Jan 26, 2015 | Kenmore Kitchen Ranges
Hot surface light stays on on GE Profile Cooktop model JP989 and On does not light for left burners. This is only happening on left burners. Left front burner goes to high with any setting on the switch...
You could have a shorted burner, if it is not then you may have gotten a bad part.
always unplug electricity before attempting to repair on any electrical appliance
Aug 17, 2017 | GE 30 in. Profile JP989 Electric Cooktop
Low flame on left front burners high flame onright front burnners
That is food/grease buildup. Clean the holes. TURN OFF GAS to stove, then just clean the holes in the burners with a soft wire brush. Then turn gas back on and immediately relight pilot lights. If that sounds scary, call your gas company, they might come out and help.
Dec 09, 2012 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Sears Kenmore gas stove, the front left and the left and right rear burners turn on when the knob is turned to the lite position. The right front burner doesn't turn on when put lite position. N
If there is no clicking sound like you hear when you turn on the other burners than I'm going to say that either the electrode is bad or the spark switch, which is what you turn to turn on the burner to begin with. Both parts are cheap so it may be a good maintenance thing to change all of the burners. Make sure you have your model and go to www.repairclinic.com and order both parts, and if you don't need one send it back for a full refund even if you installed it. good luck
Apr 29, 2012 | Kitchen Ranges
LG lre30451S burner will not shut off. It is stuck on high and the only way to get it to go off is to flip the breaker. When I flip the breaker back on the burner goes back to high. Thanks
I had the same problem with my LG front left burnr. Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Relay is the problem. I had the same problem with my front left burner stuck on high.
After replacing relay everything works fine.
Mar 02, 2010 | LG LRE30451 Electric Kitchen Range
I have a new ge range. When I turn on the left
mvek,
If you could see through the glass, you'd see "temperature sensors" located near the elements. They're very sensitive little guys, and rightly so! Their job is to detect temps and energize the warning light on the cooktop so users won't get burned.
To answer your question... It appears that there is an issue with the front left sensor (and possibly the right as well). The temp warning lamps should NEVER go off immediately. Please call for warranty repair (1-800-GE-CARES). This is an unsafe condition for you and your Family. The warning indicators are there for a reason and should indicate high temp's as long as high temp's are present.
SG
Apr 11, 2009 | GE Kitchen Ranges
Front left burner wont work.
It sounds like the left front control or element has a high resistance short.
Jan 23, 2009 | Tappan TEF242 Electric Kitchen Range
Burner temperature is always on high heat even at low setting
not related any further then sounds as if you have 2 burner switches gone bad,and actually the front right burner is controlled by a electronic control circuit board part retails for about $160-$200 part number 12002723, and left rear switch about $30 part number 74007841 . uint needs to be uninstalled from counter and parts changed by removing the bottom panel
Nov 04, 2008 | Jenn-Air JEC9530 Electric Cooktop
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Maytag MERH865RAB Electric Range Logo
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
