Question about Music
I need schmatics for my Chauvet ColorBank 8 stage lighting system
I am looking for the schmatics for my Chauvet ColorBank 8 stage lighting system. I want to understand how to program the controller to do something other than the simple chase pattern that is programmed into it. I also need to trouble shoot one of the channels that is dead.
  • Anonymous Mar 14, 2014
    #2 light controller does not work. All others work fine. Dim light on #2. Where should I start?
  • 69 Answers
Seems as thou the Color Bank 8 stage lighting system is a fixture....what controller are you usein?
Posted on Jun 23, 2009
Chauvet Obey 70 service manual
They are not worth trying to fix, if you really like this unit you can get a secondhand one for about 25GBP or find one from a decent manufacturer or even better how about a USB interface to DMX for your PC?
Dec 18, 2013 | Chauvet Obey 70 Dmx-512 Light Controller...
I have four 200b lights that i must have connected to a wrong device and all 4 blew fuses. I replaced the fuses but they continue to blow as soon as I plug them in.Any suggestions would greatly appreciate.
first need to know if the other device you connected it is with dmx and if not, the most likely need replacement on the circuit 8 pin controller dmx its easy to know the locate its the circuit most close to the input signal, I hope you test the input volt regulators and are well, if not also need more data presents fault.
Feb 16, 2013 | Chauvet (2) Chauvet Ledsplash 200b Dmx...
When i turn on the brand new double derby it works for 2 seconds and then goes off, what could this be and how do i fix it please Lily
It is probably in the wrong mode. Since the light can be set for automatic, sound, and DMX we have NO idea what mode you are trying to run. Refer to page 8 and 9 in your manual for correct dipswitch setting for whatever mode you are running.
For eye protection, the lights must keep moving or they will shut down... which is likely what is happening in your case. If you put in auto mode or sound mode they should keep on. If in DMX mode and the mode does not command movement all the time, they will extinguish.
Mar 13, 2011 | Chauvet 2) Chauvet Double Derby X Dmx Led...
I am using 3 Chauvet colorstrips. They are hooked up perfectly to my DMX controller via master/slave. There are no problems with the DMX controller. The Chauvet colorstrips are flickering simultaneously...
Check if you may need to use a terminating resistor on the DMX chain. Sometimes digital reflections on the cable can cause random behavior.
Search "DMX termination" for explanation.
Also MAKE SURE you set the program mode to 021 (RGB).
It sounds like you might be in one of the automatic modes or sound triggered.
Mar 08, 2011 | Chauvet 6x Chauvet Colorstrip Color Strip...
I have numerous Chauvet 200b LED lighting fixtures. The problem I am having is: the "blue" LED"s on most every fixture are starting to go out. All the other colors are fine (it's just the...
Before jumping to conclusions, one should do some testing. It is posssible that you are having a DMX data error. If your lines are long, please review the need for a termination resistor at the far end of a DMX chain. The reflections of the data pulses can confuse or cause errors. Test a unit up close to your controller so the cable is short. If that magically works, install a terminating resistor.
Beyond this, electronic testing needs to be done. I did find in a Chauvet LX5 a bad solder joint at a connector that brings the power for, in my case, the green LED's. There will be surface mounted resistors on the back of the board that limit the current to groups of LED's.
If the whole fixture loses the blue at once, either suspect a DMX error or the driver in the fixture.
Mar 02, 2011 | Chauvet (2) Chauvet Ledsplash 200b Dmx...
Have a q-mix chauvet stage light goes thru all motions but light wont come on even changed bulbs and fuses alright
Chauvet uses a 16 amp Triac to control the power to many of the 120 volt lamps in their products. The Triac MAY be blown in your unit. If a bulb shorts, this blows the Triac.
I use Diigikey,com part number 497-2397-5 as the exact replacement. The generic number is BTA16-600BRG
Look for a part with this number on an aluminum plate and test the device. Also look for loose wires in the unit.
Sep 12, 2010 | Chauvet Followspot 400g with Stand
I looking to have a Chauvet Cyborg light repaired or to find someone who sells parts.
Here is the link for the info you need:http://www.chauvetlighting.com/service-faq.html Hope this helps.
Jan 21, 2010 | Chauvet Dmx 55 Dmx Controller
Looking for a schmatic for the 410 tvx 4 ohm and the 410 tvx 8ohm cabinets
Go to www.peavey.com/asstes/literature/specs/005584220_3.pdf. Apparently the 410 TVX can be used in 4ohm or ohm configurations just don't drop below 4 ohms and make sure your amp has the minimum required impedence. Hope this helps.
May 26, 2009 | Peavey Music
Music Logo
115 people viewed this question
Top Music Experts
Michial Gueffroy
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
