Question about Ironman Exercise & Fitness
Ironman quest treadmill will not turn on and the treadmill is just dead. The circuit breaker seems to be OK and three small led lights on the electronic board next to the motor (on red and two amber) light up. No lights on the dashboard.
SOURCE: I have a Carrier 38tra048340
Blank screen sounds like a fried thermosat. Abrupt outages can affect certain types of thermostats. Make a jumper wire and jump across R and G. See if you get any action from anywhere. If a fan or compressor kicks in you know you have a burned out thermosat...
Posted on Jun 23, 2008
Jimster
  • 240 Answers
SOURCE: my maytag dishwasher appears dead just after 1 year
You probably have a bad main control or console control unit in there. Turn power off to the machine, be sure that BOTH of your door switches are ok. Unplug your membrane to control panel ribbon cable, then put everything back in place. Leave the door open, then turn power back on to machine. (also, be sure the thermal fuse hasnt tripped while your in the console). After re-appling power, close the door, and wait a few, if the console unit is bad, the machine will go into drain mode (you will here the unit start in drain). If no drain mode, then your control is shorted. You dont have to see any burn marks, etc for one to be bad, in fact, 98% of the boards we replace, dont show any signs of problems. Let me know what you find out.
Posted on Nov 15, 2008
huuum
  • 750 Answers
SOURCE: We had a power outage
Turn the breaker off for 5 minutes. this will reset the system. If you still have no power then it spiked your control board and it's the board that is fried.
Please remember to leave rating before you sign off
Posted on Dec 20, 2008
  • 566 Answers
SOURCE: ford transit 1998 turbo diesel red light
this sound like you fuel injector pump stop solenoid is faulty it has an elec wire attached to it that with ign turned on it opens (clicks ) then clicks off/closes the fuel supply to the pump so engine stops ok? however the seal on the valve may have parted from the operating piston valve on solenoid and although it is free to allow fuel enough for start and running will also restrict fuel flow for more revs resulting in power loss as you mention ? also when ign is turned off the valve will operate but seal being not attached to piston ? fuel can still flow/seep thro to f i p and allow engine to continue to run ? hope you understand ?? this solenoid valve is a screw in type normally on top of f i p with a single wire to energize it looks like a larger type of temp sender unit ?
Posted on Sep 14, 2009
Testimonial: "Thank you Silver top, I will change solenoid. thought was $$pump$$ it$elf and I decided to lay down and die.locking cams, flywheels, timing, $$$..."
  • 670 Answers
SOURCE: No Power, No LED's. Circuit breaker OK
There is an internal fuse, however to access it the unit must come out. The outer case will need to be removed. The following link will take you to GE's website where you can get installation instructions. The fuse is available at ther parts site, but you can get a new on for less than a dollar at radio Shack. Take the fuse with you.
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=JVM1665DNWW
Posted on Mar 05, 2010
Testimonial: "Thank you for your quick response the information was very helpful. Installation instructions were not available. How do I remove the appliance?"
Ironman treadmill repair
Sears sells this unit has the manual and repair parts available as well as will service it for you , if you wish.
Sep 06, 2014 | Ironman Edge Treadmill - Console Control...
Error code e11
hi
1.Check that the LED light flashes on the motor controller while rotating the flywheel, check the connections on the controller and control panel.
Feb 18, 2014 | Ironman Envision Treadmill Drive Motor
Ironman Quest Treadmill Unfolds Improperly
see the video and proceed according. God bless you
Jun 08, 2013 | Proform Exercise & Fitness
What is it when display reading SI 2?
SI 2 - Over voltage protection trip.
Just check if there is any resettable breaker located underneath it. You also may have a cable connection loose.
if it doesn't works for you
You may need to notify Ironman Fitness Customer Service Call Ironman Fitness Customer Service at (800) 750-4766
Mar 14, 2011 | Ironman 220t Programmable Treadmill (225...
Will not power on
The lower board has a serious short and what possible happen is that the treadmill breaker fried and open up will properly need replacing also.
Apr 30, 2010 | RTO Lifespan Fitness Tr 2000 Hrc Treadmill
Ironman Triad motor cover will not come off
To remove the motor cover (#19 from parts list), you have to remove the follow items first:
- Left and right fenders (#20 and #21 from parts list)
- Left and right sideboard covers (#49 and #50 from parts list)
There are 4 screws holding the cover - 2 at the front and 1 on each side. Be careful when you lift the cover, the circuit breaker cable is attached to the cover.
Finally, you may want to reconsider doing that. There is nothing under the cover that requires maintenance. The big *** motor is driving the front tread roller through a belt. The roller has sealed bearings that do not require oil.
Feb 19, 2010 | Ironman Exercise & Fitness
Ironman M2 treadmill starts but then stops right away
Most treadmill will run for a second or two but stop if the speed sensor don't pick up a speed. If the treadmill was moved there is a good possibility that the sensor is off line. Not 100% fimiliar with this particular unit but if you remove the motor cover, these are the usual places for speed sensors. The front roller- the side where belt come from the motor. The other popular place is on the motor fan. The sensor has either two or three wires with the sensor at the end. On the roller, the sensor needs to be close enough to pick up the magnet on the side of the roller. On the fan make sure the teeth are clean and sensor has a good connection. Hopefully one of these will do it for you.
Nov 17, 2009 | Exercise & Fitness
Exercise & Fitness Logo
Top Ironman Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Tony Crow
Are you an Ironman Exercise and Fitnes Expert? Answer questions, earn points and help others
