Question about Fisher and Paykel Washing Machines
Fault code 9
Iwl16 fault code 9
2 Suggested Answers
SOURCE: fault code 37 on an iwl16 machine? can't find a
Code 37 means the pump is not pumping the water out. This may be the result of several things. For instance ask yourself what did I just wash. In our case, we had just attempted to wash a bath mat with crumbling rubber backing. Apparently the pump picked up the little pieces of rubber and they became impacted in the valve underneath. I was a lead aircraft mechanic for United Airlines and have dealt with some of the most sophisticated machines on the planet. I have always been impressed with our Fisher Paykel IWL16, the salesman sold us on the functions of this machine. He also told us about the technology incorporated into it. The elimination of the transmission and other moving parts and that FP had incorporated the philosophy of the minimum moving parts throughout the machine. So, I might have been a little intimidated about working on it because it appears to be very sophisticated. That is until I laid it over on its side and took a look underneath. My mouth dropped open There are 4 moving parts. The motor assembly that is connected to the drum and agitator. The water pump which siphons the water off the bottom of the tank and a 2 way valve that directs the water back into the tub or overboard. There is probably a fill valve in there somewhere that is at the top of the tub. Anyway I decided to try the 2 way valve first. Make sure the you have fully disconnected the machine before trying any of this. First I disconnected the two orange wires off of the 2 way valve and pay attention to which wire goes where (mark one with a marking pen). Then Squeeze the clamps on the three hose connections to the valve and back them up the hoses. Take one more look at how the valve is installed because you could put it in backwards. There is a screw and clamp holding the valve to the bottom of the tub. Remove the screw. Take the hoses off the valve and remove the Valve. Look inside and you will probably see what ever is blocking the Valve. Don't go digging around in there since there are O'ring seals on the flapper door that could get damaged. I used the eraser end of a pencil to clear the junk out of it. I then rinsed the valve out of the rest of the junk (take care not to get the electrical motor and contacts wet. They are covered with a clear plastic cover for a reason. Make sure the ends of the hoses are also clear and then reinstall the valve, hoses (3) and the (3) hoses clamps, Clamp and screw to the whole assembly to the bottom of the tub. Connect the two Orange wires to their respective connections and wha-laa... your done. Flip the washer back up and connect it up to the hoses and plug it in... Run the Machine through the tub cleaning cycle and that should do the trick... If this sounds like it might be difficult, it isn't. Tip over your machine and look at it before you call the serviceman and you might save a couple of hundred. The water pump also looked similarly easy to replace... a new pump is 98 dollars. I love my Fisher Paykel
Posted on Jul 13, 2010
Fault 16 light 00010 000
Your motor controller board is faulty and has no motor movement.
Mar 29, 2014 | Fisher Paykel Eco IWL16
What does fault code 30 mean on a Fisher and Paykel washing machine Model GWL15/IWL16?
it means that the two electronic boards in your machine are out of sync and need to be reset. just turn the machine off at the wall for a minute and then back on. if this doesn't fix the problem, you will need to replace one of the boards, which one is unknown until you try.
Aug 14, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
The drain pump on my F&P IWL16 is leaking water. I've had the pump replaced 3 times, during which, the new control board with fuse bypass was installed to prevent the board from blowing again
The pump may not be seating tight against the bucket,
There are four bolts on the gal plate you can tighten to make pump seat tighter on the bucket.
Nov 24, 2012 | Fisher Paykel Eco IWL16
What is error 240 on a Fisher & Paykel IntuitiveEco IWL16 Top Load Washer
240. (11110000) Phase 6 - Hall Out of Order. RPS Fault
Same as previous Hall Error faults, just an extra fault code for Phase
6. See fault codes 130 and 131 for directions.
130. (10000010) Phase 1 to 6 - Single Rotor Position
Sensor Error
The Motor Control Module has found an error in the pattern received
from the Rotor Position Sensor. Likely causes of this fault are a bad
connection on the harness between the Rotor Position Sensor and the
Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: 1. Check for corrosion on the edge connector of
the Rotor Position Sensor and the Motor
Control Module connector.
2. Check the contacts on the rotor positional
sensor end of the hall harness to see if any
have been damaged. (Each set of contacts in
the socket has two wipers. If the distance
between these wipers varies between
different contacts, replace the rotor positional
sensor harness.)
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S.
tester. Replace if faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
131. (10000011) Phase 1 to 6 - Repetitive Rotor Position
Sensor Error
This fault is similar to fault number 130 above but differs slightly in that
it is a continuous condition.
Oct 02, 2012 | Fisher and Paykel IWL12 Top Load Washer
Fisher and Paykel Kelvinator Pride 5.5 Smart Drive 9
You need to read the error code
and tell me what lights are on
Aug 17, 2012 | Fisher Paykel Eco IWL16
Where can I buy a Fisher & Paykel Intuitive Eco IWL16 service manual?
go to appliancerepairplanet.vstore.ca and u can get one there
Dec 01, 2010 | Fisher Paykel Eco IWL16
Fisher and paykal IWL16 washing machine showing fault 37 tub not emptying or spinning when put on spin cycyle
Hi just read your posting.Error code 37 means PUMP BLOCK ERROR.Drain some of the water by hand enough to look under the machine to the front right.Do you see a fan.If you do this is your pump.If you do not see a fan then you have the new style of pump.Please reply on which style of pump you have and I will guide you in rectifying this fault.Looking forward to your reply.
Oct 11, 2010 | Fisher and Paykel IWL12 Top Load Washer
Washing machine comes up with code fault 51. Could you please explain?
Hi just read your posting.The error code you have indicated is called RECIRCULATION FAULT.This means that when your machine is on the recirculation mode it is losing water.Please look under the machine for me to confirm which pump style you have in your model of machine.If you see a black fan to the front right you have the older style.Please reply and let me know if you have the older pump or newer pump.If you have the new style of pump then you will not have the black fan.This information will help me guide you in rectifying this fault.Looking forward to your reply.
Sep 20, 2010 | Fisher Paykel Eco IWL16
Fisher & Paykel IWL 16 ''I need service'' message & fault code 12
The first thing to do is to check if the water valve is good - probably burnt /stuck open.
regards
Nov 16, 2008 | Fisher Paykel Eco IWL16
Fisher and paykel washing machine
Unfortunately, it means get a technician to your home. Something is wrong with the "board". I had the same problem
Sep 01, 2008 | Fisher Paykel Eco IWL16
Washing Machines Logo
15 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
