Question about Uniden Cordless Phone
GE 24 GHz cordless phone
Put new battery in & charged; phone does not work, but answering machine does; do I need to reset & if so, how?
SOURCE: Uniden 2.4 GHz cordless phone
Follow this link.  On the right hand side of the page you will see a box with Owner's Manual.  Hit the English PDF file.  This will then give you the entire owner's manual.  Programming is on page 28.  P.S.  Learn to use the internet to search for these things.  Usually major companies have home pages with links to their owner's manuals.
Posted on Oct 20, 2007
SOURCE: ge phone answering machine
The solution for the base (not the handset) is to press and hold for 2 seconds the "Skip" button (it's marked with ">>").
Posted on Dec 08, 2007
SOURCE: 2 uniden cordless phones aren't working
I don't know if this helps, but perhaps the problem is using two or more phones. On a whim, I charged a Uniden EXP 970 that my daughter gave me a few years ago. Charged right up and it has been working for about two days. I didn't think it would charge at all but to have it actually work, I was amazed!! Will post if it quits anytime soon.
FYI I bought two phones from AT&T, each around $200 and neither of them worked after a week. I was not happy! These less expensive phones seem to do a much better job!
Posted on Mar 06, 2008
  • 1142 Answers
SOURCE: Cordless phones stopped working and digital answering stopped working
May i know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
Posted on Apr 28, 2008
Registering Handsets to the Base
Whichever handset you choose to charge in the base is automatically
registered to the base. Any additional handsets must also be registered to
the base before you can use them.
Be sure both handsets are fully charged.
One at a time, place each handset in the base. The charge/in use LED on
the base begins to flash, indicating the base is registering the handset.
Wait for at least five seconds, then pick up the handset and press
[talk/flash]. If the display shows TALK, the handset is registered. If not,
place the handset in the base to try again.
Press [end] and continue with the next handset.
Once both handsets are registered, it doesn’t matter which
handset is placed in the base or the charger.
When you charge the handsets, Caller
ID summary screen and the name of
the handset appears.
This can be find from uniden website.
Posted on Jul 08, 2008
SOURCE: GE DECT 6.0 GHZ cordless fone (model 28111) don't ring
There is a Do Not Disturb button on the base unit. Press it to turn the feature on and off.
Posted on Jul 09, 2008
0 characters
1 Points
Phone want hold charge long,what to do? i have a ge 25952ee1 5.8 ghz cordless
Remove the battery, wipe the phone contacts and battery contacts with a dry cloth, then reinsert the batteries and check to see if the charge lasts longer. If there's no improvement, it's time for new batteries.
Jan 03, 2010 | GE 25952EE1 Cordless Phone
I have lost my user manuel and I need to reset my Base GE5.8GHz I have a GE 5.8 GHz cordless phone system
Your system must have been rebranded by GE since their page for telephone manuals doesn't have the number listed you gave:
GE Phone manuals
In case you made an error in the model number, you should be able to find your manual there.
Aug 25, 2009 | GE 21091GE3 2.4GHz Dual-Handset System...
I have a GE cordless phone and answering machine, model 27995GE1-A, and finally found where to get a new battery for it. When it is fully charged, is it better to leave on the charger or off, when not in...
Newer phones don't have the battery problems of old. Just to be safe I would leave the phone off the charger after the first call. Put it on the charger when you go to bed.
Jun 29, 2009 | Thomson GE Cordless Telephone 27995GE1
Hi, I have two GE 2.4 ghz cordless phones in my home. The base of the charger always has a blinking red light. That phone doesn't hold a charge very long. It it the battery or the charger? I emailed GE and...
batterys don't normally last long as constant charge with short breaks are bad for them. i'd bet the battery. does that happen with both phones?
\put a multimeter to the pins on the charger. my tongue tests 9 volt batterys
Jun 09, 2009 | Uniden Cordless Phone
How to change the language on the base phone GE 24 GHz
Press the SKIP button for 2 seconds.
This is the 4th or 5th time I've answered this question, so you can search for SPANISH if you want a clearer solution :-)
Mar 23, 2009 | Uniden Cordless Phone
I am having problem with my cordless phone.
Another tip is to remove the battery from the handset for at least 5 seconds. You might want to get a voltage meter and check the voltage on that new battery - maybe it isn't charging properly.
Mar 13, 2009 | Uniden Cordless Phone
My answering system and my instructions are all in won't pick up
is the incoming phone line plugged into the answering machine directly? the answering machine should then be plugged into the phone. the signal comes through the answering machine then to the phone. you may have the connections reversed on the answering machine. check those connections.
Nov 26, 2008 | GE 27831 2.4 GHz Twin Cordless Phone
Reset the answering machine without the manual
GE 28112EE2 1.9 GHz Twin Cordless Phone
Flashing CL.
Lost Manual.
Can you help.
May 23, 2008 | GE 28112EE2 Cordless Phone
The optional handset not working
Yeah, put it on the main charger and let it register. It takes about 15 seconds.
Dec 08, 2007 | GE 25952 Cordless Phone
Brand new cordless handset -- no dial tone, no ring!
I doubt it's the battery. As I understand it the base works fine and the problem is only with a cordless phone. Are you using an external charger stand for the cordless handset? These phones need to be registered to the base unit. That is usually done by installing the cordless phone in the base unit but you may need to do that shortly after insalling the battery or you could have a register button or setting.
Jun 18, 2007 | GE 27851FE2 Phone
Uniden Cordless Phone Logo
243 people viewed this question
Top Uniden Phones Experts
Dave Ellis
Are you an Uniden Phone Expert? Answer questions, earn points and help others
