Question about Datamax DMX-I-4212 Label Printer
Error check supply datamax - Datamax DMX-I-4212 Label Printer
Most likely this has a ribbon, check the settings for how low before warning. http://www.datamax-oneil.com/assets/maint_manual/I-Class_M2_Maint.pdf
go to page 39
Jul 18, 2014 | Datamax Office Equipment & Supplies
Keep getting a check supply error
Slide out the Media Sensor (green plastic bar that sticks out over the labels) about 1 inch from all the way in ("in" = left if looking from front). Then press Feed to clear errors. If still get same error, then look for piece of label or ribbon stuck in that error - ok to blow out with canned air.
Oct 04, 2013 | Datamax DMX-I-4212 Label Printer
Supplies
Hold in the Feed button for 4-5 seconds, which causes the printericon1.png to attempt to "Auto-calibrate." If that doesn't solve it, then slide out the Media Sensor (green plastic bar that sticks out over the labels) about 1 inch from all the way in ("in" = left if looking from front). Then press Feed to clear errors. If still get same error, then look for piece of label or ribbon stuck in that error - ok to blow out with canned air. Then try holding in Feed again for 4-5 seconds to Auto-calibrate again.
Dec 18, 2012 | Datamax DMX-I-4212 Label Printer
My datamax thermal is not heating up
These printers do not "heat up" as such. Possible causes are:
1. Incorrect ribbon type for fitted ribbon spools. Look at back plate and see which way arrows are pointing. If arrows point Anti-clockwise, then you require inside wound ribbon (i.e. standard datamax) If pointing clockwise then you require outside wound (i.e. Zebra type ribbon). Check ribbons by touching sticky side of label to ribbon (it will transfer ink to label on print side).
2. Could also be faulty printhead, Logic board or Power supply. These will require an engineer to check properly.
Jul 05, 2011 | Datamax M-Class Thermal Printer
WE HAVE A DATAMAX CLASS PRINTER AND IT'S GIVING ME AN ERROR " TOP F FORM FAULT" WE DO NOT HAVE THE MANUAL. CAN YOU PLEASE HELP? THANK YOU
Most likely problems:
Wrong sensor set in the media type area. Gap, Reflective.
If the incorrect meday sensor is set, the unit will give a TOF error.
If you hae pressed the feed button and kept pressed for at least 4 labels, and it does not automatically calibrate, check the type of sensor.
If you still get error, and the correct sensor is set, do a complete calibration.
You can downlad the user manual at Datamax-ONeil Web site.
Feb 24, 2011 | Datamax I-4208 Thermal Label Printer
I have a datamax I series and I would like to know how to troubleshoot the stepper motor
What type of problem do you have?
Will the printer not feed?
There has been some troubles on early model of the Datamax I class printers that are detailed in a service bullitin on the driver/power supply.
If the printer feeds intermittently, or runs back wards(hunts) it is probably a board failure. I usually replace the board and the motor on exchange with DAtamax if under warranty.
Jan 21, 2011 | Datamax I-4308 Thermal Label Printer
Dear Sirs, I have a DATAMAX I 4308 ,I am very satisfied with him. Sometimes when I print on low speed after 20 min.labels are printed discontinuosly I had on display MOTOR THROTTLING ,printer stopped...
Motor Throttling is a warning message designed to protect and prevent the power supply and motor from overheating. It occurs after 30 minutes or so of continuous printing and printing slows down to about half the speed. It will eventually go back to printing regular speed, but if it's that much of annoyance it can be disabled under the printer menu under print control. If you wish you can do that.
Jun 05, 2010 | Datamax I-4308 Thermal Label Printer
Position fault error
The Datamax I4308 returns a position fault error if it cannot sense the label gap where its supposed to be, or if the sensor returns a value outside the permitted range. Re-calibrate to correct the error.
Feb 12, 2009 | Datamax I-4308 Thermal Label Printer
Datamax DMX-I-4212 Label Printer Logo
161 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Joseph Mueller
Joseph Mueller
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
