Question about Toymax Magnavox 37MF337B 37 in. LCD TV
Magnavox 37MF337B no power and orange light - Toymax Magnavox 37MF337B 37 in. LCD TV
How to fix my magnavox LCD tv, the picture went out, have sound
Hi Daryl,
This is a common problem with LCD TVs. Back light failure is the cause in most of the cases. I do not think you can do anything about it yourself. Please consult a local TV tech.
Good Luck
May 21, 2015 | Toymax Magnavox 37MF337B 37 in. LCD TV
Tv powers on and after a few seconds turns off. does this several times then will eventually stay on
hi this may be a power board fault, usually capacitors that bulge up or shorted transistor or diode
regards
shaun
Nov 09, 2013 | Toymax Magnavox 37MF337B 37 in. LCD TV
Power board
The replacement power supply could be defective.
Aug 22, 2017 | Toymax Magnavox 37MF337B 37 in. LCD TV
Magnavox turns on then goes off model 37f337b/37f437b
More than likely power board,usually repairable,look for blown capacitors.A blown capacitor will look like the top is rounded also suspect capacitors will show signs of the plastic coating shrinking .
Jan 13, 2013 | Toymax Magnavox 37MF337B 37 in. LCD TV
Magnavox tv turns off by itself
hello, i don't where you live but there are no analogue signals being broadcasted any more. if your in england you will need a freeview box, some tv will switch off if they are not receiving a signal
regardsshaun
May 11, 2012 | Toymax Magnavox 37MF337B 37 in. LCD TV
Sometimes when I turn on my Magnavox 37MF337B tv it emits a very loud squeal and the picture/channel locks up. I cannot turn it off with the remote. I have to unplug it and try again. When it is on though...
you have some bad caps in the mainboard very common on this model the can shaped devices will have a puffed up top i would suggest you have a tech reaplce them they are hard to get out due to the large ground plain on the board you need a good hot iron
Nov 24, 2009 | Toymax Magnavox 37MF337B 37 in. LCD TV
Magnavox model S1MP6100D/37 I have a large screen
there are 2 stk392-120 chips mounted to a large heat sink. both are bad, also 6.8 ohm 1/4 watt resistors are bad . need ohm meter top check these.
Nov 16, 2009 | Toymax Magnavox 37MF337B 37 in. LCD TV
Toymax Magnavox 37MF337B 37 in. LCD TV Logo
20 people viewed this question
Top Toymax Televison & Video Experts
matt martin
matt martin
CoppellTVRepair.com
Are you a Toymax Televison and Video Expert? Answer questions, earn points and help others
