Question about Dometic RM2852 Refrigerator
No power, new install, no light inside or on top
Does the propane have to be connected for it to power up?
    Sergeant:
  • 405 Answers
Even though this unit does plug into a 110ac power supply it also requires 12v to power the circuit boards and the unit will not work with out the 12v. On the back side of the refrigerator verify that the pos/neg 12v wires have been properly connected to the plastic connector block. Next, on the side of the riser tube where the heating elements are located there is a sms thermal switch with two wires going to it. In the center of the thermal switch there is a reset button. Make sure that is set. Then check your fuse inside the coachcoach. If none of these steps do not restore power you will need to check the in line diode that runs from the 12v power supply to the thermal switch. It will be a red wire with a black sleeve over the diode. If the diode is bad you will indicate power to the diode but not after.
Posted on Jun 20, 2014
1996 Onan Propane 2500 Microlite Generator often will not start & dies when microwave is started?
Microwave ovens need to be connected to a separate, dedicated line.
Nov 28, 2013 | Grilling
I just cleaned my jets on my purex mini max plus 400 heater. It is heating great now but has black smoke coming from the top. I think it is rich and is getting too much gas. Is there an adjustment or do i...
First have you always had this connected to propane? There are different models for natural gas and for propane.If you connect a natural gas to propane the "jets" are way too big for propane. How did you clean the jets? IF you "drilled" them out they may be too large now. If you have adjusted the gas regulator, decrease gas pressure. I believe this unit has a combustion blower, be sure it is debris free on inlet and in fan, check for leaves. Make sure black smoke is not coming from debris built up inside of heater. Here is a link to a location for the complete manual for your heater: http://lawnandgarden.manualsonline.com/manuals/mfg/pentair_pool_products/400k_btu_hr.html
Jul 05, 2010 | Pentair Minimax Ch 400,000 Btu Propane...
New Tank won't light Weber Grill
Try checking the regulator, this is the round metal piece connected to the gas line. If this is not level flat the valve inside will not let propane flow through.
Apr 15, 2010 | Weber Spirit? E-310 Propane Grill
We have a Thermador Mod SGCS365RW 5-burner that was new in 2001 and installed for Propane. It has worked fine until yesterday - the top center burner does not get gas to the burner. The igniter works fine....
Hi, if the other 4 burners are working fine, the problem must be in the valve stem. There is a linkage inside the valve body which may have stripped itself. If this is the case you would need to replace the valve.
Feb 04, 2010 | Thermador SGS36GS Gas Cooktop
I believe i am being charged exorbitant fees for connection of my propane tank. situation: I have propane for my range top. There is NO pilot on the range (we light the burners when the propane is turned...
How fast did the propane run out? If there was a leak (which would cause the propane tank to empty a lot faster than normal use) you would be able to smell it. You can check for leaks yourself using soapy water; apply soapy water to the connection and look for bubbles...bubbles means there is a leak...no bubbles means everything is good. I think you got ripped off but I won't know for sure unless you can tell how fast the propane ran out.
Nov 23, 2009 | Grilling
DCS commercial range #36-6-1L running propane. 6 burner tops light fine, but the oven has just stopped lighting after 7 years. When I try to relight the pilot light (depress red button, click cliker) it...
You might need a new thermocouple. The thermocouple tells the oven that the pilot is lit and that it is ok to let gas into the oven. It is the metal rod that is connected to the pilot. They are fairly cheap and easy to install.
Jul 06, 2009 | DCS RGS-305 Professional Gas Kitchen Range
Tank-top propane unit won't stay lit
I had to replace the regulator. If you have a propane appliance shop near you, you can probably just get the nipple that goes into the bottle. It's aboit 3/16" diameter, 3/4" long and may have a 6 sided end up inside the screw on cap of the regulator.
Feb 24, 2009 | Mr. Heater Model MH12TS - Single Tank-top...
Gas Range Oven use without electrical power
It will be necessary to change the top burner orifices when converting to propane. You should be able to light the top burners with a match or lighter, however, the oven will need proper operating voltage.
May 22, 2008 | Amana Ovens
Burner flame height adjustment
All ignitors will always arc whenever one of them does.
I haven't worked with propane systems much, but it seems you may need the propane pressure regulator adjusted.
If the problem is only with the power burner, I would ensure that particular orifice was actually changed. The hole in a propane orifice is smaller than for natural gas.
Jan 08, 2008 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Dometic RM2852 Refrigerator Logo
101 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
