Question about Kenmore Refrigerators
Kenmore 106.5942 freezer works but fridge does not
My side by side kenmore 106.5942*801 fridge stopped working. The freezer and the fan below runs fine. There is no ice build up anywhere but the fridge barely stays cold on max setting. Any help?
Trifect7
  • 57 Answers
SOURCE: refridgerator not very cold
It could be some many things, to save time let me give you this check list:
Do what you feel qualified to do.
If you found this helpful please Vote. Good Luck!
Posted on Mar 04, 2008
SOURCE: Freezer is staying cold (below 0), but Fridge won't cool
Failure to stay cold
Posted on Jul 23, 2008
deby69
  • 16 Answers
SOURCE: whirlpool side by side freezer not working fridge is fine
Pull out the fridge and unplug. Remove the back cover. Clean the condenser coils and fan. If they're difficult to get to, use compressed air to blow out. (you can get a can from walmart). That should fix the problem. If that doesn't work, then write back.
Doug
Posted on Jan 05, 2009
peyton32034
  • 410 Answers
SOURCE: Ice maker stopped working, plus fridge not cold, but freezer o.k.
I would check that fan motor in the freezer section is running. it distributes cold air from freezer into refrig section also if this motor is running the top portion of freezer will not get cold enough to allow ice production. the motor is easy to repl and is mod# specific you should be able to buy one online.
Posted on Jan 21, 2009
  • 17 Answers
SOURCE: ice build up on coil inside freezer
it can be two things the refrgerator probably has a small refrigerant leak therefore it ices up, or the defrosting heater on the begining of the coil is faulty.
Posted on Feb 10, 2009
Kenmore side by side fridge. Green temp light flashing for fridge side, freezer side working fine. Fridge side not cooling.
possibly frosted up at the air door between the fridge and freezer, or the fan in the freezer is not pushing cold air into the fridge side, if you can not hear a fan running in the freezer when the fridge is running (compressor on) then change out the fan
Jul 18, 2011 | Kenmore Side by Side Refrigerator
Freezer side works fine. Fridge side not as cold as should be. Fan is working on freezer side
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jun 16, 2010 | Kenmore 44109 / 44102 Side by Side...
Kenmore fridge. freezer top works, but bottom doesn't.
Either your fan has stopped working, or it is not defrosting. Take the back panel of the freezer off and see if the evaporator coil is iced over, if it is replace the deforst heater, and the deforst thermostat. If the compressor is running the fan if the freezer should be running. Also make sure both your fridge and freezer controls are centered. Putting the freezer on the coldest setting acutally shuts off airflow to the fridge.
Dec 05, 2009 | Kenmore 71192 / 71194
Kenmore fridge not cooling
try www.partselect.com
would help if you had a part number
Sep 30, 2009 | Kenmore 53642 / 53644 Side by Side...
New Kennmore side by side freezer works but refrig is warm
Do you hear the fan running in the back of the compartments when either door is open? The freezer side runs the fridge side and a fan transfers the cold air from the freezer to the fridge side. If the fan does not run or there is a blockage then the fridge side will not get cold of course.
Sep 29, 2009 | Kenmore Refrigerators
Freezer gets 10 below 0 and fridge is 60 degrees
Check and clean the condensor coils. Make sure the air ducts are free f frost and not blocked by anything. Make sure the light is turning off when the door is closed.
Eric
Sep 28, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice melted and fridge not cold enough kenmore 363.50622000
Several things possible - fan in freezer side not running, defrost thermostat not working, if fan runs and cuts off & on, then the defrost heater strip could be out, but check the defrost timer under fridge; not cycling, you can manually turn to see if fan cuts off and on. If you have "ice shelf" in coils on freezer side then no air circulates in freezer and over into refrigerator side.
Aug 14, 2009 | Kenmore Refrigerators
Side by side freezer cold fridge not
the freezer may be overload or poor air circulation inside the freezer
Mar 10, 2009 | Kenmore Refrigerators
Jan 21, 2009 | Kenmore 64802 Top Freezer Refrigerator
Kenmore Side by side model # 25357682790
is the freezer fan working?is there frost in the freezer on the walls?can you find the defrost timer?let me know and we can go from there-mike
Oct 15, 2008 | Kenmore 53542 / 53544 Side by Side...
Refrigerators Logo
57 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
