Question about Daewoo DTQ-29S1FCN 27" TV
TV picture size is too large for the screen - Daewoo DTQ-29S1FCN 27" TV
The picture from my fire stick is too large for the screen. The picture from my regular tv, cable and dvd are perfect. I need to know how to adjust the size of the picture.
adjust the size of your tvs picture with your tv remote. Hit mode and select desired size.
Bitcoin donation address: (anything helps!)
1BxGnavhUFra5zsuq2bdQJSz1HcFyGn8Za
Feb 28, 2017 | Televison & Video
How do I change the format on the screen to fit my TV, the format is too large and the picture is getting cut off on both sides
U using the tv original remote wright?Yes.Check ur tv remote control for a button like View Mode,Aspect Ratio,Picture Zoom,P.Size.Pushes one of these buttons to ajust the tv picture screen sizes.
Mar 25, 2011 | Televison & Video
Picture too large for screen
It appears that on this television you can only adjust the picture size when you are using the twin picture feature. You must adjust the picture size with your other remote control. Since I do not know whether you are connected to a cable box or a satellite tv box or a blu ray player or a DVD player I cannot be very specific. On your other remote control you should had an hd zoom button, aspect, format, ratio, #, or etc. Those buttons change the picture size. The other factor determining picture size is the resolution the equipment connected to your tv is set to. This tv supports 1080i but you should also try setting the connected equipment to 720p or 480p or 480i. Also the connected equipment may be connected to your tv in two places so make sure you are on the correct selection using the tv video button on the Sony remote.
May 06, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
PICTURE TO LARGE FOR THE SCREEN AND ZOOM ISNT FIXING IT
Your TV set may have settings for picture size ratios but also if you have cable or sattelite service, they too may have these settings. Try both TV and cable remocons for proper adjustment
Jul 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Ilo lcd tv..picture too large??
I had the same problem and tried everything with the tv to get it back to normal. I would look for what was suggested by tvtek, but also look on your cable remote or box for an "aspect" button. That fixed my problem. If your problem occurs with DVDs as well then you may have another issue, but if it is with cable only, try this. When I called our cable company the tech said alot of people this button without even knowing it.
Feb 26, 2008 | Televison & Video
JVC AV2649S Picture Too Large
you can see the diagnostic menu in jvc as you press both at the same the display and the picture mode buttons
Oct 17, 2007 | JVC AV27F476 27" TV
PT5499HD Covergence Akai
Yes, you have a size problem you have horizontal and vertical size. Either its' in the service mode or somewhere on the set, with this set it's probably in menu. Must be set too high. I will look for menu codes! Is this an Akai or Panasonic set?
Oct 04, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Daewoo DTQ-29S1FCN 27" TV Logo
24 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
