Question about Phase One Capture One Pro Full Version for PC, Mac
Capture One Pro 7 - Phase One Capture One Pro Full Version for PC, Mac
Hello my name is Ron G. My girlfriend purchased this ....VIDEO CAPTURE CARD ADAPTER USB TV DVD AUDIO EASYCAP VCR TO COMPUTER cvr from e-bay.... for my Christmas gift. I have windows xp pro, Pentiu
It sounds to me like Windows has not detected the device. Make certain it is connected then check the device in windows to see if it is working properly. It might need a driver update etc.
Dec 27, 2013 | Computers & Internet
Tip
Final Cut Pro X Review-No Log and Capture or Log and Transfer?
The newly released Final Cut Pro X is now a hot topic, especially among the FCP 7 or 6 users. The UI of FCP X is different from the older versions. The style change is somewhat like how Adobe Premiere Pro CS4 differs from the older versions. In the other words, it is from grey to black. Of course, Adobe Premiere Pro is different form FCP. <br /><br /><b>How would FCP X change the video editing on Mac?</b> <br /><br /><b>- No Log and Capture , Log and Transfer</b>: <br />With FCP 7 or below, the Log and Capture option is to import tape-based videos, while the Log and Transfer option is for file-based camcorder videos. If you have mini-dv like Sony HDR-FX1S, you may need another tool to capture and save videos as a file, and then import to FCPX. <br /><br />For videos from file-based camcorders, the process is like working with iMovie. The Camera Import window should pop up when camera is connected to Mac for you to select clips. Then click Import Selected, or the like button to load videos. Even though FCP X is supposed to import AVCHD files in .mts or .m2ts format, there are still users reporting the problem. If that is the case for you, you may need to transcode AVCHD to QuickTime MOV for FCP. Aunsoft <b><a href="http://www.aunsoft.com/final-mate-mac/">Final Mate for Mac</a></b> would help you make the videos compatible to FCP X. <br /><br />If you use Canon XF100 to shoot videos in .mxf format, or other camcorders with MXF files, just try Aunsoft <b><a href="http://www.aunsoft.com/video-converter-mac/">Video Converter for Mac</a></b> to see if it works for your .mxf video footage. <br /> <br /><b>- <a href="http://www.aunsoft.com/news/final_cut_pro_x_review_-_no_log_and_capture_or_log_and_transfer.html">No transcoding to ProRes</a></b>: <br />As it is known that the videos imported via Log and Transfer would be transcoded to Apple ProRes. User should wait for the transcoding before editing. It is said that Final Cut Pro X would grant you access to your material right away, saving a lot of time. <br /><br />Actually, there is also timeline for <b>editing in FCP X</b>. But the layout is different from the previous versions. The audio would be snapped to the video. You may find out more interesting features and get used to it.
on Jul 15, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Not recognised by Adobe Premiere Pro 2
It might be that you are trying to capture a signal, when the software is set to capture another form of signal. Try switching the format of the capture on Adobe.
Mar 26, 2013 | Panasonic AG-DV2700 Mini DV VCR
Hi, My operation system is Windows 7 (32) bit. I can't install My Pinnacle Pro-One RT-DV hardware on it. Please assistance me to setup this hardware on my OS. thanks.
The best solution is make a XP partition or install a Virtuall machine whit XP, W7 or W8 cant detect the hardware, drivers not are compatible.
Feb 27, 2011 | Pinnacle Pro-ONE RTDV Video Capture
Is that this card(canopus acedvio pro version) any problem with windows 7
MPN 770-10116-900
Adapter Type Video Capture
Interface with Host PCI
Video Input Composite Video • i.Link (IEEE1394)
Video Output Composite Video
Platform PC • Mac
Hey no problem....It is best for Video capture...the datails are this.... i still useing it.........
Technical Features
Audio Support Stereo
System Requirements
Operating System Apple MacOS 9.x or later • Microsoft Windows 2000• Microsoft Windows XP Home Edition • Microsoft Windows XP Professional
Warranty 3 Years
Included Accessories 1 x Firewire (IEEE1394) Cable • Composite to S-Video Cable
Nov 18, 2010 | Canopus ACEDVio/EDIUS Pro 3 Bundle...
How do you capture video? Live Cam notebook pro
go to computer then click your camera then click record to record video
Aug 02, 2009 | Creative Labs Live! Cam Notebook Pro...
ATI RADEON X600 ProGraphic Card can't capture video
no it is not a Video input device it is video out put device. You buy avermedia internal TV card and capture video
Jun 29, 2009 | ATI RADEON X600 Pro, (128 MB) PCI Express...
I can't figure out how to get adobe premier pro 7 to capture!
FIRST INSTALL ANY FIRE WIRE CAPTURING CARD & THEN CONFIRM THAT IT IS PROPERLY INSTALLED & HARDWARE IS DETECTED. AFTERWARDS WHEN U WILL ATTACH UR HANDYCAM WITH YOUR CAPTURING CARD YOUR CAMCORDER WILL BE DETECTED AUTOMATICALLY & THE WINDOW WILL OPEN & WILL ASK YOU THROUGH WHICH SOFTWARE YOU WANT TO CAPTURE THEN SELECT ADOBE PREMIERE THEN OPEN ADOBE PREMIERE GO TO FILE MENU & THEN SELECT CAPTURE THEN U CAN PLAY , REWIND OR FORWARD TOTAL FULL CONTROLL OF CAMCORDER WITH SOFTWARE ,TO CAPTURE CLICK RED BUTTON,IT WILL START UR CAPTURING,GIVE THE FILE NAME & DESTINATION WHERE U WANT TO SAVE THE FILE THEN START CAPTURING.
Mar 22, 2009 | Adobe Premiere V 7.0 Professional for PC
How Do I Capture Live Audio with M-Audio Fast Track Pro
All you have to do is to connect with 2 cables your cd's or dvd's output to the two 1/4” TS plus in the front side of the Fast Track Pro and a usb cable from the rear panel of the Fast Track Pro to your pc's usb port. I suppose that you have installed the drivers for Fast Track Pro at your pc.
Anyway in case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Aug 31, 2008 | M-Audio Fast Track Pro Mobile USB...
Phase One Capture One Pro  Full Version for PC, Mac  Logo
Top Phase One Computers & Internet Experts
David Payne
David Payne
Are you a Phase One Computer and Internet Expert? Answer questions, earn points and help others
