Question about NATURE POWER Naturepower Nemo 400W 12V Wind Generator
The wind will not turn the blades even at 10mphs
I haave eleven of the things , some with wide blades and some with narrow blades, it just seems like there would be a replacement blade that is wider to gather more wind,, so I added a wider girth to the blades using a plastic cardboard and it worked better, are there replacement blades to buy??
    Novelist:
  • 89 Answers
If you have too much weight from wider blade, check to make sure there is not too much pressure on the bearings to operate properly.
Posted on May 12, 2018
I have a TS300 table saw and the blade does turn immediately when power upped, the blade speed seem low, and the blade easily stall when cutting - even 1/4" ply.
There are two windings in the motor, a starting winding and a running winding. There's also a centrifugal starting switch in the motor that switches from the starting winding to the running winding once the motor gets up to speed. Sometimes the switch can get stuck and you almost have to give the blade a spin with your hand to get it moving-- and then it moves slowly till it picks up speed.
A rating on that saw complains it doesn't have a whole lot of power, but yours doesn't sound like its under-designed -- it sounds like there's something wrong. Does it smell hot when running? Does the arbor turn freely? Are you using a long extension cord? (dont!)
I hope you don't need a new motor ($255)
If you do, I'd sell the thing for parts on CraigsList and look for another saw in the same place. I bought one table saw on craigslist for $60 and another for $45. (You might have to watch the listings every day for a year or so to get those kind of prices.) Both of the ones I bought are belt-drive contractor's saws with a 1.5 hp motor outside the box on the back side of the saw.
Oct 17, 2014 | Saws
Wire conections for ledu magnifer flourscent lamp?
The narrow blade is the hot or black wire and the wide blade is your neutral neutral. Use an ohm meter, connect one of the ohm meter probe on the wide blade and the other meter probe on the end of each wire. which ever one gives you a reading is the neutral or white wire. You may want to next time, label the wires before you disconnect them.
Sep 05, 2014 | Ledu Corporation Home
My problem is the recepticle that you plug your light in for the timer burned
Replace receptacle.
buy new receptacle.
Turn off power.
Pull out receptacle.
Connect black hot wires to side with narrow blade.
White neutral wires to side with wide blade.
http://waterheatertimer.org/images/Outlet-polarity-200.jpg
http://waterheatertimer.org/images/Switch-quick-connect-400.jpg
Sep 13, 2012 | Hampton Technologies Brinks Timer
Light switch wiring
Yes.
The code is maximum 12 boxes per circuit breaker.
You can connect a 12-2 NM W/G cable to one of the outlets. Black-to-black and white-to-white and ground-to-ground. Black is hot, white is neutral, and ground is ground. And bring that cable into a hollow-wall box you install 50" high on the wall. Then run the 12-2 cable up to your light fixture.
http://waterheatertimer.org/images/GE-15312-single-a-300.jpg
http://waterheatertimer.org/How-to-wire-switches.html
http://waterheatertimer.org/OWB1.html
You can also replace one of the outlets with a combo switch-outlet. The run singe 12-2 cable up to light.
This wiring diagram shows half way down how-to-wire-switches page.
Outlets have wide blade on neutral side, and narrow blade on hot side.
The black hot wires from old outlet connect to side of combo device with narrow blade.
The white neutrals from old outlet, and new wire going to switch, all connect to silver screw on wide-blade side of new combo device.
The black wire going to new light connects to screw next to switch located on wide-blade side of device.
Aug 28, 2012 | Electrical Supplies
The Brinks Model 42-1014 fails after a few weeks. The motor that turns the timer dial is not strong enought to trigger the on switch. I can move the dial by hand to turn it on and it does turn off but...
I agree.
I test timers.
Brinks timers are near lowest quality of all timer brands, yet all timer manufactures sell lower end products to meet price points. Brinks are probably made by one of the bigger brands.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Brinks
http://waterheatertimer.org/GE-timers-and-manuals.html
http://waterheatertimer.org/UPM-timers-and-manuals.html
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
http://waterheatertimer.org/How-to-set-timers.html
Test your outlet with cheap circuit analyzer from box store to make sure that polarity of outlet is not reversed. Notice that Brinks timers, like most plug-in timers, have polarized plug.
Polarized plug has wide and narrow blades so they plug into outlet correctly.
Wide blade is for Neutral, and narrow blade is for Hot.
If outlet has polarity reversed, this will adversely affect timer motors, and other appliances.
Jun 23, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Blade will not stay on cutting mark, even a straight line. My blade looks like a quarter inch on a nine inch band saw.
clean dust off the wheels, center the blade get it tracking and tension it so it has a medium high to (wide blade) high pitch (narrow blade) twang like a guitar sting when plucked with the saw turned off
Feb 19, 2011 | Ryobi 9 in. Benchtop Band Saw
How to install Pass & Seymour 5410CC10 sp2 cord switch on a torchiere lamp? Can it be used the same as an sp1 switch?
The cord that runs to your light contains two wires.
The cord switch interrupts one wire.
The second wire runs uninterrupted between wall plug and light.
The photo below is not the same switch as yours, but it shows how one wire is interrupted and the other wire is uninterrupted.
Which wire do you want to interrupt?
Look at the wall plug.
Is the plug polarized, where one blade of the plug is wider?
If the plug is polarized, then one blade is wide and the other is narrower.
Each blade of the plug feeds one of the two wires going to lamp.
Locate the narrower blade, and the wire that comes from that side of plug.
The narrow-blade wire is the wire you want to interrupt when installing the cord switch.
If the plug is not polarized, then choose one wire.
Nov 08, 2010 | Pass & Seymour 5410CC10 Black Feed Cord...
Cutting 45's on my Dewalt 744
Narrow throat plate should work. Sure you have the blade installed correctly with arbor washers?
Feb 28, 2010 | Dewalt DW744S 10" Portable Table Saw with...
Blade Types
remember to match the blade width to the type of cutting you are doing. Also keep in mind: * Narrow Blades can make much tighter radius cuts, but tend to twist and wander when making long straight cuts. * Wide Blades can't make the tight turns that narrow ones can, but they hold a straighter line than their narrow counterparts. * The tpi determines the speed with which the blade cuts through stock. Blades with high tpi cut slower but leave a very smooth edge. They are best for detail work on thin stock. Blades with low tpi cut quickly and leave a slightly rough edge. They are great for resawing or long rip cuts. * Steel Blades are inexpensive and work well for cutting softwood. Steel blades, however, dull quickly in hardwood. * Bimetal Blades are made of high-speed steel and can cut thin metal or wood. * Carbide Blades are for wood cutting only. They are more expensive than other blades but stay sharper longer than steel or high-speed steel.
Aug 27, 2008 | Dewalt Variable Speed Deep Cut Band Saw...
Blade width usage
Blade Width is important when purchasing a band saw. Most saws accept narrow 1/8" blades for cutting detailed designs and tight curves. Better saws also accept wider blades. Wide blades don’t flex as much as narrow ones, but they make accurate straight cuts in thick stock quicker. There are also some wide blades available that can cut metal.
Aug 27, 2008 | Milwaukee Tool Milwaukee 6230 Deep Cut...
NATURE POWER Naturepower Nemo 400W 12V Wind Generator Logo
506 people viewed this question
Top NATURE POWER Renewable Energy Experts
Greg Scott
Greg Scott
Kelly C
Kelly C
Level 1 Expert
Brian Lee
Are you a NATURE POWER Renewable Energy Expert? Answer questions, earn points and help others
