Question about Furuno FS1503 (199 Channels) 2-Way Radio
Ham mhz 5990a
Howm do you go frojm low power to high power??
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 129 Answers
How to select tuning range between 430-440 MHz and 440-450 MHz Yaesu FT-790RII?
Try www.mods.dk. They have tons of free manual downlods and mods for HAM radio and other equipment that hams use. It's the BEST online source for this type of information.
Apr 27, 2014 | Radio Communications
How do I increase power output for a cobra 148 gtl the latest Chinese version
best way is to leave the radio in piece and obtain a linear amplifier to do the job a 10 meter ham radio amplifier will do nicely but you must re-tune it for the 27 mhz band 10 meter band is 28 mhz.
RF amps work best using side-band mode.
Oct 14, 2013 | Cobra 148 GTL 120-Channels Base CB Radio
My connex 3300 will not lock on correct frequency it either goes to 25 mhz or 28 mhz
Turn the BAND knob (under the RF power selector switch) in conjunction with the High Low selector switch to choose band A, B, C and in the other position D, E, F. A listing of frequencies that can be tuned in this manner can be found by clicking the link below:
http://hotspotcb.com/charts/freqchar33.html
A few words of caution.. the FCC takes a very dim view of unauthorized use of frequencies. The only range of frequencies that you can legally use without an FCC issued license (in the U.S. anyway) are those in Range D. If caught transmitting on any of the other frequencies without the proper license(s) fines and imprisonment may result. No one ever expects to get caught - but plenty do. If you'd like to gain the use the 28Mhz and up frequencies, check out:
http://www.arrl.org/licensing-education-training
Amateur radio is not shackled by channels, power limits less than 1500 watts nor limited to AM and SSB modes. Check it out! Good luck!
Jan 06, 2012 | Connex Radio Communications
LOST MY MANUAL TO MY UNIDEN BEARCAT BC142XL CAN I GET A FREE REPLACEMENT
The manual isn't online to my knowledge however I did find a guide on how to program it.
"Turn it on. Push the "MANUAL" button to stop it from scanning.
Push number 1, then push "MANUAL" again. This should leave you on
channel one.
Using the keypad enter the frequency you want to monitor, then push
"E." Press "REVIEW" at anytime to see what frequency is programmed
there. If the review button flashes 000.0000 on the LED readout
display, you might be entering an invalid frequency. Refer to the list
of acceptable frequencies in the Frequency Range Bands below.
Push "MANUAL" to step to channel number two. Enter the frequency. Push
"E." Push "MANUAL" to step to channel three. Repeat this process until
all the (10) channels are full, or you've run out of frequencies to
enter.
Push "SCAN" to start automatically scanning the frequencies. The
radio will stop when it hears someone talking, and resume scanning two
seconds after the conversation has stopped.
Frequency Range Bands:
20 to 29.7 MHz (10 Meter "Ham" Band)
29.7 to 50 MHz (VHF Low Band)
50 to 54 MHz (6 Meter Amateur Band)
136 to 144 MHz (Military Land Mobile)
144 to 148 MHz (2 Meter "Ham" Band)
406 to 420 MHz (Federal Government Land Mobile)
420 to 450 MHz (70cm "Ham" Band)
450 to 470 MHz (UHF Standard Band)
470 to 512 MHz (UHF "T" Band)"
http://newsgroups.derkeiler.com/Archive/Rec/rec.radio.scanner/2006-01/msg00174.html
Hope this helps.
Apr 22, 2011 | Office Equipment & Supplies
My yaesu-ft1500m have a bad RX on low frequency's and the RX is bether on higher frequency's, but on 144-146 MHZ RX is bad and on higher like 150 mhz is bether than 146, and on 160mhz is bether than 150,...
Sensitivity is a function of the rec rf amp and detector.selectivity is a function of image rejection and oscilator tuning accuracy. You have a good unit, needs aligned properly and troubleshot for bad components in reciever cktry
May 15, 2017 | Cell Phones
PROGRAM FREQ IN BC142XL
Its so easy to use you really don't need a manual for the Uniden BC
142XL scanner.
Turn it on. Push the MANUAL button to stop it from scanning.
Push number 1, then push MANUAL again. This should leave you on
channel one.
E. Press REVIEW at anytime to see what frequency is programmed
there. If the review button flashes 000.0000 on the display, you might be entering an invalid frequency. Refer to the frequency coverage list below.
Push MANUAL to step to channel number two. Enter the frequency. Push E. Push MANUAL to step to channel three. Repeat this process until all ten channels are programmed, or you've run out of frequencies to enter.
Frequency Coverage:
For a comprehensive database of active frequencies in your area, visit
www.RadioReference.com
Nov 07, 2009 | Uniden BC248CLT Base Scanner
How do i get expanded freqs on my ft1802 yaesu tranceiver
The FT-1802 is a 50 watt 2 meter FM transceiver. It can transmit anywhere between 144 - 148 Mhz (the FM portion) of the 2 meter ham band. It can receive anywhere between 136 - 174 Mhz without any modifications. There is a modification to enable transmit "out of band" below:
http://www.ham.dmz.ro/yaesu/ft-1802-extended-transmit-modification.php
There are few details about the results of this mod - typically these provide for transmitting on frequencies outside (above, below or both) of the 2 meter ham band. Transmitting outside of the ham band without a proper license for the frequencies in the U.S. is a violation of FCC rules.
Sep 08, 2009 | Yaesu Radio Communications
Need a free printable user manual for Bearcat scnner BC142XL
Its so easy to use you really don't need a manual for the Uniden BC142XL scanner.
Push number 1, then push "MANUAL" again. This should leave you on channel one.
Using the keypad enter the frequency you want to monitor, then push "E." Press "REVIEW" at anytime to see what frequency is programmed there. If the review button flashes 000.0000 on the LED readout display, you might be entering an invalid frequency. Refer to the list of acceptable frequencies in the Frequency Range Bands below.
Push "MANUAL" to step to channel number two. Enter the frequency. Push "E." Push "MANUAL" to step to channel three. Repeat this process until all the (10) channels are full, or you've run out of frequencies to enter.
radio will stop when it hears someone talking, and resume scanning two seconds after the conversation has stopped.
If this helps, please take a moment to give us a rating -- and a rating of "very helpful" would be greatly appreciated.
Sep 06, 2009 | Uniden BC-95 XLT Scanner
Furuno FS1503 (199 Channels) 2-Way Radio Logo
66 people viewed this question
Top Furuno Radio Communications Experts
Clint Millett
NOEL
NOEL
Are you a Furuno Radio Communication Expert? Answer questions, earn points and help others
