Question about Stanley Tools & Hardware - Others
Staples dont go in - Stanley Tools & Hardware - Others
Staple gun is loaded stapled 6 now no staples coming out
its probably blocked at the end were the staples come out you need to push this back, depending on models there is some with 2 red plastic bits you grip and push it back to open up to clean out the steppes some others you need a flathead screwdriver and prize the gap open to clean it out, dont do this with the cartridge in or the spring. remove the bad staple or staples and try it again .
Jul 02, 2017 | Tools & Hardware - Others
How do I reset to just basic adding
Dont know what you are saying.
Basically turn it off and on if your stuck.
Jan 05, 2016 | Staples SPL-250 10-Digit Display...
Put new staples in my Rapid 34 and some come out but in the beginning they dont. Why?
Hi Anonymous,
Have you bought the genuine RAPID branded staples for the 34 tool? If not that is the reason. There are a lot on manufacturers that use the same series numbers but they aren't the same wire size. 30 thousands of an inch can be enough to stop the staple working through the tool.
Having said that, if they are the genuine article, does the spring and pusher work correctly? (the thing that you put in the back of the tool to keep the staples in place)
Mar 01, 2015 | Staples Tools & Hardware - Others
What Staples does a swingline 34301 Electric Staple Gun take?
That's an easy one
Use the Arrow 600 series staples. heres the link to the different sizes available.
http://www.arrowfastener.com/catalog/supplies/staples/600-series
Good luck and don't forget to rate me :)
Aug 09, 2014 | Staples SwinglineĀ® 36115 Staple Guns Tools...
Primo Staples 960/101
Hi sue I don't suppose by any miracle that you still have the primo staples?
Nov 20, 2011 | Vanguard (TRACKER4) Tripod
Stapler is jambed
a staple is probably jammed in between the housing and the ram look at the bottom front where the staples are ejected you may need a small screwdriver to reach up inside and loosen the staple from the ram ... a little WD-40 may help also ... dont forget to rate me thx:)
Oct 01, 2009 | Arrow T50P ARROW STAPLE GUN
How do I load staples into the Minolta Di 2010f copier?
Follow instruction on door. Push in on both sides of staple cart pull the top up install the new staple pack dont pull string on staple pack until its inside. (Staples on the floor:)) Don't throw away the plastic cart itself insure the arrows on the new staple pack match the direction on the old run or the staples will be upside down and not able to get out of the pack
Aug 17, 2009 | Minolta DI-2010F Copier
Electric stapler won't staple???
hi there. i hope i can help you? what you need to do is open the stapler up check for any stuck staples? where they come out. dont put two many in at any one time. please make sure you are putting the correct staples in? is there a sound when in normal use? if yes it may well be a blockage. also check the fuse in the plug just in case ? i hope this will help you,
May 01, 2009 | Kitchen Appliances - Others
Tools & Hardware - Others Logo
16 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
