Question about Duo Fast Duofast Cn350 Cn350b Sh Nailer O Ring Rebuild Kit
Adjust foot depth Durofast nailer
Depth adjust
How to adjust depth on bostich mk111fs
There is no depth adjustment on this tool -
If the staples are going too deep - most likely the piston (#17) has threaded off the driver inside the tool, you have a broken piston bumper (#62) inside, or the teflon foot pad (#56) on the bottom of the tool is the wrong thickness for the flooring you are using.
If the staples are not driving far enough - most likely you have a broken / chipped driver blade (#21) or the teflon foot pad (#56) on the bottom of the tool is the wrong thickness for the flooring you are using.
Detail
Sep 01, 2014 | Stanley Bostitch MIIIFN Flooring Nailers
SETTING SHORT NAIL DEPTH
If you have tried the depth adjuster lowest setting and still too high, try lowering the pressure to the gun. The shorter nail does not give enough resistance allowing the driver to slam against the lower bumper inside of the gun (made of rubber or vinyl) forcing it to compress. There might be a rubber protector that installs on the safety foot of the gun that will space the gun away from the work another fraction of an inch. Finally, you could use a thin piece of wood under the safety foot /nose to space the gun away from the work. Good luck
Apr 05, 2013 | Tools & Hardware - Others
Adjust depth on pneumatic stapler
I have noticed that many nailers do not have a way to adjust the depth. Usually there is a thumb screw under the trigger or on the side of the safety foot. If no visual way to adjust, you must get creative. The bumper stops the driver at the bottom of the cylinder. Adding layer of rubber (inner tube or similar) under the bumper will cause the driver extend less and shaving the bumper will cause it to drive deeper. Another method if to add material to tip of safety to space gun away from work (less deep, using various thickness of spacers like used on flooring nailers) or grind the tip of the driver (cant reverse but if driver is too long grind away) . Buy a spare driver and make adjustment to tip for when you need different setting. Good luck
Aug 28, 2012 | Surebonder Stapler. Pneumatic 1/4 in....
How do i control the depth the nail shoots in a bostitch coil nailer
The bostitch nailer pictured along along with your question is a RN46 roofing coil nailer. It has a dial on the front of the nose for adjusting depth. Some older nailers (roofing nailers) do no have a means of adjusting so were set at the factory for best performance. The question of depth usually comes up when lower bumper fails and the nail is driven too deep. Easy test. Remove nails and find a very soft piece of wood. Dry fire the gun against soft wood and measure how deep the driver is entering the wood. Harder test. Remove the head and use any handy tool to push driver down to bottom. Measure how far the driver extends past nose (should be about 1/8 to 3/16). If more, replace the lower bumper. Good luck
Jun 21, 2012 | Stanley Bostitch Nail Gun
Adjust nail depth 350 mag framing nailer
To adjust the depth of the nail on the coil 350, refer to the parts list listed below.
The safety foot, refrence # 430 or part # 904930 has a slot head bolt. Back off the bolt and move the safety foot down or up and retighten. If however the adjustment will not move enough to keep the driver from setting the nail too deep, then suspect that the bumper, refrence # 130 or part # 897337 has failed and is allowing the driver to travel down the cylinder further than normal. Easy fix. Remove the head and pull out the cylinder and driver to change the bumper. Good luck
http://www.ereplacementparts.com/porter-cable-coil350-type-coil-nailer-parts-c-129_1658_2177.html
Oct 10, 2011 | Porter Cable COIL350 3 12" Magnesium...
How to adjust double shot for Hitachi nail gun
The condition of the driver oring is an indication of wear of all the other orings in the gun. Remove the nails and lightly tap the nose against piece of wood. If the driver drops to bottom of cylinder the oring is worn out and time for oring kit. Hitachi nailers are sensitive and will double fire if placing the foot against work then depressing trigger. Adjust the depth thumb screw several turns either direction then depress trigger and quickly bump gun against work. Good luck with your repair.
May 03, 2011 | Hitachi NR83A2 Framing Nailer Full Head...
I have been installing a treated pine deck, but the nails are been driven in to far, i have tried adjusting the pressure from the compressor but have had no luck is there a depth adjustment on the gun?
Yes, there is a depth adjustment. Most of the Bostitch models have a push button on the left side near where the nails come out. With the air unplugged, push in this button and you can slide the head assembly up or down to make your adjustment. Slide it out for less depth. It sounds like maybe yours is fully seated, providing the maximum depth.
Dec 13, 2010 | Stanley Bostitch Coil Framing Nailer
How do i set the depth
I have a older Hitachi 3 1/2 full roundhead nailer and on my there is a button on the front below the head at the end of the nails that you push sideways and hold and slide the nail gun tip up or down. There should be grooves across the front of the tip.
Oct 12, 2010 | Hitachi 3 - 1/2" Full Roundhead Framing...
I have dewalt dc618, nail doesn't goes all the way in, please help?
Below find information on how to adjust for depth, however if you have already made adjustment then check for broken tip on driver blade. The blade is not expensive and available from dewalt service center.
Please note the following from manual:
Adjusting Depth
The depth that the fastener is driven can be adjusted using
the depth adjustment wheel (C) on the side of the tool.
WARNING: To reduce risk of serious injury from
accidental actuation when attempting to adjust depth,
ALWAYS:
• Remove battery pack.
• Engage contact trip lock-off.
• Avoid contact with trigger during adjustments.
1. To drive the nail shallower, rotate the depth adjustment
wheel (C). There are twelve depth settings, 1 being the
shallowest and 6 being the deepest.
2. To sink a nail deeper, rotate the depth adjustment
wheel (C) to a higher setting.
Sep 08, 2010 | Dewalt DC618KA Angled Nailer Kit
Duo Fast Duofast Cn350 Cn350b Sh Nailer O Ring Rebuild Kit Logo
79 people viewed this question
Top Duo Fast Air Tools & Compressors Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
yoopertech
Are you a Duo Fast Air Tool and Compressor Expert? Answer questions, earn points and help others
