Question about Panasonic PT-61LCX65 61" Rear Projection HDTV
How do i reset the lamp on my Panasonic HDTV 1080i
2 Suggested Answers
SOURCE:
  • 13 Answers
SOURCE: Panasonic HDTV 1080i Lamp out
If the lamp is actually out - replace it - if the lamp is still working just reset the lamp hours - at 10,000 hours it automatically says that but it is just the lamp time needing a reset.
Posted on Jun 02, 2009
Does my panasonic hdtv 1080i pt-50LC14 have a lamp
Yes it does! Behind the front bezel under the screen. you can buy it here. http://projectorlamps.com/panasonic-dlp-tv-bulbs-pt-50lc14.html PT 50LC14 Panasonic Genuine High Quality Original Projector Lamps now...
Refer to the manual or the instructions that are shipped with the lamp.
Apr 25, 2015 | Panasonic Televison & Video
I got the 1080i panasonic hdtv which lamp indicator light flashes 4 times and wont turn on.what could be the problem.
I would check the lamp first. These are the most common failures and can be replaced by the consumer with step by step directions in the user's manual. Check the lamp by removing the lamp door and checking the bulb. If you see either a shattered or cloudy bulb, then you need to get a new lamp.
Oct 13, 2009 | Panasonic PT-53WX53 53" Rear Projection...
I have a Panasonic HDTV 1080i 52inch TV that is 6 years old. When I turn it on, the green power light just blinks and there is no picture at all. Any advice?
Check the lamp. Detach the front cover, read the warning, unscrew the cover, look inside, undo the one and only screw you can find, and pull out the lamp module. (Without touching the lamp) have a look at the light. Can you see it smokey in colour, or is the filament broken? This is how the PT-50LC13-K that I found in the garbage behaved, and the lamp filament is toast. Just thought I'd share.
Oct 10, 2009 | Panasonic PT-50LC13 50" Rear Projection...
How do you rset the lamp timer on a panasonic hdtv
Panasonic Lamp timer reset.
To reset the lamp timer
For the full instructions and how to reset the lamp timer go to the following site
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
I hope this information allows you to resolve this issue.
asnowman
Oct 04, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Blury screen on panasonic 1080i hdtv
seeing double and a lot of green on my panisonic hdtv 1080i what do i need to replace?
Aug 23, 2009 | Panasonic Televison & Video
Panasonic HDTV 1080i Lamp out Panasonic 1080i 42" HDTV - - saying "lamp needs to be replaced, reset lamp" - - what does this mean and how do I fix it??
Jun 01, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
My picture is dark and have changed the brightness
Hello!
Well it seems that your lamp is about to go out, replacing the lamp might jus do it ! Also make sure you get a Philips lamps, they work like a charm.
And regarding the long plastic cover just be a little bity patient and you'll make it come off, just make sure you do remove all the screws.
Apr 18, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic 1080i HDTV 52 in. will not turn on occasionally. Is there a hidden reset button?
Can i use a wii game system with a panasonic 52 inch 1080I hdtv?
Apr 10, 2009 | Televison & Video
This model is notorious for needing a new lamp about every 2 years. The lamp is accessed through the front by removing the long plastic cover under the screen (it just pulls off). Under that, to the left of center, is a square cover with one grey plastic screw. Loosen the screw and pull the lamp assembly out. It should just slide right out. Turn it around and look at the lamp. If the lamp face or reflector looks "cloudy" or "misty". Replace the lamp with Philips part number TY-LA1000. Just Google the number and you will find them available for around $100
Mar 18, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic PT-61LCX65 61" Rear Projection HDTV Logo
64 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
