Question about AEG Lavamat Lavalogic 1600 Front Load Washer
The machine is giving error code(CD) PNC: 1100007941 and not working after pushing start buttom and not able to reset or solve it.
2 Suggested Answers
  • 3230 Answers
SOURCE: AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
Posted on May 06, 2009
Hi, machine will not begin centrifuging, motor is not turning and at the program ends error code c9 pnc:110006989 appears. if machine is empty there's no problem. I changed the motor brushes but thi
press at the same time the two first buttons ( pre washing and soaking) And turn the button one time to the left (delicate spin drying). Wait few seconds, everything should be reset now. Good luck!
Dec 21, 2014 | Washing Machines
Hello, I have the Asko W6761 and all of a sudden it doesn't run the cycle anymore. It starts normally, i.e. pumps water into it, but then it doesn't start to wash..any idea what this could be? After a few...
Hello, my W6761 becomes the same. When it happens, you can clear the problem by "soft ware reset". Following is the procedure:
1. Power it on
2. Push Start/Stop buttom 5 times
3. Push "Enter", ">", "<", "Menu" buttons (from right to left)
4. Again, push "Enter", ">", "<", "Menu" buttons
5. Wait for 30 seconds that the above soft ware cycle resets the internal status
6. Toggle the power switch
7. You need to execute above "soft ware reset" within 15 seconds
Start washing and check to see if above reset the problem.
If it does not begin to work, repeat above "soft ware reset" cycle until it begins to work.
My W6761 once needed to repeat above cycle 7 times to solve the problem.
W6761 seems to be weak at high ambient temperature.
Tsunett
Oct 26, 2010 | Asko W6761 Front Load Washer
What does error code EHO mean
That error code does not exist,the closest is EH1.which means that the supply to the machine is incorrect.What is the model,and PNC.number,hope this helps.
Regards.
Jul 02, 2010 | Zanussi Washing Machines
Toshiba e-studio120, H4 error code. what it`s meen??
seems like heat roller problem.
enter code C, exposer light buttom, C and exposer light buttom , then all the indicator in the machine goes off. then enter 14 and press print buttom. Now your machine must work. If not Pls refer to technician.
Jul 08, 2009 | Toshiba e-Studio120 Copier
Error 11
Error 11 and or Error 17 is mean that CD is dirty or scratch, and the optic can not detect CD track.
Solved problem:
1. Clean the CD
2. Change open source by push knob going to "CD" display or push "search" from remote to "CD" display
3. If still come out Error 11, change the MP3 CD by Original CD with clean track CD.
4. For the last step, clean the optic sensor by CD cleaner for a few minute.
5. Check and try to play the CD again.
Apr 26, 2009 | Pioneer Car Audio & Video
Asko W6761 - seems fine, starts to fill 40 seconds then stops!
1. Power it on
6. Power it off and on, again
This problem happens in mostly in warmer season, so this will be related with high ambient or water temperature.
ASKO technician may replace the controller but even with the replaced controller, this problem often happens.
Tsunett
Mar 16, 2009 | Asko W6761 Front Load Washer
Samsung washing machine reset code
i have samsung
6 kg WA80HAG silver nano
dear'
plz help me to reset washing
machine
thanks
Mar 18, 2008 | Samsung WF337AA Front Load Washer
No start with a start buttoms and more....
Try this -
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=97,E=0000000000825271086,K=7324,Sxi=2,Case=Obj(26419)
Jan 02, 2008 | Palm LifeDrive Handheld
Xerox XD100
I have a XD100 Work Center with a L6 error code indication. After press "C" Clear (orange color button), followed by "Auto" (the most left small button) - exposure mode key; and "C" followed by "Auto" again, the copier starts to print and solved problem.
Nov 02, 2007 | Xerox WorkCentre XD100 All-In-One Laser...
AEG Lavamat Lavalogic 1600 Front Load Washer Logo
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
