Question about Whirlpool ACQ189XM Air Conditioner
Not blowing cold air
Samsung window unit not blowing cold air
  • Randy Prevost
    Randy Prevost May 11, 2010
    ijcnluv,
    Please supply more details. Here are a few things to clarify:
    How many BTUs does the unit support?
    What are the conditions (ie. room size, ave temp, climate) of the area you need to cool?
    How old is the unit?
    Are you the original owner?
  • 148 Answers
If the compressor is running and the filter is clean could need a shot of freon
Posted on Jun 21, 2009
Go n check whether ur compressor is there or its stolen by someone else...
Posted on May 08, 2010
My samsung portable window air conditioner is 4 years old and it does not blow cold air. Like at 66 degrees it is not that cold why
It is either low on freon,or,the unit needs to be removed,and cleaned,especially the coils,the condenser coils,and the evaporator coils,be careful not to bend fins on coils,use a water hose,and clean the inside of the unit out,clean off coils real good,see if this is the problem,it always helps.If this was helpful,please rate,and thank you,
Jun 28, 2010 | Samsung AW1203B Air Conditioner
Not blowing cold air anymore
Possibly dirty evaporator coil or condenser coil. Maybe dirty filters. Also could be low on refrigerant charge.
May 17, 2010 | GE AJCQ08ACB Air Conditioner
A/c works heating blows cold air
Is this an electric unit? I guess it is. It appears tha the heating elements are not activating. Check to see if the contactor pulled in on a call for cooling>
Oct 20, 2009 | Carrier YC273D Air Conditioner Window/Wall
Unit is icing up and not blowing cold air
Usually when this happens, the unit is low on freon. If you have an AC tech come out, make sure he does a leak check for you. Hope this helps... good luck!
Sep 02, 2009 | Samsung AW0505M Air Conditioner
Panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Jul 17, 2009 | Carrier 52PQ307 Wall/Window Air...
Window ac unit is not blowing cold air
When the unit is running, go outside and put your hand near the condenser fins, this air that comes out should be slightly warmer than the ambient temp. If it is not you will need to take the unit out of the window and out of its outer case and clean the condenser fins from the inside, this is no easy task as it is very hard to reach. You will want to get a small (toothbrushed sized) brass bristled brush with a long handle. Make sure the evaporator coil (in the front) recieves the same attention and wash the mesh filter that goes in front of the evaporator. Re- assemble and enjoy the cold air.
Jun 07, 2009 | Whirlpool ACQ189XM Air Conditioner
Not blowing cold air, do u recharge this unit?
only after you find a leak. first u have to make sure if the compressor is running at all. condenser side spinning. if compressor is not working it will blow hot air if the condenser is dirty or blocked but then u would get a minute or two of cold air then hot. you have to determine its empty or what else might be the cause before you start dumping in freon.
May 25, 2009 | Samsung Heating & Cooling
Air conditioner
If the fan blows cold air the compressor is already on.
Jul 18, 2008 | Heating & Cooling
Comp shuts off
Coils could be dirty. Compressor could be getting too hot and cutting off. Will have one fan motor that turns condenser fan and evaporator blower.
May 30, 2008 | Fedders D Chassis A6D24E7A Air Conditioner
Whirlpool ACQ189XM Air Conditioner Logo
443 people viewed this question
Top Whirlpool Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
