Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
ADMIRAL REFRIGERATOR/FREEZER BURNED
Admiral refrigerator/freezer side-by-side burned on the inside with faulty wiring. Repairman stated wiring was the cause of melting plastic inside the refrigerator not replaceble. The whole refrigerator was smoked/black and all groceries in refrigerator and freezer ruined. Happening during the night while family slept, could have died of smoke inhalation. Purchased new refrigerator/freezer. Could you give an address for Admiral Refrigerator Headquarter to show pictures of the damage and smoke.
Brenda Mc
Crowley TX
817-297-2420
  • jojomama101 Oct 26, 2008
    I have an  Admiral model ASD2120DR . It's a side by side. I heard a Sizziling sound coming from the freezer. Is it normal to have a hot coil on the back wall on the bottom? We turned it off for now. HELP my food is going to melt soon!
  • 410 Answers
Admiral is a maytag owned company which is now owned by whirlpool. so contact maytag or whirlpool. google them should be eay enough to find..
Posted on Dec 20, 2007
My admiral model hmg-64184 is leaking water from the bottom of freezer
It sounds like you have a broken place in the door gasket that is allowing warm air to enter the freezer.
May 29, 2015 | Admiral 26 cu. ft. Side-By-Side...
My frost free, Admiral, side by side freezer just stopped working, i plugged it out for two days and when i plugged it back in neither the freezer or fridge works. Its actually warm inside both sides and i...
Whoops
The fridge has a refrigerant leak, or the thermostat has failed.
Try replacing the thermostat, if that does not work then you will need to call a technician in to find and repair the refrigerant leak and regass the fridge
Mar 30, 2011 | Admiral 26 cu. ft. Side-By-Side...
GE side by side has ice from top to bottom on inside back wall of freezer. GE repairman replaced defrost heater about 2 years ago. Could this part burn out this fast. Freezer temp. is 25 to 30 degrees.
It shouldn't burn out that fast but may have. Some of the side by sides came from the factory with only one heater. Later on it was decided that the replacement heater kit include a second heater. This could be the case for you.
Jul 11, 2010 | GE Refrigerators
Admiral ATF1910DRW refrigerator. The refrigerator
hi there,
there seems to be a technical error. call your repairman to have him take a look at the inside wiring before your food gets spoiled even more.
Jun 11, 2010 | Refrigerators
Have moved into new house with Admiral freezer/fridge/icemaker. Leaks water onto floor from time to time under freezer. Ice maker not connected to water supply so not that.ANY SUGGESTIONS?
Defrost drain is clogged causing this problem. Clear the dfrost drain and pan from inside the freezer section by removeing the freezer back cover plate and you will see from there. No extra parts required just patience.
Feb 01, 2010 | Admiral 26 cu. ft. Side-By-Side...
My freezer control in my ge side by side refrigerator is stuck
change the termostat that control temperature . is burned out. you need new one.
Apr 05, 2009 | Admiral 26 cu. ft. Side-By-Side...
Burned hole in freezer liner
take off the back panel inside the freezer and in the coil you'll see the defrost heaters(about 3'' glass tube,look for a burned wire or a loose conection to the heaters that might sparked or ground with the wet freezer walls.
Apr 02, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Admiral side by side refrigerator won't stay cold.
change the defrost thermostart or check door(ajar) or damper control
Mar 26, 2009 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
300 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
