Question about Garden
Whitch gap valve on 12.5 hp ic 289707 briggs and stratton
  • 15 Answers
SOURCE: briggs and stratton lawnmower 4horse power engine needegap specs on coil and points
That's easy man! You will always hear, "You sir, need to gap this or that at EXACTLY .00071542 inches per square meter".
The actual "poor boy fix"-
Put your magneto back on there, and stick a business card from your wallet in between it and the rotor. Let the magneto pull itself to it, you center it, and give it just a hair of breathing room (to slide the card back out). Tighten 'er down, and you got it.
1.- If you can't pull the card out, it is too tight.
2.- If you pull the card out easily, too loose.
3.- JUST enough to pull it out, and have it drag just a bit on the way out is JUST ENOUGH!
Remember, on 4-strokes, they ARE forgiving, and can do miracles even if you try your best to destroy them.
Posted on May 30, 2009
moretons
  • 155 Answers
SOURCE: how do you adjust the valves on a 17.5 ohv briggs
Hi 1st remove the rocker cover and spark plug
hold a long skinny screwdriver down the plug hole and wind the engine by hand until you get top dead centre (NOTE WATCH ROCKERS) first the intake valve will open then close when it closes the piston should be coming up to top dead centre and both valves should be closed and the rocker loose setting should be 0.004 thou you need to undo the locking screw down the centre of the adjusting nut then you can adjust to setting, (DONT FORGET TO DO THE LOCKING SCREWS BACK UP) reassemble
Posted on Jul 27, 2009
  • 110 Answers
SOURCE: want a repair manual for a 17 hp briggs &
A range of strip-down manuals for all Briggs & Stratton engines is avalable - I got mine from Amazon, but you can get them directly from Briggs & Stratton via their web site. They have a look-up system by model series, which ensures you end up with the manual that covers your engine.
Posted on Oct 03, 2009
hunter19_46m
  • 7482 Answers
SOURCE: 4.5 hp Briggs& Stratton push mower will not run
You need to rebuild your carb. The diaphram in the carb has gotten hard and is no longer acting as a fuel pump to pump the fuel to the carb. Get a rebuild kit and a compressor (for compressed air) to blow out the jet passages. It is an medium to easy job, just watch the small parts. ----------------------------------------------------------------------------- Hint: Before you remove your fuel/air jets, bottom them out first and count the number of turns it takes to bottom them out and mark it down for each fuel/air jet. When you go to reinstall the fuel/air jets bottom them out and then back them back out to the number of turns before removal. That way the fuel/air jets are set to the right number of turns when it was running right. Good Luck, I hope this helped Please rate me...Thanks
Posted on Jan 04, 2010
  • 2841 Answers
SOURCE: 2006 17.5 briggs and stratton ohv need specs on
Remove the spark plug. Turn the flywheel until the piston is at Top Dead Center (TDC) on the compression stroke. Continue to turn the flywheel until the piston drops down 1/4". Set the intake valve at .004" - 006". Adjust the exhaust valve to .006" - .008". You can use a pencil to know that the piston down 1/4". Just put it in the spark plug hole against the top of the piston and then place a mark on the pencil at the lip of the spark plug hole. Now measure up 1/4" and place another mark. Turn the flywheel unit the second mark is flush with the lip. The feeler gauge should be snug but move freely when adjusting the valves. Double check it after locking the rocker arm nut down.
Posted on Oct 18, 2010
HOW DO I GET A REPAIR MANUEL FOR A BRIGGS AND STRATTON 12 HP IC QUIET ENGINE
Try website for Briggs & Stratton. Or use Google Search for Briggs & Stratton 12 HP IC Quiet Engine Manual.
Oct 02, 2014 | Heating & Cooling
Oil coming from valve cover
did you gap spark plug to.028" ? may need to replace the valve cover gasket.
May 24, 2012 | Briggs & Stratton Briggs Stratton Intek V...
What is the valve settings on a Model 31 C707 Type 0175E1 Code 040804ZD Briggs Stratton Engine ?
Hi and welcome to FixYa, I am Kelly.
Your engine service manual is here:
http://www.mymowerparts.com/pdf/Briggs_&_Stratton_Service_and_Repair_Manuals_Spec_Charts/276781%20Single%20Cylinder%20OHV%20BRIGGS%20&%20STRATTON.pdf
Spec sheet on page 175 of the pdf file above.
The valve gap is 0.003 - 0.005 for intake
exhaust gap 0.005 - 0.007
Valve maintenance is in sections 6 and 12 with some comments in section 1.
Thanks for choosing FixYa,
Kelly
Jun 25, 2011 | Briggs & Stratton Garden
7 hp oh valve sears frame
Remove the cover for the valves by the spark plug and adjust both valves at .008 gap
That will end the back firing. They have locking nuts (double nuts) at each valve to adjust
Jun 10, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Engine wont start
go to youtube and type in valve adjustment on briggs,very simple procedure to do.
Apr 23, 2010 | Briggs & Stratton 66set Panzer Tractor...
Need point gap setting for 8 hp Briggs and Stratton gas engine
If it is an older BS it will be .015 That was standard. In fact an old match box cover would work to set them if you could not find a guage
Oct 07, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
15.5 intek pushrods whitch one is for the intake vavle ?
Intake is aluminum, exhaust is steel. Set valves 1/4" past top dead center on compression stroke (both valves closed), intake (bottom) .003-.005, exhaust .005-.007
Jul 08, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
126 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
